Adding temperature dependent heat source using fvOptions in chtMultiRegionSimpleFoam
Like Tree17Likes
  • 1 Post By shaileshbg
  • 1 Post By TobiF
  • 14 Post By shaileshbg
  • 1 Post By BlnPhoenix
Old   December 19, 2017, 10:33
Default Adding temperature dependent heat source using fvOptions in chtMultiRegionSimpleFoam
Shailesh BG
shaileshbg is on a distinguished road
Hello Foamers,
I want to add a temperature dependent heat source into the chtMultiRegionSimpleFoam solver using fvOptions.
I was looking at semiImplicitSource option which works on source term linearization using SuSp injection rate treatment where:
S(x) = Su + Sp(x)
S(x): net source for field (x)
Su: explicit source contribution
Sp: linearized implicit contribution
I understand that the solver works by evaluating enthalpy (so my field is H) and that the unit of enthalpy is same as that of internal energy (J/Kg), so if I want to add a constant heat source I need not convert anything I can put it in directly under Su (taking absolute and specific into consideration), but I do not know how to add a temperature dependent source term of this form:
source = constant * (T - T_const)
Problem definition:
Heat conduction through four different solids each having its own temperature-dependent source.
Could anyone please help me to understand how to implement this.
Many thanks in advance,
Shailesh
shaileshbg is offline   Reply With Quote
Old   December 19, 2017, 14:50
TobiF is on a distinguished road
Hey,
use scalarCodedSource to calculate the temperature-depending heat-source.
If you need the mean-temp of the region you should define the selectionMode type cellZone and in the code something like :
const volScalarField& Tm = mesh_.lookupObject<volScalarField>("T");
Tvol = Tm.weightedAverage(mesh_.V()).value();                //averageValue of the volScalarField
to calculate the mean tmep of the cellZone.
After that you can use the Tvol - value for your calculation.
            const vectorField& C = mesh_.C();                    //List of cellcentres
            scalarField& hSource = eqn.source();                //defining source
            forAll (C, i)
                hSource = (Tvol - Tconst)*yourvalue;
Maybe you have to do some adjustments for your case.
Hope it helps...
TobiF is offline   Reply With Quote
Old   December 20, 2017, 06:24
Default From function virtual void Foam::fv::option::checkApplied() const
Shailesh BG
Hello Tobi,
Thank you very much for your reply, this is exactly what I wanted. But when I implement it I am getting an error
--> FOAM Warning :
    in file cfdTools/general/fvOptions/fvOption.C at line 125
    Source blood_perfusion_tumor defined for field T but never used
I have defined two heat sources in my fvOptions file:
1) constant q of 13600 W/m^3 (as a scalarSemiImplicit source)
2) temperature dependent heat source with T_const at 310K
Please find my fvOptions file below:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
metabolic_heat_generation_tumor
    type            scalarSemiImplicitSource;
    active          true;
    scalarSemiImplicitSourceCoeffs
        selectionMode   cellZone; // all, cellSet, cellZone, points
        cellZone         tumor;
        volumeMode      specific; // absolute;
        injectionRateSuSp
            h   (13600 0);
    type          scalarCodedSource;
    name    sourceTime;
    active          true;
    scalarCodedSourceCoeffs
        fields      (T);
        cellZone        tumor;
        codeInclude
        codeCorrect
            Pout<< "**codeCorrect**" << endl;
        codeAddSup
            const Time& time = mesh().time();
            forAll(C, i)
                hSource[i] = (Tvol - 310)* 48000;
            Pout << "***codeAddSup***" << endl;
        codeSetValue
            Pout<< "**codeSetValue**" << endl;
        // Dummy entry. Make dependent on above to trigger recompilation
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
        // Dummy entry
In order to monitor temperature, I have added this to my controlDict:
functions
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        writeControl   timeStep;
        writeInterval  1;
        probeLocations
            ( 0 0.0495 0)
            ( 0 0.0595 0 )
            ( 0 0.0395 0)
            (0 0.022 0)
            (0 0.067 0 )
            (0 0.072 0)
        fields
            T
I have also attached my checkMesh log for your reference. Could you please let me know if I have implemented the coded source properly.
Thank you in advance
Shailesh
raj kumar saini likes this.
Old   December 21, 2017, 03:14
Can you please tell me, how you set up your case?
multiRegion via topoSet or via multiple stl-files?
Usually (thats how I set up my cases - doesn't have to be the best way, but is working for me) you write a single fvOptions for each region where you define the code for the single region.
Tobi
Tobi likes this.
Old   December 21, 2017, 04:40
Default multiRegion via topoSet
Shailesh BG
Hello Tobi,
Thank you for your reply. I have created multiregion with toposet and defined a fvOptions file separately for each region.
Problem detail: My problem has four solid hemispherical regions (muscle, gland, tissue, tumor), these are the steps that I have followed:
1) Use snappyHexMesh with searchable sphere option to define the hemispherical regions for each solid separately (as I required different mesh concentrations in each region)
2) Use merge and stitch meshes to join each meshed region into one whole meshed domain.
3) Use toposet to create different cellZones.
4) Split mesh regions based on these cellZones.
5) Define initial and boundary conditions for each cellZone use changeDictionary.
Please find a dropbox link with the case file along with a run and clean script.
https://www.dropbox.com/s/5c1hwvaoka...nFoam.zip?dl=0
Thank you very much for your time.
Shailesh
Old   January 5, 2018, 02:20
Default source term added
Shailesh BG
Hello Foamers,
Thanks to Tobi we have managed to add the temperature-dependent heat source as required. Below is the snippet of the fvOptions file for anyone who might face this trouble in future.
blood_perfusion_gland
    active          true;
    name    sourceTime;
         cellZone        gland;
	 fields      (h);
        codeInclude
        codeCorrect
        codeAddSup
	     scalar Tvol = 0;
            //const Time& time = mesh().time();
	    const scalarField& V = mesh_.V();
            forAll(C, i)
                hSource[i] = (Tvol - 310)*2400*V[i] ;
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
    sourceTimeCoeffs
         $scalarCodedSourceCoeffs;
Regards,
Shailesh
TobiF, blttkgl, aadil and 11 others like this.
Old   March 22, 2018, 03:20
SomeUser is on a distinguished road
Hi, I'm working on the similar case.
But I noticed that the scalarCodedCase is always working on the whole domain and not only in cellSet or cellZone.
Did your scalarCodedSource work only in the zone you specified of in the whole domain?
Thanks
SomeUser is offline   Reply With Quote
Old   March 22, 2018, 05:40
If you choose selectionMode cellZone, like in the code stated below the codedSource should only work for this cellZone
(and the fvOptions-file is in the ./system/yourZoneName/ - directory)
         cellZone               yourZoneName;
	         fields                    (h);
And for your next post, please give some more information. of - Version, case-setup, whatyou want to do, etc.
regards Tobi
Old   March 22, 2018, 10:14
Thanks Tobi, I already tried that. Although I don't understand what you mean by fvOptions should be in the ..., if I create the directory like that and put fvOptions inside than fvOptions doesn't work at all.
Btw I create cellZone from cellSet with commant setsToZones.
The Goal:
I'm using OF 3.0 the solver is reactingMultiphaseEulerFoam, I have 4 phases (one has volume fraction of 0, so is "dormant").
I'm not trying to change the temperature but the volume fraction of one phase to another.
Like the volumetric fraction of phase1 (perfectFluid in thermophysical properties) is reducing while for the phase2 (also perfectFluid) the volumetric fraction is increasing.
Case is quasi 2D (square pipe with only one cell in y), gravity is 0.
So I want to have the change in only one half of the pipe.
|  \\    /   O peration     | Version:  3.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
options
    massSource1
		active			false;
		cellZone			zone1;
        fieldNames      (thermo:rho.phase2);
		redirectType	scalarCodedSource;
        name    sourceTime;
        codeInclude
        codeCorrect
        codeAddSup
            const Time& time1 = mesh().time();
            const scalarField& V1 = mesh_.V();
			const volScalarField& Am1 = mesh_.lookupObject<volScalarField>("alpha.air");
			const volVectorField& Ui1 = mesh_.lookupObject<volVectorField>("U.air");
            scalarField& deltaPhase2 = eqn.source();
            deltaPhase2 -= V1*mag(Am1)*mag(Ui1);
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
	massSource2
		active			true;
		cellZone			zone1;
        fieldNames      (thermo:rho.phase1);
        name    sourceTime2;
        codeInclude
        codeCorrect
        codeAddSup
            const Time& time2 = mesh().time();
            const scalarField& V2 = mesh_.V();
			const volScalarField& Am2 = mesh_.lookupObject<volScalarField>("alpha.air");
			const volVectorField& Ui2 = mesh_.lookupObject<volVectorField>("U.air");
            scalarField& deltaPhase1 = eqn.source();
            deltaPhase1 -= -V2*mag(Am2)*mag(Ui2);
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
And I have an additional question. For quite some time, I'm searching for the equation thermo:rho.phase1 (probably the true name is thermo:rho()) in my solver and up to date I couldn't find it. Could you also help me with that?
Thanks in advance and best regards
SomeUser
Last edited by SomeUser; March 23, 2018 at 04:55. Reason: Corrected spelling errors
Old   August 13, 2019, 05:15
BlnPhoenix is on a distinguished road
The Goal:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
options
    massSource1
		active			false;
		cellZone			zone1;
        name    sourceTime;
        codeInclude
        codeCorrect
        codeAddSup
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
	massSource2
		active			true;
		cellZone			zone1;
        name    sourceTime2;
        codeInclude
        codeCorrect
        codeAddSup
        codeSetValue
        code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeSetValue
SomeUser
Hi!
I'm trying to do the same as you. Mass transfer from one phase to another in reactingMultiphaseEulerFoam. Have you managed to do so?
Maybe we can figure this out together..
BlnPhoenix is offline   Reply With Quote
Old   November 3, 2019, 10:47
Default Be very carefull...
  #11
Michael Roth
roth is on a distinguished road
@SomeUser, you are correct. If you are not careful it will apply the source to the entire domain. There is discussion and work-around here:
https://bugs.openfoam.org/view.php?id=2361
I'm copying the example given by @MattijsJ:
    energySource
        active     true;
        name       sourceTime;
            selectionMode   points;
            points (
                   ( 2.0  2.0 2.0)
//        selectionMode   all;
//        selectionMode   cellZone;
//        cellZone        heater;
            fields          (h);
            codeInclude
            codeCorrect
            codeAddSup
                scalarField& heSource = eqn.source();
                const labelList& cellIDs = cells();
                forAll(cellIDs, i)
                    label cellI = cellIDs[i];
                    heSource[cellI] -= 0.0001*sqr(time.value())*V[cellI];
            codeSetValue
            code
                $codeInclude
                $codeCorrect
                $codeAddSup
                $codeSetValue
        sourceTimeCoeffs
roth is offline   Reply With Quote
Old   December 30, 2020, 17:06
julien
julieng is on a distinguished road
Is it possible to add an heat source on a boundary (using facezone or patch name) ?
I want to add on the interface solid-fluid the heat flux:
qr=emi x cst_boltz x (T(boundary temp)^4 - Tcst^4)
Best regards
Julien
julieng is offline   Reply With Quote
Old   March 18, 2021, 14:33
Default Questions on heat flux model
  #13
sw choi
choist31 is on a distinguished road
Dear Mr. Julieng
I am woking on the similar job. I wonder if you have any resolution on your approch. It would be great if you can share your experience with me.
Thanks for any help in advance.
Best wishes,
Sung
choist31 is offline   Reply With Quote
Old   January 2, 2023, 13:57
Default Heat source with temperature dependent without scalarCodedSourceCoeffs
  #14
État
Sully is on a distinguished road
Dear all,
I would like to know if it is possible to set heat source with temperature dependency (in fvOptions or not) but by avoiding the use of scalarCodedSourceCoeffs ? Coded part does not work in my case.
Thank you,
Sully is offline   Reply With Quote
Old   January 26, 2024, 19:48
Default fvOptions in OF4.x
  #15
Jose
jose.ceballos is on a distinguished road
Can i use fvOptions in OpenFOAM 4.x? I want to add source terms to the energy equation of a PEM fuel cell.
jose.ceballos is offline   Reply With Quote
chtmultiregionsimplefoam, enthalpy equation, fvoptions, heat source term, temperature dependent
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Transient spacial dependent heat source Kumudu OpenFOAM Running, Solving & CFD 0 October 28, 2013 12:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
