pisoFoam, fully developed pipe flow using cyclic BC's
Like Tree2Likes
  • 2 Post By thijs1909
Old   January 29, 2018, 08:44
Default pisoFoam, fully developed pipe flow using cyclic BC's
Thijs
thijs1909 is on a distinguished road
Dear Foamers,
I would like to study the influence fully developed flow in tubes with a helix structure. I am particulary interested in the influence of the structure on the pressure drop. My Re=5300 and I am using kOmegaSST as a turbulence model.
I started three months ago using simpleFoam, cyclicAMI boundary conditions and fvOptions to specify the mass flow. I did not get good mesh independent solution for my tube with a helix structure so I went back to a simple tube using a structured mesh.
But instead of using simpleFoam I decided to use pisoFoam and solve in time. Again I wanted to using periodic boundary conditions to reduce my spatial domain. I noticed that both cyclic and cyclicAMI boundary conditions gave me severe osciliations for the pressure term. To overcome this problem I tried to using the mappedPatch boundary condition, mapping my outlet at z=0.01 to my inlet at z=0. So far I succesfully modelled hagen poiseuille flow, but now I turned on the turbulence and I do not know how to set the boundary conditions for k, omega and nut:
BC's I use for velocity U and pressure, which I know they are correct while they show the correct Hagen-poiseuille velocity profile:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 1);
boundaryField
    INLET
        type            mapped;
        value           uniform (0 0 1);
        interpolationScheme cell;
        setAverage true;
        average (0 0 1);
    WALL
        type            fixedValue;
        value           uniform (0 0 0);
    OUTLET
        type            zeroGradient;
Pressure P:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            zeroGradient;
    WALL
        type            zeroGradient;
    OUTLET
        type            fixedValue;
        value           uniform 0;
turbulent kinetic energy:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
internalField   uniform 0.0045;
boundaryField
    INLET
        type            mapped;
        value uniform 0.0045;
setAverage false;
average 0.0045;
    OUTLET
        type            zeroGradient;
    WALL
        type            fixedValue;
        value           uniform 0;
For omega:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 333.2391;
boundaryField
    OUTLET
        type            zeroGradient;
       // inletValue      $internalField;
        //value           $internalField;
    WALL
        type            fixedValue;
        value           uniform 1.3441e+7;
    INLET
        type           mapped;
value uniform 333.2391;
setAverage false;
average 333.2391;
     //   value           $internalField;
For nut:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
boundaryField
    INLET
        type            zeroGradient;
    OUTLET
        type            zeroGradient;
    WALL
       type            fixedValue;
       value           uniform 0;
The geometry I use is a straight tube of Ø5,3mm and a length of 10mm.
I just basically do not know how to correctly set k, omega and nut. I only want to map the outlet conditions to my inlet. For velocity I specify an average bulk velocity of 1m/s.
Kind regards,
Thijs
ashrufsyed and randolph like this.
thijs1909 is offline   Reply With Quote
Old   January 29, 2018, 11:20
Thijs
or should I use directMappedPatch instead of mapped?
Old   January 29, 2018, 11:37
gu1
Guilherme
gu1 is on a distinguished road
What version of OpenFOAM?
Put your 'boundary' file so we can analyze.
In fact, I did not understand why z = 0.1? Could you explain ?!
gu1 is offline   Reply With Quote
Old   January 29, 2018, 11:41
Thijs
Hi there,
What I mean with coordinate z is the offset I would like to map to my inlet. I use openFOAM 5.0 on bash ubuntu on windows.
My inlet plane is located at z = 0 and my outlet plane is located at z= 0.01
HTML Code:
|  \\    /   O peration     | Version:  5.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
3
    INLET
        type            mappedPatch;
        offset (0 0 0.01);
        sampleRegion region0;
        sampleMode nearestCell;
        samplePatch none;
        nFaces          1805;
        startFace       535895;
//neighbourPatch OUTLET;
//transform translational;
//separationVector (0 0 0.01);
    WALL
        type            wall;
        inGroups        1(wall);
        nFaces          7600;
        startFace       537700;
    OUTLET
        type            patch;
        nFaces          1805;
        startFace       545300;
//neighbourPatch INLET;
//separationVector (0 0 -0.01);
Old   January 29, 2018, 11:49
Thijs
I also found this old thread: simpleFoam + cyclic pipe = unstable?
But the proposed boundary conditions for 0/k 0/omega and 0/nut do not seem to work.
As I understand I start with an initial length of pipe. Then in the next time iteration the outlet is mapped to the inlet. For laminar the setup with 0/U and 0/p work while I find the hagen poiseuille velocity profile. My understanding is that in the next time iteration the k, omega and nut values should be mapped to my inlet, but how do I specify a value at the outlet I do not know how it will evolve?
Old   January 29, 2018, 13:50
Thijs
I believe directMapped is not available in openFoam 5.0, so I will stick to mapped
Old   January 30, 2018, 00:51
Yuncheng Xu (Cloud)
luther1990 is on a distinguished road
Here are some problems on your BCs
  1. too big omega at wall 1.3441e+7??????
  2. nut is set as calculated at inlet
  3. Fix above, and go back to cyclic or cyclicAMI.
  4. make sure All the variables except for nut are set as cyclic at inlet and outlet
If cyclic gives problems, so will mapped.
Hope it can help you
luther1990 is offline   Reply With Quote
Old   January 30, 2018, 04:36
Thijs
I tried cyclic with laminar and I find severe oscillations for my pressure.
For my nut value at the wall, I used this formula by Menter:
"Standard" Menter SST Two-Equation Model (SST)
https://turbmodels.larc.nasa.gov/sst.html
Omega_wall = 10 *( (6 *nu)/(B1 *yplus^2))
my viscosity nu = 1.0034e-06 m^2/s
B1 is a model constant = 0.075
I created a boundary layer with a y+ =~ 1 so my first cell height is 7,36e-06meter
Old   January 30, 2018, 04:43
Thijs
[IMG]<a href="https://ibb.co/b1hoW6"><img src="https://preview.ibb.co/iTEfdm/piso_no_conv.jpg" alt="piso_no_conv" border="0"></a>[/IMG]
Old   January 30, 2018, 08:15
Thijs
Apparently the laminar case converge to the right solution even with the fluctuations in the pressure residual. The calculated dp/dx source term slowly converges to the analytic solution. The required analytic value for my case is: 0.2286 and I found 0.231091 after 1.024 seconds, but I suspect it will converge better to the analytic value with a finer mesh or a longer runtime, so that is what I will try now.
Old   February 5, 2018, 09:28
Thijs
pisoFoam for the laminar case converges to the correct pressure gradient for a pipe of Ø5,3mm using cyclic bc's. However when I turn on RANS kOmegaSST I get a velocity profile which has the correct shape, but maybe the wrong max. velocity, and I do not get a correct pressure gradient. I can calculated the pressure gradient with the moody diagram and the correct is: dp/dx=3.5 If I read the moody-diagram for a Re=5282 the friction coefficient Fd should be approx. 0.037. This is also the friction coefficient is used in my calculation of the first layer height, using the blasius fanning coefficient : f= 0.0791/(Re^0.25) and Fd = 4*f
My dp/dx is 4.37 which differs too much.
So I expect my boundary conditions for the turbulence are not correct. I use a lowRe with a y+ = 1.
k
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
boundaryField
    INLET
        type             cyclicAMI;
    OUTLET
        type            cyclicAMI;
    WALL
        type            fixedValue;
        value           uniform 0;
omega
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    object      omega;
boundaryField
    INLET
       type             cyclicAMI;
    WALL
        type            fixedValue;
    OUTLET
        type           cyclicAMI;
nut
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
boundaryField
    INLET
        type            cyclicAMI;
    OUTLET
        type            cyclicAMI;
    WALL
       type            fixedValue;
       value           uniform 0;
p
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    INLET
        type            cyclicAMI;
    WALL
        type            zeroGradient;
    OUTLET
        type            cyclicAMI;
U
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    INLET
        type            cyclicAMI;
    WALL
        type            fixedValue;
    OUTLET
        type            cyclicAMI;
I also tried using a lowRe wallfunction for nut --> nutLowReWallFunction but I did not give a better result. The dp/dx remained 4.37
The pressure gradient according to moody can be calculated as:
delta P = Fd*{(rho*Vavg^2*L)/(2*D)} such that the pressure gradient is calculated as: deltaP/(rho*L) =dp/dx= (Fd *Vavg^2 )/ (2*D)
Does someone has a better suggestion? I found this validation case online: https://www.simscale.com/docs/conten...tPipeFlow.html but could not figure out how they set the boundary condition for nut
Old   February 5, 2018, 10:22
Thijs
Could aspect ratio be the problem. I have a y+ = 1 so my first cell layer height is 7,36e-6meter. My spacing in axial direction (z-direction) is 1e-4. But then again why I do checkMesh, openFoam tells everything is OK!
HTML Code:
Build  : 5.x-197d9d3bf20a
Exec   : checkMesh
Date   : Feb 05 2018
Time   : 15:22:03
Host   : "LAPTOP-38GBMABK"
PID    : 5239
I/O    : uncollated
Case   : /mnt/c/Users/thijs/Documents/openFoam_cases/restart/struct_piso/turb/tsu6_res/piso_struct_lvl_1_cyclicAMI
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            547105
    internal faces:   535895
    cells:            180500
    faces per cell:   6
    boundary patches: 3
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     180500
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    INLET               1805     1844     ok (non-closed singly connected)
    WALL                7600     7676     ok (non-closed singly connected)
    OUTLET              1805     1844     ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-0.00265 -0.00265 0.01) (0.00265 0.00265001 0.02)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (1.45266e-17 -4.96472e-17 2.58155e-16) OK.
    Max cell openness = 7.75827e-16 OK.
    Max aspect ratio = 15.3833 OK.
    Minimum face area = 6.50758e-10. Maximum face area = 3.38236e-08.  Face area magnitudes OK.
    Min volume = 1.41389e-13. Max volume = 3.38236e-12.  Total volume = 2.20368e-07.  Cell volumes OK.
    Mesh non-orthogonality Max: 7.36316 average: 2.0249
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.358788 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Old   February 5, 2018, 13:04
Yuncheng Xu (Cloud)
Just a few suggestions. You need to use wall functions for k and omega too. They do matter. Don’t need to use lowRe for nut. Try spalding or normal wall function for nut. Y+ should be fine, but it will be better to put it in log law sublayer.
Old   February 6, 2018, 09:38
Thijs
I replaced my y+ = 1 mesh LowRe with a y+ =35 highRe mesh. And used the following wall functions:
k:
type kqRWallFunction;
value uniform 1e-12;
omega:
type omegaWallFunction;
value uniform 100;
nut:
type nutkWallFunction;
value uniform 0;
and my calculate dp/dx term by openFoam reduced to: 3.62 , which is way more close to the analytic solution of 3.5 from the moody diagram. However I observe the following problem for my velocity profile. I do not see noSlip condition at the wall. It says approx. 0,6m/s
Is this the consequence of using wallfunctions or am I doing something wrong?
Kind regards,
Thijs
Old   February 6, 2018, 11:18
Thijs
The velocity profile I obtaine :S
Old   February 6, 2018, 14:36
Yuncheng Xu (Cloud)
Hi Thijs,
I am not sure what caused the ‘no-slip’, but you may check the U value at wall boundary in the latest time directory. See if it is uniform fixed value of (0 0 0). In my experience and based on the codes, these wall functions won’t change velocity on the boundaries. It may be caused by interpolation issue in visualization. Why not try paraview to visualize?
Old   February 13, 2018, 04:13
Thijs
I have a question regarding grid refinement and the y+ value. Currently I am using a y+ =~ 1 and during grid refinement of h=sqrt(2) in all direction I am also refining y+ such that I get a smaller y+=~0.707 .
But is this the correct procedure in order to study mesh independence. While I observe that my dp/dx term grows with smaller y+ value. And when I was taking my y+ value constant during refinement (y+ =~1) I observed better mesh independence.
Kind regards,
Thijs
Old   February 21, 2018, 23:07
Yuncheng Xu (Cloud)
Kind regards,
Thijs
Basically, pressure gradient is due to wall shear stress, which is very sensitive to the first grid height or y+. So your observation makes sense to me.
If you do care about pressure gradient, y+ shall be a very important variable in the grid dependence analysis.
fully developed region in pipe akbar.mech FLUENT 2 August 30, 2016 04:08
3D pipe flow - Using UDF's to define fully developed turbulent flow on the inlet Taz-CFD CFD Freelancers 1 February 21, 2016 12:12
UDF for 3D turbulent fully developed flow howhs Fluent UDF and Scheme Programming 0 August 1, 2013 12:47
Fully Developed Flow at an Inlet Ed Mueller CFX 5 January 13, 2009 12:50
2D representation of pipe for fully developed flow Nathan FLUENT 3 November 22, 2008 11:01
