Issue with specifying TotalPressure boundary condition. |
October 4, 2017, 21:30 |
Rep Power: 10 |
In simulating a supersonic bow shock on an air jet thrusting into the flow with rhoCentralFoam, I have produced some results that I do not believe are correct. The bow shock caused by the air jet is significantly further from the body than it should be. Because of this, I suspect that my boundary conditions are incorrect, specifically the supersonic freestream boundary conditions. My intention is to have the freestream boundary condition be at the following conditions: Temperature or 173.4 K, velocity of Mach 2, and a total pressure of 13789 Pa. My current setup uses the fixedValue boundary with a pressure of 1762, which is my calculated static pressure. Switching to using the totalPressure boundary condition resulted in my simulation crashing very early on. My current setups for P, T, and U are below. P: Code:
... dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1762.3; boundaryField { inlet { type fixedValue; value uniform 1762.3; } ... Code:
... dimensions [0 0 0 1 0 0 0]; internalField uniform 173.4; boundaryField { inlet { type fixedValue; value uniform 173.4; } ... Code:
... dimensions [0 1 -1 0 0 0 0]; internalField uniform (488 0 0); boundaryField { inlet { type fixedValue; value uniform (488 0 0); } ... Thank you |
October 9, 2017, 15:27 |
Rep Power: 10 |
I suppose I should make my question more clear since it is a little vague. I am using RhoCentralFoam to simulate a rocket engine thrusting opposite of Mach 2 flow. I have this working but am creating a bow shock 40% greater than expected. However, I am using a fixed value boundary condition set to a calculated static pressure 1762Pa. I have set the static pressure higher (by 10X) and the bow shock gets much smaller, as expected. As such, I believe pressure to be the immediate issue.
I would like to use Total Pressure (since that is the known value given to me). However, if I use the Total Pressure boundary condition set to 13790Pa (the known value of total pressure for the freestream) and run the simulation with all other factors unchanged the simulation crashes due to a negative initial temperature within the first few time steps. I've isolated the problem to be occurring on the inlet patch for the freestream where paraView is showing a very sharp change in flow parameters between the total pressure boundary condition and the initial internalField pressure of 1792Pa. To me it seems that the internalField is not set to the correct pressure for the given total pressure even though I calculated it to be 1792Pa. Questions: 1) Has anyone encountered a similar problem when specifying Total Pressure? If so, what was the cause and remedy? 2) When applying a fixedValue boundary condition, is it specifying static, dynamic, or total pressure? 3) Are there reasons that rhoCentralFoam would be failing to correctly predict where a bow shock in this situation would form? 4) Is there a more accurate solver for this situation than rhoCentralFoam? I have attached an image of my case. Thank you Last edited by wididid; October 10, 2017 at 19:12. Reason: Missing attached image |
Need info about totalPressure boundary condition | sahmed | OpenFOAM Running, Solving & CFD | 4 | December 4, 2018 22:23 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
