Rep Power: 9 ![]() |
Hello FOAMers!
I am working on a shock-wave case and I'd like to use the rhoCentralFoam solver. I understand that this solver is transient but my question is: Can it be used in LES or in URANS? Where can I find more info? Thank you in advance! |
Oğuzhan Demir
Dear Calmly,
You can use rhoCentralFoam for LES or DES simulations. You do not need to do any changes for the solver but you have to change your turbulenceProperties file in order to make a LES analysis. Oguz |
madz
Rep Power: 7 ![]() |
In OF V5.x can k-omega SST DES be implemented with no changes except in the turbulence properties file?
#5 | |
Fatih Ertinaz
Rep Power: 15 ![]() |
Hello maddy11
[ertinaz@supernova OpenFOAM-5.x]$ find . -iname "*kOmega*" -type d Code:
./src/TurbulenceModels/phaseCompressible/RAS/kOmegaSSTSato ./src/TurbulenceModels/turbulenceModels/LES/kOmegaSSTDES ./src/TurbulenceModels/turbulenceModels/Base/kOmegaSST ./src/TurbulenceModels/turbulenceModels/RAS/kOmegaSSTLM ./src/TurbulenceModels/turbulenceModels/RAS/kOmega ./src/TurbulenceModels/turbulenceModels/RAS/kOmegaSSTSAS ./src/TurbulenceModels/turbulenceModels/RAS/kOmegaSST Code:
[ertinaz@supernova tutorials]$ grep -rn "kOmegaSSTDES" * Code:
incompressible/pisoFoam/LES/motorBike/lesFiles/turbulenceProperties:22: LESModel SpalartAllmarasDDES; Code:
[ertinaz@supernova OpenFOAM-5.x]$ ls -l ./src/TurbulenceModels/turbulenceModels/LES/LESdeltas/ total 28 drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 cubeRootVolDelta drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 IDDESDelta drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 LESdelta drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 maxDeltaxyz drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 PrandtlDelta drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 smoothDelta drwxrwxr-x. 2 ertinaz ertinaz 4096 Jan 19 2018 vanDriestDelta // Fatih |
madz
Thanks a ton Fatih! Was very helpful.
![]() Have u implemented DES model in Openfoam? |
rhocentralfoam |
[Other] OpenFOAM Installation for navalFoam | sachinlb | OpenFOAM Community Contributions | 22 | July 28, 2017 05:26 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Can't get data from OpenFoam to external solver using externalCoupled | perry | OpenFOAM Running, Solving & CFD | 4 | May 26, 2014 08:09 |
rhoCentralFoam solver for simulating airfoil in high altitude | sani | OpenFOAM | 0 | September 27, 2012 11:22 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
