K
Rep Power: 8 ![]() |
Hey everyone!
I am new to OpenFoam and I am learning about interFoam. Currently I am trying to write the data for a new variable that can be read in Paraview. For example: Say I want to write the rho variable data for the user defined writeInterval. I edited the CreateFields.H file as (the part dealing with rho variable) volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), alpha1*rho1 + alpha2*rho2 ); rho.oldTime(); // writing a new variable rho.write(); But this doesnot seem to work, any suggestions on how to address this problem? Thank you! |
Rep Power: 15 ![]() |
I am not sure why interfoam doesn't automatically write rho, but an easy to understand work around is to define a new field, say rhoWrite, that's written automatically. Then you just need to compute/update rhoWrite with rho before the solver writes data with runTime.write(). So, add
volScalarField rhoWrite ( IOobject ( "rhoWrite", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), alpha1*rho1 + alpha2*rho2 ); Code:
rhoWrite = alpha1*rho1 + alpha2*rho2; Caelan. |
K
Hey Caelan
Great! That worked ![]() Thank you -Kurian |
Aashay Tinaikar
Rep Power: 7 ![]() |
Hii Kuria and Clapointe,
Thanks for posting the question and giving a very working answer. I was facing an issue where the scalar field variable was not written at output. Precisely, I just added a variable in a manner given in the wiki page https://openfoamwiki.net/index.php/H...ure_to_icoFoam I found out that the new variable is written when I specify fixedValue velocity condition but not when I change it to flowRateInletVelocity. Therefore, I suppose it might have some bug. Quick fix: Add variable_Name.write() just before runTime.write() |
#5 | |
Aashay Tinaikar
if(runtime.outputTime()) { variable_Name.write(); } Thanks. Hope this helps. |
Vishal
Rep Power: 5 ![]() |
Hey Guys, is there a possibility where the changes should not be done in the solver but in the controlDict file to write a new variable?
I am trying to write drag coefficients in the multiphaseEulerFoam. I can not make changes in the original solver due to some permission rights. Is there a way that I can add lines in a case directory to write it? Thank you |
Yep, this is possible via function objects compiled at runtime. You can do something like the following (which is added to controlDict) :
functions { vorticity { libs ("libutilityFunctionObjects.so"); type coded; name vorticity; codeExecute #{ const volVectorField& U = mesh().lookupObject<volVectorField>("U"); volScalarField enst = 0.5*magSqr(fvc::curl(U)); static autoPtr<volScalarField> pField; if(!pField.valid()) { pField.set ( new volScalarField ( IOobject ( "enstrophy", mesh().time().timeName(), U.mesh(), IOobject::NO_READ, IOobject::AUTO_WRITE ), enst ) ); } volScalarField& enstrophy = pField(); enstrophy.checkIn(); enstrophy = enst; #}; } } Caelan |
#8 | |
sujata
Rep Power: 6 ![]() |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 09:29 |
Need help in writing UDF for an oscillating airfoil to get Output parameters | ned.musab | FLUENT | 0 | October 27, 2017 11:21 |
writing a scalar in the output | anishtain4 | OpenFOAM | 6 | January 25, 2013 04:16 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
