Use of function objects to terminate transient simulations
Like Tree1Likes
  • 1 Post By kandelabr
Old   October 5, 2017, 09:51
Default Use of function objects to terminate transient simulations
Luca Cornolti
Luca Cornolti is on a distinguished road
I'm running a free surface problem with the interFoam solver of OpenFOAM v1706.
Schematically, the geometry can be described as a cylindrical tank with an open surface at the top, an outlet duct on the side surface and a inlet on the bottom surface.
From the inlet, I'm filling the tank only with water.
From the outlet duct both air and water flow out, as in a water channel problem.
The height of water adjusts itself such that it allows the amount of water introduced thought the inlet to flow out from the outlet duct.
I'm running some transient simulations to reach the final water level which changes with the inlet flow. In general the time needed to reach the steady state is not known a-rpiori and I have to run many simulations.
Therefore, I'd like to use the function objects in the controlDict to stop the simulation when some criteria are reached. For example, when the total water flow at the inlet at the outlet duct are equal and the outlet flow does not significantly change with time.
I checked this link to get some ideas:
http://www.openfoam.com/releases/ope...on-control.php
And I came out with the following code:
functions
    inletFlux
        type            surfaceFieldValue;
        libs ("libfieldFunctionObjects.so");
        fields
            alphaPhi
        writeFields     false;
        log             true;
        surfaceFormat   null;
        regionType      patch;
        name            inlet;
        operation       sum;
        writeControl    timeStep;
    outletFlux
        $inletFlux;
        name            outlet;
    averageInletFlux
        type                valueAverage;
        functionObjectLibs  ( "libfieldFunctionObjects.so" );
        functionObject    inletFlux;
        fields                 (???????);
        window              0.01;
    averageOutletFlux
        $averageInletFlux;
        functionObjectName  outletFlux;
    // Compute flux difference
    Fluxdifference
        type                ??????;
    runTimeControl1
        type                runTimeControl;
        functionObjectLibs  ("libjobControl.so");
        conditions
            // Terminate when inlet and outlet fluxes difference is less than tolerance
            difference
                type                average;
                functionObjectName  Fluxdifference;
                fields              (??????);
                tolerance           1e-4;
                window              50;
            // Terminate when average OutletFlux changes by less than a tolerance
            average1
                type                average;
                functionObjectName  averageOutletFlux;
                fields              (??????);
                tolerance           1e-4;
                window              50;
The idea is to compute the total fluxes on the two patches, do a time average of these quantities as they are quite noisy and finally to use the difference of these averages as a criterion to terminate the simulation.
The problem is that I'm missing some information (lines with question marks), specifically:
1) what is the name of the field returned by inletFlux and outletFlux functionObjects on which I can operate (see the link for an example with forceCoeffs functionObjects)?
2) How to compute the difference of these two fluxes?
Thank you for your suggestions,
Luca
Luca Cornolti is offline   Reply With Quote
Old   June 18, 2019, 10:07
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
Hello!
Did you manage to solve this conundrum? I have a very similar case at the moment.
Thanks!
jcappola likes this.
www.damogranlabs.com
kandelabr is offline   Reply With Quote
Transient Simulations saisanthoshm88 CFX 7 July 13, 2013 07:57
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
URANS and Transient Simulations bob Main CFD Forum 0 October 1, 2003 04:54
