For P_rgh, the number of iterations is always greater than 500.
Like Tree1Likes
  • 1 Post By Jack_Kerouac
Old   February 2, 2018, 10:22
Default For P_rgh, the number of iterations is always greater than 500.
Kai Jiang
Jack_Kerouac is on a distinguished road
Hello,foamer
i'm modeling the two phase system of water and solid particle using twoPhaseEulerFoam. But, For P_rgh, the terimnal indicates the number of iterations is always greater than 500.
I can't solve the problem, please help me !
Best regards!
Jack_Kerouac is offline   Reply With Quote
Old   February 2, 2018, 11:09
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
which linear solver are you using? Please read the thread from Nils: How to give enough info to get help
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   February 2, 2018, 11:34
Kai Jiang
Hi,Tobi
Thanks for you quick reply. I will illustrate the case from me and the problem i met in terms of your advices
Best regards!
Tobi likes this.
Old   February 2, 2018, 15:13
Default twoPhaseEulerFoam-pipeline(3D)- diverges
Kai Jiang
Originally Posted by Tobi View Post
Hi, my current project is as follows:
I want to discuss a problem about two phase system of water and solid particle( slurry flow in 3D pipeline ) using twoPhaseEulerFoam.
The basic description about the problem i'm studying:
1.the solid-liquid two phase flow, that is slurry flow.
2.This is an isothermal flow. So, It doesn't have to solve the temperature equation from the document-"twoPhaseEulerFoam.C".
3.It is considered that the drag force and turbulent diffusion force affect the interphase momentum exchange.
4.the volume fraction of solid particle is more than or equal to 0.2.
5.the initial inlet velocity of water is 0.4m/s. the initial lnlet velocity of solid particle is 0.4m/s.
The problem i met :
The calculation has always been divergent and the terminal display for P_rgh, the number of iterations is always more than 500.
the geometry
https://app.box.com/s/lpx0af9v8op5jn7ua2bumx3ks12na899
the mesh
https://app.box.com/s/jweedcos5x5y51ogsfpmlsyml3iqosgs
the checkMesh
https://app.box.com/s/5cot7vlboi37btzuybeioje65tixxjbu
the fvsolution
https://app.box.com/s/e0s1zdqk4r4orbuogfxmf6nqje7u603f
the fvschemes
https://app.box.com/s/uazebrk7n060j54ilmgtyo2ek3e3q9yg
the case
https://app.box.com/s/w9yv9ym86teh86vqatk0dze4vahmirmf
the error code
https://app.box.com/s/xeartido1boommr8a2mqx0lcmf4y4qtj
Thanks!
two phase euler foam, two phase system
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 23:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
