InterFoam parallel running for 48 hours without producing time folders!
Like Tree1Likes
  • 1 Post By piu58
Old   November 7, 2017, 23:05
Default InterFoam parallel running for 48 hours without producing time folders!
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
Hi All:-
I have a successful run of a two-phase flow case study by using interFoam solver(parallel running with 64 processors for 48 hours). However, The solver could not produce any time step solution despite the solution run smoothly as you can see from the file (the link below).
Any idea?
Thanks!
https://drive.google.com/file/d/1GwR...ew?usp=sharing
alinuman15 is offline   Reply With Quote
Old   November 8, 2017, 01:23
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
My recommendations:
- Simplify your model for testing it. Use less nodes.
- Make the writeInterval much shorter, to see if anything happens. Best you write at every step first
- Start with one processor. The course of the program can be followed much easier with only one processor.
alinuman15 likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   November 8, 2017, 08:04
Ali Noaman Ibrahim
Originally Posted by piu58 View Post
My recommendations:
- Simplify your model for testing it. Use fewer nodes.
1. How can I decrease the nodes and make sure that the model still able to capture the physical phenomenon? Now, I set the model with a number of cells more than eight million and not sure if it is enough for recognizing the capillary forces.
- Make the writeInterval much shorter, to see if anything happens. Best you write at every step first [/QUOTE]
2. My time step is too small and that will be reflected on the required memory after reconstruction. How can I avoid the expected aggravated required memory size?
- Start with one processor. The course of the program can be followed much easier with only one processor.[/QUOTE]
3- Based on 1 and 2, do you think I still can follow up with one processor?
Thank you so much for replying!
Old   November 8, 2017, 08:43
Ali Noaman Ibrahim
Dear Uwe:-
Update:-
I have time step ( 1e-6) and after your suggestion, I have changed the writeInterval from 0.0004 to 0.000009. After running the case, the solver just extracted the time step 0.0004 and stopped and reported following report:-
Create time
Create mesh for time = 0.000439557937677
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
MPI_ABORT was invoked on rank 4 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Now, I decreased the writeInterval even more (0.000005) and gave it another run. Waiting for results. But, still, need your feedback regarding the previous post.
Thanks again!
Old   November 9, 2017, 02:17
piu58's Avatar
Uwe Pilz
It is not necessary that the rougher geometry covers all phenomena in high accuracy. This approach should contain, however, all elements that the high-resolution has in it.
The main purpose of this simplified model is to check the calculation process and to find mistakes in modelling.
Uwe Pilz
Old   November 9, 2017, 17:12
JPeternel
jpeter3 is on a distinguished road
It looks like your case was terminated by an error in MPI mistery box that is supposed to run parallel cases. MPI does have nothing to do with cases it only provides a framework for parallel operations. That suggests that your problem is not in the openfoam case settings and solver but rather in the system you are running your case on. (just guessing though)
jpeter3 is offline   Reply With Quote
Old   November 9, 2017, 18:13
Ali Noaman Ibrahim
As I tried it out:
It is an OpenFOAM setting issue since I tried it on my personal computer with parallel run => it produced the same thing. However, when I changed the write interval as Uwe suggested with the parallel run on supercomputer , it made a difference!
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
what is Execution(/CPU) time when running parallel jobs? Malthe Eisum OpenFOAM Post-Processing 1 May 11, 2016 03:05
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
interDyMFoam in parallel idefix OpenFOAM Running, Solving & CFD 0 May 21, 2013 03:34
