InterFoam higher diffusion with higher mesh resolution
Like Tree1Likes
  • 1 Post By saddy
Old   October 9, 2017, 06:07
Default InterFoam higher diffusion with higher mesh resolution
Roman G.
Novel is on a distinguished road
I'm simulating sloshing in a system with two liquids. Sloshing is generated due to Lorentz force. The geometry is a 10x10x10 cm cube with anode and cathode at the top and the bottom. When simulating, the diffusion is higher when I increase the mesh resolution. I'm using fixed time stepping as long as my courant number is lesser than 0.1 otherwise the time step is reduced. The surface tension is set to 0.
My alpha:
    "alpha.*"
        nAlphaCorr      2;
        nAlphaSubCycles 3;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    3;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-12;
        relTol          0;
        maxIter         1000;
Does anyone know why the diffusion might increase?
PS: Let me know if you need more informations.
regards,
R.
Novel is offline   Reply With Quote
Old   October 17, 2017, 03:23
sandy
saddy is on a distinguished road
hey , i have been working for a long time using interfoam and interdymfoam
the problem is the fact that more the no of cells you increase, more the spurious currents appear, more smeared/diffuse interface occurs.
the solution is here : http://www.tfd.chalmers.se/~hani/kur...ankarMenon.pdf
however my suggestion is to couple level set with vof in INTERDYMFOAM
PLz let me know if you make any progress
saddy is offline   Reply With Quote
Old   October 23, 2017, 05:11
Roman G.
thank you for your answer do you have any reference regarding this topic?
I thought spurious currents only occurs if surface forces are calculated but as I mentioned in the question I have no surface tension.
Old   October 23, 2017, 10:47
sandy
the problem of interface diffusion is due to the way the volume of fluid is implemented in openfoam.
openfoam uses MULES which always produces diffused interface when interface is movving with high velocity and if small volume fraction is what we trying to track.
there are two solutions to this problem
1. volume of fluid+level set implementation
2.implementing Geometric volume of fluid, named as ISOADVECTOR its recently released in openfoam-v1706, interfoam - is modified to interflow , u can try it
its branch is also available on github, just google isoadvector
as far as your questions about references, i don't understand it
a number of researchers have implemented vof+level set and within my field of intrests , you can google "EVAPVOFHARDT" a two phase flow solver with boiling done by kunkelmann and he aslo faced this problem and solved it by coupling vof+level set with dynamic mesh
his solver "evapvofhardt is also publicly available and it doesn't show any diffusion at all.
must try it
let me know what you think
the_ichthyologist likes this.
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 17:59
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
