Time Varying Heat Flux for Internal Energy Boundary Condition
Like Tree3Likes
  • 1 Post By faab
  • 1 Post By Yadav067
  • 1 Post By GerhardHolzinger
Old   October 5, 2017, 08:34
Default Time Varying Heat Flux for Internal Energy Boundary Condition
fouad abi
faab is on a distinguished road
Send a message via Skype™ to faab
Dear All,
I am working on a solver that computes the energy dissipation, from an external heat source, in a confined Liquid Helium channel, and the energy equations are solved with Specific Internal Energy as the "main variable". The temperature field and the thermodynamic properties are computed using thermodynamic libraries at every time step, and a custom PISO loop was developed for this purpose.
The geometry of the problem at hand is quite simple, with a narrow channel (in middle) connecting two baffles (right and left), the whole region being filled with Liquid Helium. A certain (time depending) heat flux is generated through both the upper and lower boundaries of the channel, and this energy is dissipated in the L. Helium towards the end baffles.
I managed to build a solver that runs simple cases where the heat flux is constant using the default BC:
hell_channel_to_solid2
        type                     externalWallHeatFluxTemperature;
        kappa                    lookup;
        q                        uniform 1e7;  //Boundaries S=1e-3 [m2]; Q=1e-4 [W.m-2]
        //Ta                     uniform 20.0;
        //h                      uniform 10.0;
        thicknessLayers          (1.5e-3);
        kappaLayers              (8.5634e-1);
        value                    uniform 15.0;
        kappaName                kEff;
        Qr                       none;
        relaxation               no;
But I can't find a way to make this "q" time varying. If anyone has a suggestion and/or can guide me through the process that would be highly appreciated.
I have a question also, I'm not sure what is the "value uniform 15.0" supposed to be, I re-used it from an existing case, does anyone have an answer to that?
Thanks a lot !
saidc. likes this.
faab is offline   Reply With Quote
Old   March 21, 2019, 13:49
Chenguang Li
lcg44 is on a distinguished road
Hi I have same problem. Is there any solution for this? Thank you!
lcg44 is offline   Reply With Quote
Old   April 15, 2019, 05:42
Post KappaLayers definition
vamshi
vamshinallan is on a distinguished road
If I want to define one layer of material with thermal conductivity in externalWallHeatFluxTemperature Boundary condition, The following error appears in paraview
ERROR: In C:\bbd\7cc78367\build\superbuild\paraview\src\VTK\ IO\Geometry\vtkOpenFOAMReader.cxx, line 7486
vtkOpenFOAMReaderPrivate (000001E93C169D60): Error reading line 13270 of D:\latest\baffledtower\newPit8\20/T: Unmatched )
In the source code the syntax is given as
Description
This boundary condition applies a heat flux condition to temperature
on an external wall in one of three modes:
- fixed power: supply Q
- fixed heat flux: supply q
- fixed heat transfer coefficient: supply h and Ta
where:
\vartable
Q | Power [W]
q | Heat flux [W/m^2]
h | Heat transfer coefficient [W/m^2/K]
Ta | Ambient temperature [K]
\endvartable
For heat transfer coefficient mode optional thin thermal layer resistances
can be specified through thicknessLayers and kappaLayers entries.
The thermal conductivity \c kappa can either be retrieved from various
possible sources, as detailed in the class temperatureCoupledBase.
The ambient temperature Ta is specified as a Foam::Function1 of time but
uniform is space.
Usage
\table
Property | Description | Required | Default value
mode | 'power', 'flux' or 'coefficient' | yes |
Q | Power [W] | for mode 'power' |
q | Heat flux [W/m^2] | for mode 'flux' |
h | Heat transfer coefficient [W/m^2/K] | for mode 'coefficent' |
Ta | Ambient temperature [K] | for mode 'coefficient' |
thicknessLayers | Layer thicknesses [m] | no |
kappaLayers | Layer thermal conductivities [W/m/K] | no |
relaxation | Relaxation for the wall temperature | no | 1
emissivity | Surface emissivity for radiative flux to ambient | no | 0
qr | Name of the radiative field | no | none
qrRelaxation | Relaxation factor for radiative field | no | 1
kappaMethod | Inherited from temperatureCoupledBase | inherited |
kappa | Inherited from temperatureCoupledBase | inherited |
\endtable
Example of the boundary condition specification:
\verbatim
<patchName>
mode coefficient;
Ta constant 300.0;
h uniform 10.0;
thicknessLayers (0.1 0.2 0.3 0.4);
kappaLayers (1 2 3 4);
kappaMethod fluidThermo;
value $internalField;
What if my geometry has only one thickness material??
How to define thicknessLayers and kappaLayers .
I defined it as
shellw
mode coefficient;
Ta constant 320;
h uniform 13;
thicknessLayers ( 0.005 );
kappaLayers ( 45 );
kappa none;
value uniform 318;
This one gives above stated error.. Please respond..
vamshinallan is offline   Reply With Quote
Old   April 18, 2019, 10:47
regard is on a distinguished road
hi all
i have a problem with heat flux varying coductivty ... and finally i used the groovy bc for this purpose ..my bc is :
heater
type groovyBC;
valueExpression "325.15";
gradientExpression "q/(K1*alpha1+K2*(1.0-alpha1))";
fractionExpression "0";
variables "q=14000;K1=0.06;K2=0.01;";
timelines ();
value uniform 327.15;
perhaps this bouandry condition can help you
best
regard is offline   Reply With Quote
Old   March 12, 2020, 13:57
Raj Niraj Patil
RajNPatil is on a distinguished road
Hi regard,
Thank you for the answer but I have some doubts.
1]When we set it as groovyBC, are we making it partial derivative there or we need to specify fractionExpression to be 0 for that.
2]For your case you have used fractionExpression to be 0, so it is using only gradientExpression. So, what is your left hand side of the gradient equation? Is it the normal derivative of the temperature?
It will be kind of you if you explain the actual physics represented by these all terms in this BC.
thank you in advance.
regards,
Raj
RajNPatil is offline   Reply With Quote
Old   July 24, 2021, 08:50
Default Varying Heat Flux
Shailesh
Yadav067 is on a distinguished road
Dear Fellow,
How to give varying heat flux with respect to temperature in CFD?
Kindly, provide solution?
Yadav067 is offline   Reply With Quote
Old   July 24, 2021, 08:53
Default Varying Heat Flux problems
Shailesh
Dear Fellow,
How to give varying heat flux with respect to temperature and time in CFD?
Udf code for unit step or (Heaviside function) function in variable heat flux (Y-axis, Temperature Vs X-axis, Time)
please provide with udf code
parthigcar likes this.
Old   March 7, 2022, 12:29
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I managed to receive a similar error message by ParaView with a CHT case in which I used the externalWallHeatFluxTemperature BC.
However, using a newer version of ParaView solved the issue.
Using ParaView-5.10.0, which I installed along OpenFOAM-2112, showed no error.
Using ParaView-5.6.3, which I installed along OpenFOAM-9, did show the error.
This issue, i.e., the error regarding the unmatched ), has also been discussed in this issue at the GitLab issue board of KitWare
olesen likes this.
GerhardHolzinger is offline   Reply With Quote
heat transfer boundary, heat transfer modelling, time vayring bc
UDF for a time varying heat flux boundary condition B.Hamada Fluent UDF and Scheme Programming 9 August 8, 2018 13:51
time varying heat flux boundary condtion xishan555 OpenFOAM Programming & Development 1 February 26, 2015 10:33
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
How to implement heat flux boundary condition as function of time baran_foam OpenFOAM Running, Solving & CFD 3 September 15, 2014 01:28
Boundary Condition for heat flux changing by time vainilreb OpenFOAM Pre-Processing 0 January 22, 2013 14:13
