Foam::error::printStack after adding New Drag model
Like Tree1Likes
  • 1 Post By anuragm
Old   February 26, 2018, 09:40
Default Foam::error::printStack after adding New Drag model
SURAJ
surajkvs is on a distinguished road
I have added one new drag model and compiled it successfully.
After that my new solver also I compiled.
Than I run the default case 'Goldschmidt' with the new drag model it run succesfully in MPPICFoam solver.
But when I am running my own case it gets stop somewhere between 0.1 to 0.2 sec of simulation.and shows following error.
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? in "/lib/x86_64-linux-gnu/libm.so.6"
#4 pow in "/lib/x86_64-linux-gnu/libm.so.6"
#5 Foam::EmmsAtdDragForce<Foam::KinematicCloud<Foam:: Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foam :article> > > > >::calcCoupled(Foam::MPPICParcel<Foam::KinematicPa rcel<Foam:article> > const&, double, double, double, double) const at ??:?
#6 Foam::ParticleForceList<Foam::KinematicCloud<Foam: :Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foa m:article> > > > >::calcCoupled(Foam::MPPICParcel<Foam::KinematicPa rcel<Foam:article> > const&, double, double, double, double) const at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 ? at ??:?
#11 ? at ??:?
#12 ? at ??:?
#13 ? at ??:?
#14 ? at ??:?
#15 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#16 ? at ??:?
Floating point exception (core dumped)
Can anybody please help me.I have read few PrintStack problems but unable to find my solution.
surajkvs is offline   Reply With Quote
Old   February 26, 2018, 10:54
Anurag
anuragm is on a distinguished road
Usually happens when there is division by zero or similar error. I'd suggest recompiling your code using the following flag in your Make/options
 -DFULLDEBUG -g -O0
This will help you to trace the source of your error. Perhaps you will need to ensure your model is valid in extreme cases by adding a small term to the denominator.
surajkvs likes this.
anuragm is offline   Reply With Quote
Old   March 10, 2018, 13:11
SURAJ
Thanks a lot Anurag for reply,Actually it worked when I changed the mesh.
printstack
Adding New phaseCompressible Turbulence Model scram OpenFOAM Programming & Development 34 March 25, 2020 09:08
Adding a custom turbulence model in OpenFOAM 3.0 Sylvain OpenFOAM Programming & Development 3 July 18, 2016 09:15
Airfoil lift and drag using k-kl-omega turbulence model hylleman OpenFOAM Running, Solving & CFD 6 June 17, 2016 16:10
How to compile a new drag force in Lagrangian model lilinmin OpenFOAM Programming & Development 4 June 9, 2016 05:15
multiphase model and drag law Yasmail AKARIOUH FLUENT 0 April 29, 2008 08:44
