October 10, 2017, 04:49 |
DTCHull tutorial, forces output 0 everywhere
Krzysztof
I am new to OF. I intend to use openFOAM to do some resistance estimates of various hull forms. I started by running DTCHull tutorial using ./Allrun in order to get familiar with post processing and case set-ups. After running the case, I accessed the post processing folder and the file force.dat reads 0 for each time step which is clearly wrong. Has anyone encountered the same problem? Is there any data that needs to be modified before running the case? Perhaps I have missed something? Thanks Last edited by BSN123; October 10, 2017 at 06:59. |
February 17, 2018, 05:53 |
Ali Hassan Khan
Hey.... yes you are missing a command... instead of giving ''snappyHexMesh'' command just give ''snappyHexMesh -overwrite''. Using this command you will be overwriting the files in constant folder with all the files for faces etc and then it would start giving the values of Forces because in that case it takes into account the Hull otherwise not
dtchull, dtchull tutorial, forces, ship, ship resistance |
rhoSimplecFoam: error in Forces output (correct pressure field) | WhiteW | OpenFOAM Running, Solving & CFD | 1 | December 8, 2015 13:02 |
What is the best way to include speed in the DTCHull (wigleyHull) tutorial? | Ron de Vos | OpenFOAM Running, Solving & CFD | 1 | October 10, 2015 10:44 |
[PyFoam] what is the unused output? | leroyv | OpenFOAM Community Contributions | 4 | July 4, 2014 04:55 |
FORCES don't run! | C12Carbon | OpenFOAM | 0 | September 10, 2011 07:34 |
controlDict 'forces' function: multiple output files? | lordvon | OpenFOAM | 0 | January 10, 2011 16:22 |
