Ventilation of High-Rise building with ODU
Like Tree1Likes
  • 1 Post By piu58
Old   March 6, 2018, 05:39
Default Ventilation of High-Rise building with ODU
Bhargav lakhlani
bhargav1195 is on a distinguished road
Hello Everyone,
I am trying to simulate the flow and heat analysis of high-rise (33 Floor) building using buoyantboussinesqpimplefoam.
Physics of the problem:
Every floor has two ODU(Out-Door Unit). I have registered two inlet and two outlet of ODU in the domain.Boundary conditions are
1) Pressure: Inlet - zerogradient
outlet- fixed value 0
2) Velocity: Inlet - fixed value 1
outlet- zerogradient
3) Temp: Fixed value at inlet
With this BC, even when I try to run simplefoam, solution is diverging. I have attached screenshot and my case folder in following link for reference
https://drive.google.com/open?id=122...PHKf712bvsksNh
Basically flow coming out from the outlet of ODU is at higher temp and due to natural convection it should create thermal stacking effect and flow should move towards upper floors.
ERROR
1) I have fixed flow rate at Inlet and Outlet of the ODU and I am giving fixed rate at Inlet but I am confused what should i give in velocity BC at outlet? should I give fixed flow rate or zero gradient?
2) Which BC for velocity and Pressure I should give to the upper surface of the floor from where flow should be defuse to upper floor? should I give freestream condition or zerogradient?
3)As the hight of floor increases, the inlet temperature also varies due to higher temperature flow coming from bottom floors due to thermal stacking. How to incorporate this varying temperature at inlet in buoyantboussinesqpimplefoam.
Can anyone suggest me appropriate boundary conditions and solution for this problem. Once again, I have uploaded all the case file and model geometry picture in the following link for reference
Thank You
Regards,
Bhargav
bhargav1195 is offline   Reply With Quote
Old   March 6, 2018, 06:06
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I tried to run your case. It is not complete:
--> FOAM FATAL IO ERROR:
keyword PIMPLE is undefined in dictionary "C:/OpenFOAM/17.02/Z0Pilz-3.0.x/run/Test/system/fvSolution"
file: C:/OpenFOAM/17.02/Z0Pilz-3.0.x/run/Test/system/fvSolution from line 22 to line 74.
    From function dictionary::subDict(const word& keyword) const
    in file db/dictionary/dictionary.C at line 648.
FOAM exiting
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 6, 2018, 07:10
Bhargav lakhlani
Hello Uwe,
Thanks for giving some time in trying to help me. In controldict file I have given simplefoam as a solver name. I have set all conditions with respect to buoyantboussinesqpimplefoam and simplefoam. But in your error message it is written that PIMPLE word is undefined. So is it anyway possible that you are trying to run the PimpleFoam? Or am I mistaken here?
Thank You again.
Regards,
Bhargav
Old   March 6, 2018, 07:37
piu58's Avatar
Uwe Pilz
If I try to uses ..SimpleFoam I get
Unknown patchField type noSlip for patch type wall
Of course, this one I could repai by myself. But I ask you to give a case which ic checked, so it runs.
bhargav1195 likes this.
Uwe Pilz
Old   March 6, 2018, 07:55
Bhargav lakhlani
Hello Uwe,
I am really sorry for this error. One bracket was missing in the P/0 file which I have rectified and now it is running. Th file I have updated in the shared folder. After few iterations epsilon and k will diverge and solution will stop. I really need help to adjust boundary conditions so that case runs as per our requirement.
Thank you so much for giving your time to help me.
Regards,
Bhargav
Old   March 6, 2018, 08:44
piu58's Avatar
Uwe Pilz
I found more errors and cured them:
Unknown asymmetric matrix solver PBiCGStab
Valid asymmetric matrix solvers are :
4
BICCG
GAMG
PBiCG
smoothSolver
and
keyword p_rgh is undefined in dictionary "C:/OpenFOAM/17.02/Z0Pilz-3.0.x/run/Test/system/fvSolution.solvers"
file: C:/OpenFOAM/17.02/Z0Pilz-3.0.x/run/Test/system/fvSolution.solvers from line 22 to line 25.
FOAM exiting
But I have it running now.
This lead to a questions: Do you have any minimal experience with OF? Your problem is not a elementar one and requires some knowledge. If you don't have that I recommend to simulate much easier (but connected) cases first.
Uwe Pilz
Old   March 6, 2018, 08:55
Bhargav lakhlani
Hello Uwe,
Thank you so much again.
I dont have any experience in OpenFOAM but I do have experience with other CFD Packages. I studied and tried few documents and cases of OpenFOAM and based on that only I am trying to simulate this case. In this case all I want is flow and temperature analysis due to two inlets and outlets. That's all. On top of that I have done the analysis for Single floor and then Two Floor combined and in both case I was able to get the desired solution. But with the same boundary condition I am not able to get the converged solution for 33 Floors. I am creating Mesh in salome. I am able to understand most of boundary condition but few only I am not able to understand
1) The Top surface from where flow will move to the atmosphere, U, P, and P_RGH BC for this TOP surface. As per my understanding, for buoyantboussinesqpimplefoam P_RGH is only required for calculation.
2) Freestream boundary..i.e. surfaces on the sides of the computational domain
can you suggest me some appropriate BC for above case or will it change according to every specific case?
Thank You so much.
Regards,
Bhargav
Old   March 6, 2018, 09:02
piu58's Avatar
Uwe Pilz
I repaired the case and it comes to an end:
Time = 24
DILUPBiCG:  Solving for Ux, Initial residual = 8.75483e-009, Final residual = 8.75483e-009, No Iterations 0
DILUPBiCG:  Solving for Uy, Initial residual = 1.50941e-008, Final residual = 1.53925e-010, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 1.16955e-008, Final residual = 3.88379e-011, No Iterations 1
DILUPBiCG:  Solving for T, Initial residual = 4.70309e-007, Final residual = 7.29866e-010, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 0.427255, Final residual = 0.00347759, No Iterations 6
time step continuity errors : sum local = 1.02881e+022, global = -1.27014e+020, cumulative = -1.27014e+020
DILUPBiCG:  Solving for epsilon, Initial residual = 4.90031e-009, Final residual = 4.90031e-009, No Iterations 0
bounding epsilon, min: 2.34381e-023 max: 3.89193e+046 average: 3.28729e+040
DILUPBiCG:  Solving for k, Initial residual = 7.44824e-007, Final residual = 2.61052e-009, No Iterations 1
bounding k, min: -4.60822e+030 max: 1.43061e+045 average: 3.67576e+039
ExecutionTime = 936.233 s  ClockTime = 937 s
SIMPLE solution converged in 24 iterations
End
Commercial codes have more support of selecting the right computational environment. In OF you need to know more (in fact: Nearly all details).
Even if I have a result now I would not trust it. I am not close enough to your problem.
I strongly recommend to start with a model case, which si of simpler geometry, but contains all the physics. It would be best if you have a reference solution for that case. I would deal with more complicated cases not until having full success with a model case.
Uwe Pilz
Old   March 6, 2018, 09:10
Bhargav lakhlani
Hello Uwe,
Thanks for the help. May i know what changes you have made? Can you share that files? I have also obtained such result but the high value of Bounding K and Bounding epsilon used to scar me. According to you, is it fine to have such value?
Now I will try to run buoyantboussinesqpimplefoam and hopefully I will get desired results.
Thank you so much for help.
Regards,
Bhargav
Old   March 6, 2018, 09:24
piu58's Avatar
Uwe Pilz
I did not analyze what happened with the k values. They are much to high, of course.
My changes:
In 0/U instead of noSlip
	type fixedValue;
		value uniform (0 0 0);
in fvSolution:
   "(U|T|k|epsilon|R)"
        // solver          PBiCGStab;
		solver BICCG;
        preconditioner  DILU;
        tolerance       1e-08;
        relTol          0.01;
	p_rgh
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.01;
        smoother         DICGaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    p_rghFinal
        solver           GAMG;
        tolerance        1e-7;
        relTol           0;
        mergeLevels      1;
Uwe Pilz
Old   March 6, 2018, 09:31
Bhargav lakhlani
Hello Uwe,
Thanks so much for sharing the change. I will study about that and will further make some changes to decrease the bounding k and bounding epsilon value.
Your help is much appreciated.
Thank you so much.
Regards,
Bhargav
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 13:29
High Lift Airfoils At High Angles Of Attack Luiz Pancini FLUENT 2 April 9, 2015 09:01
forced ventilation boundary conditions???? annu Main CFD Forum 0 May 2, 2014 10:05
[ANSYS Meshing] High aspect ratio Roby_1986 ANSYS Meshing & Geometry 0 February 22, 2013 06:34
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
