Thermal properties
Like Tree4Likes
  • 4 Post By Bloerb
Old   December 8, 2017, 01:26
Default Thermal properties
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Dear Foamers,
I have to simulation the conditions of chemical reactions at a boundary layer (electrochemical deposits). One aspect of this is the mass transport to the boundary. Because this is not ready available in OpenFoam I used the temperature instead of the concentration. The equations are equal.
Doing this I have to give the thermal properties. I don't know the real values for my galvanic bath, so I started with the values of water. For reference I give my thermophysicalProperties file at the end of the post.
Unfortunately, this is only weak documented in the OF literature. I found out everything except "Hf", which I set to zero (as in examples I found). I switched it to 1000, but nothing happens (at least in my incompressible case with noc changes of the density).
Does anybody know what is this value for? Thank you in advance.
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        nMoles          1; // not used, only necessary for gases
        molWeight       18; // ditto
    equationOfState // rho(T)
	// density
        rho             1000;
    thermodynamics
	// heat capacity
        Cp              4181;
        Hf              0;
    transport
	// dynamic  viscosity
        mu              959e-6;
	// Prandtl number: 13,44 (0 °C); 11,16 (5 °C); 6,99 (20 °C); 4,34 (40 °C); 3,00 (60 °C); 2,20 (80 °C); 1,75 (100 °C)
        Pr              6.62;
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   December 8, 2017, 03:09
TobiF is on a distinguished road
Hey,
as you can see in the link below (chapter 7.1.3) Hf is the heat of fusion
https://cfd.direct/openfoam/user-guide/thermophysical/
TobiF is offline   Reply With Quote
Old   December 8, 2017, 04:49
piu58's Avatar
Uwe Pilz
Thank you! Now it is clear that I don't need it.
Uwe Pilz
Old   December 8, 2017, 04:52
Bloerb will become famous soon enough
Hf is the heat of fusion. It is however not used if sensibleEnthalpy or sensibleInternalEnergy is specified. This quantity only applies to totalEnthalpy etc. For example evaporation or combustion, melting and solidification need a heat of fusion. The same applies to nMoles and moleWeight. Those are only used if something beside a pureMixture is looked at. Like a mixture of two different gases. Nevertheless a value must be present. Which value is choosen does not affect your simulation results since it is not used to calculate any quantity.
Bloerb is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
IAPWS water properties + orthotropic thermal conductivity Chander CFX 1 February 29, 2012 18:26
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
