[reactingTwoPhaseEulerFoam] large time step challenge |
February 28, 2018, 21:06 |
#1 | |
Gerhard Holzinger
Rep Power: 28 |
the commit message [1] for the introduction of the face-based momentum equation states, that the face-based momentum formulation allows for: Quote:
For a setting of maxCo=0.75, the simulation crashes within the first 5 seconds, for both formulations. Using the face-based momentum equation, however, improves the solution in a way, that it does not show some sort-of checkerboard-like artifaces, see the attached PNGs. My working theory is that the two-fluid Euler-Euler model is not happy with Courant numbers larger than 0.5. Single-phase solvers, on the other hand, can be run with maxCo settings up into the low two-digits, e.g. I ran a vortex shedding case up to maxCo=20 with a reasonable accuracy of the vortex shedding frequency. So now the challenge: Does anybody find a case-setup, which allows for larger time steps respectively Courant numbers than the ones I achieved so far. References: [1] https://github.com/OpenFOAM/OpenFOAM...777bb10a3e1dda Rules:
August 11, 2020, 10:53 |
solution dependency on maxCo
Rep Power: 8 |
I am not sure if my question/finding fits here, but I thought it is the most suitable thread. I recognized, that the solution using reactingTwoPhaseEulerFoam in OpenFOAM-7 as well as multiphaseEulerFoam OpenFOAM-8 strongly depends on the maxCo number, even if maxCo is always well below 0.5 (see pictures). Do you have any ideas why this is happening? Is it okay or is there a problem with the solution algorithm? (or maybe only with my case-setup?) My idea was, that the differences come from the MULES algorithm. Possibly, different time steps lead to a different blending of high-order and low-order schemes and therefore to different "diffusivities" of the solution. I attached the case setups for reactingTwoPhaseEulerFoam (OF7) and multiphaseEulerFoam (OF8). |
euler-euler, timestep size |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 06:28 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
