How Phase change with reactingTwoEulerFoam/reactingMultiphaseEulerFoam works?
Like Tree5Likes
  • 3 Post By Mr.Turbulence
  • 1 Post By Michaelfoam
  • 1 Post By sjohn2
Old   December 5, 2017, 11:32
Default How Phase change with reactingTwoEulerFoam/reactingMultiphaseEulerFoam works?
Mr.Turbulence is on a distinguished road
Dear All,
I am currently trying to model phase change (condensation and evaporation) with reactingTwoPhaseEulerFoam and reactingMultiphaseEulerFoam in OpenFoam 5.0.
I would like to know why in the tutorial multiphase/reactingTwoPhaseEulerFoam/laminar/bubbleColumnEvaporatingDissolving/ the Hf values are set to -1.3435e+07 and -1.5879e+07 for vapor and liquid water
and how the phase change model is working ?
It is explained in the User guide that Hf is suppose to be the heat of fusion and then i don't understand why these values are so high and negative (as the Heat of fusion of the water is 333 000 J/Kg and the Heat of vaporization is 2 257 000 J/Kg).
As far as i understand looking into the code (InterfaceCompositionPhaseChangePhaseSystem.C) , the model is trying to :
  • Compute the temperature T_f at the interface of 2 phases thanks to the formula Q(T_f) = \dot{m}(T_f) L(T_f) through a newton algorithm.
  • Compute the saturation pressure and then the mass fraction thanks to the the T_f
To do so the program should compute L(T_f) which is done in Foam::InterfaceCompositionModel<Thermo, OtherThermo>::L with :
    forAll(p, celli)
        L[celli] =
            localThermo.Ha(p[celli], Tf[celli])
          - otherLocalThermo.Ha(otherP[celli], Tf[celli]);
As i am using thermo -> hconst, the localThermo.Ha term should be determined by Foam::hConstThermo<EquationOfState>::Ha which returns :
   return Cp_*T + Hf_ + EquationOfState::H(p, T);
Then as my equations of state used are perfectFluid and perfectGas i understand that L = (Cp * Tf + Hf)_{gas} -  (Cp * Tf + Hf)_{fluid}
Then i understand that (Hf)_{gas} -  (Hf)_{fluid} = 2.444e^6 \approx L_v in my case but i still don't understand these values.
Moreover i don't understand, if it is an energy balance done on the interface, why the equation use Cp * T_f instead of Cp * \Delta T.
I have as well looked in the tutorial bubbleColumnEvaporating where the thermo model is set to janaf (although it is not the model that i want to use) but once again i don't understand why the coefficient h for the H2O gas is set to :
h_{high} = -30004.3
h_{low} = -30293.7
I should model the injection of water inside a hot gas. As a first step i tried to validate the condensation and evaporation. I would like to understand how the model is really working and if what i understood so far is correct.
Thanks a lot in advance!
Chad
Kummi, nikitin-pro and Lang like this.
Mr.Turbulence is offline   Reply With Quote
Old   December 2, 2019, 19:01
Stanley John
sjohn2 is on a distinguished road
Did you figure of out things? I am trying to model phase change of water because of a pressure drop. So I understand I have to use the theinterfaceCompositionPhaseChangeTwoPhaseSystem
I am having trouble defining the thermophysical properties of water and steam
I do not understand the definition of these files in bubbleColumnEvaporating tutorial. How would do the same for water phase change:
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
location    "constant";
object      thermophysicalProperties.gas;
thermoType
type            heRhoThermo;
mixture         multiComponentMixture;
transport       sutherland;
thermo          janaf;
equationOfState perfectGas;
specie          specie;
energy          sensibleInternalEnergy;
inertSpecie air;
species
air
    H2O
H2O
specie
molWeight       18.0153;
thermodynamics
Tlow            200;
Thigh           3500;
Tcommon         1000;
highCpCoeffs    3.03399 0.00217692 -1.64073e-07 -9.7042e-11 1.68201e-14 -30004.3 4.96677 );
lowCpCoeffs     4.19864 -0.00203643 6.5204e-06 -5.48797e-09 1.77198e-12 -30293.7 -0.849032 );
transport
        As
1.67212e-06;
Ts              170.672;
air
specie
molWeight       28.9596;
thermodynamics
Tlow            200;
Thigh           3500;
Tcommon         1000;
highCpCoeffs    3.57304 -7.24383e-04 1.67022e-06 -1.26501e-10 -4.20580e-13 -1047.41 3.12431 );
lowCpCoeffs     3.09589 1.22835e-03 -4.14267e-07 6.56910e-11 -3.87021e-15 -983.191 5.34161 );
transport
        As
1.67212e-06;
Ts              170.672;
PHP Code:
     \\/     M anipulation  |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      thermophysicalProperties.liquid;
thermoType
type            heRhoThermo;
mixture         pureMixture;
transport       const;
thermo          hConst;
equationOfState perfectFluid;
specie          specie;
species
air
    H2O
inertSpecie H2O;
"(mixture|H2O)"
specie
molWeight       18.0153;
equationOfState
R           3000;
rho0        1027;
thermodynamics
Hf          -1.5879e+07;
Cp          4195;
transport
mu          3.645e-4;
Pr          2.289;
air
specie
molWeight   28.9;
equationOfState
R           3000;
rho0        1027;
thermodynamics
Hf          0;
Cp          4195;
transport
mu          3.645e-4;
Pr          2.289;
sjohn2 is offline   Reply With Quote
Old   July 3, 2020, 10:39
Default Evaporation
Michael
Michaelfoam is on a distinguished road
Hi Mr. Turbulence
Did you manage to get an answer to your question ?
I am trying to simulate water evaporation
If I set the Hf value to zero for my gas phase I receive the same results compared to an experiment.
The User guide says that Hf is the heat of fusion but the Code says that it is the heat of formation. I am confused.
Michaelfoam is offline   Reply With Quote
Old   July 6, 2020, 04:14
Hi Michaelfoam,
I moved on some other project and didn't went further these questions but this activity is coming back and i still didn't figure it out. I guess, looking at the equations into the code that these value shoumld be the Heat of fusion of the water (333 000 J/Kg) and the Heat of vaporization (2 257 000 J/Kg).
In the tutorial multiphase/reactingTwoPhaseEulerFoam/laminar/bubbleColumnEvaporatingDissolving/ the Hf values are set to -1.3435e+07 and -1.5879e+07 for vapor and liquid water which is quite strange number to set but the difference of H is almost the same (2e6).
Could you share the validation you made setting Hf = 0?
Old   July 23, 2020, 16:37
Michael
Hi Mr.Turbulence,
Sorry for my late answer.
I will evaluate my Work in a few weeks after that I can share it.
Does anybody know how Ha is calculated if I use eConst instead of hConst?
Mr.Turbulence likes this.
Old   April 29, 2021, 05:04
JungHoon Lee
ssitank is on a distinguished road
Hello Mr. Turbulence and Michaelfoam,
sorry that it is pretty old post but I am currently doing my work in evaporation simulation using reactingTwophaseEulerFoam as you guys did.
And I am facing the same problem with Hf value. Since it seems really wierd to me as well.
Could you please share any ideas you have?
ssitank is offline   Reply With Quote
Old   April 29, 2021, 05:09
Stanley John
The latent heat has to be specified through Hf to get correct mass transfer.
The latent heat in the code is eventually computed through difference in enthalpies.
PHP Code:
/*--------------------------------*- C++ -*--------- Reciprocal polynomial-------------------------*\
     \\/     M anipulation  |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
thermoType
type            heRhoThermo;
transport       const;
thermo          eConst;
equationOfState rPolynomial;
specie          specie;
//species (   water);
mixture
specie
molWeight       18.0153;
equationOfState
//      rho 920;
(0.001278 -2.1055e-06 3.9689e-09 4.3772e-13 -2.0225e-16); // need to find a better fit off by 10 kg/m^3
thermodynamics
Cv          3526;
Hf           -1.5658e+07;
transport
mu          0.1839239e-3;
Pr          1.178;
PHP Code:
    \\  /    A nd           | Version:  dev
     \\/     M anipulation  |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
thermoType
type            heRhoThermo;
mixture         pureMixture;//multiComponentMixture;
thermo          eConst;
specie          specie;
mixture
specie
molWeight       18.0153;
thermodynamics
Cv          1701;
Hf          -1.3145e+07;
transport
        As
1.67212e-06;
Ts              170.672;
Old   April 29, 2021, 06:30
JungHoon Lee
Hi sjohn2,
thank you for the reply.
I am still confused since as Mr. Turbulence said the values are seemed wierd.
And why does it have different values for H2O in liquid and H2O in gas.
I mean these values are niether for the heat of fusion nor the heat of vaporization of H2O.
I am guessing that if they are refering to same value i.e. the latent heat of vaporization, they should have same value and maybe in different sign.
Also sign of the values are still confusing. Why do they have same negative sign?
I appreciate any comments!
Thanks!
Old   April 30, 2021, 23:11
Stanley John
Originally Posted by ssitank View Post
Hi sjohn2,
Thanks!
Heat of formation for water and steam are different. Latent heat can be obtained as a difference between the two. Check out Thermodynamics by Cengel and Latent heat can also be found as as a difference between the enthalpies of water and steam based on the thermophysical models one has specified.
For heat of formation calculation check:
http://www.tfd.chalmers.se/~hani/kur...t_CAPPELLI.pdf
granzer likes this.
Old   November 13, 2024, 13:44
Robert Castilla
rcastilla is on a distinguished road
it is a quite old thread, but I think I can make a small contribution.
This Hf defined in thermoPhysicalProperties is not the latent heat of condensation/evaporation. It is the heat of formation. It is quite larger than the first. The latent heat seems to be computed by tha code from the other thermodynamic properties as Mr. Turbulence pointed out in the fist post.
Am I right?
Greetings
Robert
rcastilla is offline   Reply With Quote
enthalpy of fusion, enthalpy of vaporization, openfoam 5.0, phase change, reactingtwoeulerfoam
Multiphase solvers and non-isothermal phase change erlend_grotle OpenFOAM 1 September 25, 2021 10:48
Need help regarding phase change models in ansys fluent diggee Fluent Multiphase 0 October 11, 2016 12:35
use mixture model to simulate two-phase flow with phase change dxm2008 Fluent Multiphase 5 September 7, 2016 15:15
Change phase phenomena Imane FLUENT 0 May 4, 2016 16:56
Refrigerant R134a Phase Change Mahesh Bondhu FLUENT 4 May 4, 2013 09:13
