Help me !! radiation considering scattering
Like Tree1Likes
  • 1 Post By keitaro7_14
Old   January 4, 2018, 01:56
Exclamation Help me !! radiation considering scattering
Jung da yoon
kane is on a distinguished road
I want to know the wall heat flux of Enclosure case.
Internal medium is gray and scattering gas.
I have to consider a scattering model.
first, I add this code.
scatterModel  constantScatter;
constantScatterCoeffs
   sigma        sigma   [ 0 -1 0 0 0 0 0 ] 0.5;
   C            C       [ 0 0 0 0 0 0 0 ] 0;
But I think it was not effective.
What should I do additionally??
++++oh, Is is not possible to consider scattering in fvdom model????
kane is offline   Reply With Quote
Old   January 4, 2018, 13:53
Domenico Lahaye
dlahaye is on a distinguished road
What do you mean by "not effective"?
dlahaye is offline   Reply With Quote
Old   January 5, 2018, 05:46
Post
Jung da yoon
oh I'm sorry.
''NOT effective'' means that I added the code, but it did not work.
As a result, i could not deal with scattering in fvdom model.
Old   January 5, 2018, 08:00
Post
Jung da yoon
I'm really confused...
Is it not possible to deal with scattering in fvdom model??
Old   January 5, 2018, 11:23
Domenico Lahaye
I image that fvDOM implemented in OpenFoam does allow for scattering. Could you please be more descriptive than "not working". Do you obtain results that are incorrect or no results at all?
Old   January 6, 2018, 05:43
Post
Jung da yoon
thank you for commenting, dlahaye!!
I'm sorry for my abstract explanation.
First I made a solver that deal with only radiation heat transfer.
So I applied this solver in Enclosed case.
As a result, I gained wall heat fluxes such as qr,qin in Openfoam.
But, this time I want to get wall heat fluxes(qr,qin) using a radiation solver
added to scattering. I added below codes in Enclosed case- file(constant/radiationproperties) to deal with scattering.
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      radiationProperties;
radiation on;
radiationModel  fvDOM;
fvDOMCoeffs
    nPhi    10;         // azimuthal angles in PI/2 on X-Y.(from Y to X)
    nTheta  10;          // polar angles in PI (from Z to X-Y plane)
    convergence 1e-6;   // convergence criteria for radiation iteration
    maxIter 1000;         // maximum number of iterations
// Number of flow iterations per radiation iteration
solverFreq 1;
absorptionEmissionModel constantAbsorptionEmission;
constantAbsorptionEmissionCoeffs
   absorptivity    absorptivity    [ 0 -1 0 0 0 0 0 ]  1;
   emissivity      emissivity      [ 0 -1 0 0 0 0 0 ]  1;
   E               E               [ 1 -1 -3 0 0 0 0 ] 0;
But it was the same results(qin,qr) as no scattering.
I thought that i could only add scatterModel codes in radiationproperties to
deal with scattering. What should i do additionally??
I attached my solver and case file. Please check it out.
'Enclosescatter' is case file that deal with scattering.
'radiationFoam' is solver file.
Old   January 8, 2018, 02:30
Jung da yoon
Does anyone who have ever tried to run fvdom model case including scattering????
Old   May 3, 2018, 11:07
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Dear kane,
If you know how to use incident radition 'G' in the solver? Because I want to calculate the temperaute field by 'T=pow(fvDOM->G()/(4*sigma),0.25);'
Best regards,
Chengan
wangchengan2003 is offline   Reply With Quote
Old   June 8, 2021, 10:53
JuanMi
keitaro7_14 is on a distinguished road
If you analyze fvDOM.C, you can see that scatterModel is not considered (although scatterModel.H is loaded). However, in P1 model the variable scatter_ is used.
B_R_Khan likes this.
keitaro7_14 is offline   Reply With Quote
Old   August 16, 2023, 12:13
BISSAI NKAA
sante_junior is on a distinguished road
that's right
sante_junior is offline   Reply With Quote
chtMultiRegionSimpleFoam: Thermal Conduction + Surface-To-Surface Radiation Zeppo OpenFOAM Running, Solving & CFD 16 May 18, 2017 19:04
Materials Radiation properties: scattering and absorption coefficient monkaeydadde CFX 0 April 7, 2017 08:03
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
