November 17, 2017, 15:50 |
Error using totalPressure in p_rgh
Sugajen
Rep Power: 14 |
Hi all,
I am trying to run a pressure driven flow simulation using reactingTwoPhaseEulerFoam. I get an error when I specify totalPressure in inlet p_rgh. Code:
--> FOAM FATAL ERROR: request for volVectorField U from objectRegistry region0 failed available objects of type volVectorField are 6 ( U.particles_0 DUDt.particles U.air U.air_0 U.particles DUDt.air ) From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>] in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? #3 Foam::totalPressureFvPatchScalarField::updateCoeffs() at ??:? #4 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/reactingTwoPhaseEulerFoam" #5 Foam::fv::EulerDdtScheme<double>::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::ddt<double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/reactingTwoPhaseEulerFoam" #7 ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/reactingTwoPhaseEulerFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/reactingTwoPhaseEulerFoam" Aborted (core dumped) When I used the totalPressuere in inlet P instead of p_rgh, I get reasonable values, but that is not the right way to do, right ? I searched the forum for relevant threads, but none touched this explicitly, and hence the post. I am attaching my p, p_rgh and U files below. P: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1.04e5; boundaryField { inlet { type calculated; value $internalField; } outlet { type calculated; value $internalField; } top { type calculated; value $internalField; } bottom { type calculated; value $internalField; } walls { type calculated; value $internalField; } frontAndBack { type empty; } Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1.04e5; boundaryField { inlet { type totalPressure; p0 $internalField; value $internalField; } outlet { type prghPressure; p uniform 0; } top { type fixedFluxPressure; value $internalField; } bottom { type fixedFluxPressure; value $internalField; } walls { type fixedFluxPressure; value $internalField; } frontAndBack { type empty; } } Code:
FoamFile { version 2.0; format binary; class volVectorField; location "0"; object U.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.0 0.0 0.0); boundaryField { inlet { type fixedValue; value $internalField; } outlet { type fixedValue; value $internalField; } top { type noSlip; } bottom { type noSlip; } walls { type noSlip; } frontAndBack { type empty; } } Thanks in advance Sugajen |
November 18, 2017, 17:09 |
Refer to the source code for boundary specification
Jaydeep
Rep Power: 11 |
Your error is pretty self explanatory. You can look for the boundary definition here:
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H You will find that the boundary does calculation along the lines of: Code:
p_p = p_0 - 0.5 |U|^2 So it needs "U" field. In your case, you will need to explicitly feed U field for species. The definition is given in the same source file: Code:
Usage Property | Description | Required | Default value U | Velocity field name | no | U phi | Flux field name | no | phi rho | Density field name | no | rho psi | Compressibility field name | no | none gamma | (Cp/Cv) | no | 1 p0 | Total pressure | yes | |
November 21, 2019, 20:02 |
Pressure driven flow in nozzle
Stanley John
Rep Power: 8 |
I have the same problem. I want to specify total pressure in the inlet and static pressure in the outlet using the same solver reactingtwophaseeulerFoam. Does any one have an example? |
totalPressure (why flux direction dependend) | Tobi | OpenFOAM Running, Solving & CFD | 3 | October 17, 2019 23:27 |
Need info about totalPressure boundary condition | sahmed | OpenFOAM Running, Solving & CFD | 4 | December 4, 2018 22:23 |
About the totalPressure BC | fmerk | OpenFOAM Running, Solving & CFD | 1 | September 25, 2017 18:53 |
totalPressure boundary :Performance Curve (constant RPM) | nash | OpenFOAM Running, Solving & CFD | 0 | September 6, 2013 12:34 |
Totalpressure Ansys | Leuchte | CFX | 2 | April 9, 2013 19:56 |
