perforated plate simulation using porous media |
February 11, 2018, 02:35 |
mahdi
Rep Power: 11 |
Hello
I want to simulate a perforated plate using the porous media technique. This plate has been used in a silencer and the flow is parallel to this plate(Something like attached picture). unfortunately, there is no experimental pressure drop data for this plate(Just an experiment for pressure drop in the whole silencer is done). Thus we have to use one of the empirical equations proposed by Smith, Idelchik, Ergun ... to find inertial coefficient and use one of the available methods in OpenFOAM(Darcy-Forchheimer, fixed Coefficient or power-low) for simulation. unfortunately, these equations can not estimate the correct inertial coefficient and to the best of my knowledge, there is not enough research in this field. I really appreciate if someone who has experience in this kind of simulations could help me. |
May 16, 2018, 10:36 |
Anna Feichtner
Rep Power: 10 |
Hello Mahdi,
do you have a solution or any ideas yet? I am facing a very similar problem... Best wishes, Anna |
May 16, 2018, 11:39 |
mahdi
Rep Power: 11 |
May 17, 2018, 07:54 |
Anna Feichtner
Rep Power: 10 |
Ok
Thanks for the update. Anna |
November 26, 2018, 04:11 |
Tobias Holzmann
Rep Power: 52 |
Hi all,
you can estimate the pressure drop using an own simulation and only a section of the plate. For different velocities, we get different pressure drops which can be used to estimate the Darcy-Forchheimer Coeffs. Tobi
Keep foaming, Tobias Holzmann |
transient Simulation with porous media | Chrisi1984 | OpenFOAM Running, Solving & CFD | 6 | August 26, 2015 17:13 |
Solid Properties Setup In Simulation of Porous Media | Modest Cat | FLUENT | 4 | March 26, 2012 06:00 |
Alternative modeling of an perforated plate (not as a porous medium) | airflow | CFX | 1 | March 1, 2012 18:07 |
Benchmark for porous media simulation | siw | Main CFD Forum | 4 | February 7, 2012 15:14 |
Perforated Plate with Porous Media | giogio | FLUENT | 4 | July 8, 2008 16:07 |
