Different dimensions for = dimensions : [0 2 -1 0 0 0 0] = [0 4 -3 0 0 0 0] |
October 9, 2017, 08:54 |
Mohak Lapsiwala
I am trying to perform cyclone simulation (steady, single phase) using available LRR model. As my knowledge in openfoam is quite limited I am not able to know what exactly the mentioned error suggests. Different dimensions for = dimensions : [0 2 -1 0 0 0 0] = [0 4 -3 0 0 0 0] From function bool Foam::dimensionSet:perator=(const Foam::dimensionSet&) const in file dimensionSet/dimensionSet.C at line 171. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::dimensionSet:perator=(Foam::dimensionSet const&) const at ??:? #3 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>:perator=(Foam::tmp<Foam::Geometri cField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #4 Foam::RASModels::LRR<Foam::IncompressibleTurbulenc eModel<Foam::transportModel> >::correctNut() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Aborted (core dumped) I would be very much thankful for any suggestions. Regards, Mohak. Last edited by mohakbl111; October 9, 2017 at 09:24. Reason: To provide more information for the mentioned error |
October 9, 2017, 11:35 |
Rep Power: 9 |
I am very inexperienced with OpenFOAM but I did have this error when I was trying to move a case between solvers that used different units for pressure and phi. Maybe you could compare your unit definitions in your /0 folder to ones from a tutorial to make sure they're consistent?
October 9, 2017, 11:37 |
Tobias Holzmann
Rep Power: 51 |
as Surgeron said, you mixed files and units. Check out the units in your time folder 0/ to be correct. One of the simplest ways is to copy a tutorial of the solver you want to use and adjust it to your needs.
Keep foaming, Tobias Holzmann |
October 9, 2017, 11:42 |
Mohak Lapsiwala
Thank you for your suggestions... I will try to do as you both have said and get back to you with the details (Probably tomorrow).
Regards, Mohak. |
February 6, 2019, 05:06 |
Dimension set error
Vivek
Rep Power: 8 |
Hi everyone,
I am trying to implement turbulent integral Length scale in my code PHP Code:
PHP Code:
PHP Code:
February 6, 2019, 05:37 |
Rep Power: 10 |
I had this kind of problem when I tried running different solvers on the same Case like potentialFoam and simpleFoam.
The solution was quite easy, I just had to delete the phi-file. Your phi-field will be calculated from your velocity field anyway before the first iteration even starts. |
contact angle behavior in micro & nano dimensions | Jimbomet | OpenFOAM Running, Solving & CFD | 7 | June 18, 2016 16:18 |
FOAM FATAL ERROR for Different dimensions | rupesh_w | OpenFOAM Running, Solving & CFD | 2 | April 27, 2016 04:14 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 04:14 |
Software that can stretch the overall dimensions of a mesh. | Robert_B | Main CFD Forum | 2 | January 27, 2012 07:39 |
fields + dimensions | santiagomarquezd | OpenFOAM Programming & Development | 3 | March 7, 2011 12:47 |
