Unphysical phase volume fraction in FoamExtend3.1 using interDyMFoam
Like Tree2Likes
  • 2 Post By hjasak
Old   October 17, 2017, 11:29
Default Unphysical phase volume fraction in FoamExtend3.1 using interDyMFoam
smog1988
OF24x is on a distinguished road
I have a layer A/R case where a cylinder sees two patches (along Z) add and remove layers while oscillating the enclosed cellZone. The case is run in parallel Hierarchical (4 4 1) xyz decomposition. The case runs fine in laminar mode. But as soon as I turn turbulence "on", it breaks down giving unphysical Alpha1 (liquid phase volume fraction) accompanied by increase in velocity. Here are a few other details:
--> CFL = 0.4
--> write in binary
--> time precision = 6
--> write precision = 6
fvSchemes:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
div(rho*phi,U) Gauss vanLeerV;
div(phi,alpha) Gauss vanLeer;
div(phirb,alpha) Gauss vanLeer;//interfaceCompression;
div(phi,k) Gauss upwind;//limitedLinear 1;
fvSolution:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.1 |
| \\ / A nd | Web: http://www.extend-project.de |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
pcorr
solver PCG;
preconditioner DIC;
minIter 0;
maxIter 1000;
tolerance 1e-15;//1e-8, was initially 1e-2
relTol 0;
pd
solver PCG;
preconditioner DIC;
minIter 1;
maxIter 1000;
tolerance 1e-08;//was 1e-6
relTol 1e-2;
pdFinal
$pd;
tolerance 1e-08;//1e-6;
relTol 0;
"(U|k)"
solver PBiCG;
preconditioner DILU;
minIter 1;
maxIter 1000;
tolerance 1e-06;
relTol 0;
PISO
cAlpha 1;
PIMPLE
nOuterCorrectors 1;//was 4;
nAlphaCorr 2;
nAlphaSubCycles 3;
nCorrectors 4;
nNonOrthogonalCorrectors 1;
correctPhi yes;
relaxationFactors
U 0.7;
pd 0.3;
Any help to fix this problem is appreciated.
OF24x is offline   Reply With Quote
Old   October 18, 2017, 04:16
Hrvoje Jasak
Wrong different Int scheme on div(phi,alpha).
Please use vanLeer01 or vanLeer01DC
alia and OF24x like this.
Hrvoje Jasak
Old   October 19, 2017, 00:18
smog1988
Thank you Dr. Jasak. A follow up question:
Since my mesh motion is in the Z direction, it became clear to me that I cannot decompose my case in Z. So I decompose hierarchically into 16 domains in Xand Y. But, for a certain mesh size the layer AR works fine, while for a finer cell size, it does not (for the same deconposition method). Is there a general rule of thumb as to how the mesh should be decomposed so as to be able to run these layer AR cases in parallel?
Am I correct in my understanding that the latest version of movingBodyTopiFvMesh is unable to handle arbitrary mesh decompositions? If yes, can you provide an estimate of when this will be released (or how to how to fix this)?
alpha1, gamma, interdymfoam, layer addition, layer removal
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 03:53
set up of volume fraction of the thrid phase in VOF fevi84 FLUENT 0 April 27, 2012 18:22
