February 1, 2018, 10:15 |
Particle tracking
Bill Lasher
Rep Power: 17 |
Hi:
I'm trying to do a simple particle tracking using one-way coupling (only the effect of the liquid on the particle). I've read conflicting things about whether icoUncoupledKinematicParcelFoam will do this. I've been able to model a single particle with buoyancy in a still fluid and get accurate results. When I specify a uniform velocity nothing changes - as though the solver doesn't recognize it. My eventual goal is to use another solver to get the flow field, then use a particle tracker to get the track. Am I going down the right path or do I need to use a different solver? Thanks, Bill |
February 1, 2018, 14:28 |
Answer to question
Bill Lasher
Rep Power: 17 |
Ok, so I solved my own problem and thought I might put it here for others, since I've seen a lot of posts about this.
First, I had an error in my kinematicCloudProperties dictionary where the patch names didn't match what was in blockMesh. I fixed that and everything worked as expected. To use icoUncoupledKinematicParcelFoam on an already-solved flow field, this is all I had to do: 1. Solve the original flow problem (I did the pitzDaily tutorial from the simpleFoam tutorials). 2. To the constant directory add/edit the following files, which you can get from the hopper tutorial: -g, kinematicCloudProperties, kinematicCloudPositions -add rhoinf to the transport properties dictionary 3. Replace the controlDict file with the one from the hopper tutorial and make the appropriate changes 4. Run icoUncoupledKinematicParcelFoam, then visualize using the instructions that can be found on the OpenFOAM wiki. Voila! |
July 10, 2019, 12:41 |
Rep Power: 9 |
I follow your instructions but the solver get stock forever on the first time step! perhaps do you have a working example? Thank you! |
July 11, 2019, 15:04 |
Example
Bill Lasher
Rep Power: 17 |
Hi:
I do not still have the files but I can try to re-create the case. Give me a few days and I'll get back to you. |
July 11, 2019, 16:28 |
Rep Power: 9 |
Thank you very much for your help! I really appreciate it. |
July 14, 2019, 15:05 |
Example
Bill Lasher
Rep Power: 17 |
Here is an example. Run the pitzDaily tutorial using simpleFoam, rename the last directory (288) to 0 and remove the other time directories.
Copy the attached controlDict, fvSchemes and fvSolution files to the system directory, and the remaining files to the constant directory, and run icoUncoupledKinematicParcelFoam (I used OpenFoam v. 6). You should be able to view the results in paraFoam. Good luck, and let me know if you have any problems! |
June 14, 2020, 05:25 |
I ran the pitzDaily case with simpleFoam and then overwrote the system/ directory and constant/ directory files with those from your zip file, and ran icoUncoupledKinematicParcelFoam. Finally, where I ran paraFoam, selecting kinematicCloud - Lagrangian under Mesh Parts and selecting all under Lagrangian fields, ParaView showed nothing.
Can you show what ParaView is supposed to show? I ran mine on Raspberry Pi-4 (Buster 32 bits), with ParaView built to 64-bit architecture and 32-bit IDs. ===== I see I missed out the steps in OpenFoamWiki: https://openfoamwiki.net/index.php/H...er_in_paraFoam (but isn't this said to be for massless particles tracking, whereas we are interesting in tracing Lagrangian particles?). Following that instruction, ParaView through errors complaining "The input dataset did not have a valid DATA_TIME_STEPS information key. I have seen this error message before when running ParticleTracks and trying to display the filter Temporal Particles to Pathlines. Last edited by Mars409; June 14, 2020 at 05:51. Reason: newer info. |
June 15, 2020, 11:09 |
Postprocessing
Bill Lasher
Rep Power: 17 |
Hi:
The wiki link you noted is different than the one I used and I believe it's for showing the flowfield rather than Lagrangian particle tracking (thus the massless particles). The link I was referring to is here: http://openfoamwiki.net/index.php/FA...gian_particles Note that you need to unselect everything in Volume Fields. Let me know if this solves the problem - if not perhaps zip your case and post it, I will take a look. |
June 15, 2020, 12:07 |
#9 |
Thanks. It works now using the Glyph filter.
Indeed after posting the last remark yesterday I looked through the time directories and inspected the Lagrangian VTK files (they are in ASCII) and came away wondering why ParaView wasn't showing the ball since the Lagrangian Fields list a whole bunch of them. So it's the Glyph filter that needs to get applied. Now I see the ball moving from left the the right when I tripled the end time. Strangely, though, in a separate cyclone simulation case prepared through the SimFlow GUI and viewed separately using ParaFoam invoked from the command line I did not have to apply the Glyph filter to see the particles. With that experience, I was expecting the same in this pitzDaily tutorial case that it caught my blindsided. On top of that--it maybe just me--somehow I am unable to display the Lagrangian field at the mesh at the same time. It's not just this case but that cyclone simulation as well. |
June 15, 2020, 12:47 |
#10 |
Bill Lasher
Rep Power: 17 |
Glad you got it to work! I'm not an expert on Paraview, I just figured this particular thing out and thought I'd share it.
Good luck! |
July 2, 2020, 19:13 |
#11 | |
Sricharan S Veeturi
Rep Power: 10 |
This may not be completely accurate but its a technique to get quick results. |
particle tracking |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
Lagrangian Particle Tracking in Eulerian-Eulerian Multiphase Flow | DarrenC | CFX | 5 | April 7, 2016 14:50 |
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message | peteryuan | OpenFOAM Installation | 6 | August 18, 2013 18:00 |
[OpenFOAM] ParaView ErrOr | soheil nazmdeh | ParaView | 1 | August 17, 2013 07:40 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
