Writing snappyHexMeshDict
Like Tree2Likes
  • 1 Post By jhanson2
  • 1 Post By Teosim
Old   September 25, 2017, 19:44
Default Writing snappyHexMeshDict
Jack Hanson
jhanson2 is on a distinguished road
The propeller example in pimpleDyMFoam says I can write the following:
type triSurfaceMesh;
file "innerCylinder.obj";
regions
ascii
name innerCylinder;
I write a similar code that reads
file "Torpedo_with_Wings.obj";
regions
ascii
name Torpedo_with_Wings;
I get the following error
"--> FOAM FATAL ERROR:
Unknown region name ascii for surface Torpedo_with_Wings
Valid region names are 1(patch0)
From function Foam::searchableSurfaces::searchableSurfaces(const Foam::IOobject&, const Foam::dictionary&, bool)
in file searchableSurfaces/searchableSurfaces/searchableSurfaces.C at line 258.
I'm assuming that snappyHexMesh doesn't really know what ascii means (or any other name I put there) but I've defined it the same way the example has and it' unclear why this error is occurring.
Following the directions here
https://cfd.direct/openfoam/user-guide/snappyhexmesh/
and
https://openfoamwiki.net/index.php/SnappyHexMesh
don't give good direction about what I can put after the "{". Would anyone be able to give me direction as to what I'm doing wrong?
namsivag likes this.
Last edited by jhanson2; September 25, 2017 at 19:48. Reason: Easier to read this way
jhanson2 is offline   Reply With Quote
Old   September 26, 2017, 04:07
Teosim is on a distinguished road
looks like SHM could not find a region named "ascii" in your .obj file. It also states that there is a single region named "patch0".
You could first try substituting the "ascii" entry with "patch0" in your snappyHexMeshDict or edit/regenerate your .obj file with the desired region name.
Teosim is offline   Reply With Quote
Old   September 26, 2017, 18:06
Jack Hanson
@Teosim,
Thank you. That did improve the code. Do you know why switching from "ascii" to "patch0" worked?
Unfortunately now I get the error:
--> FOAM FATAL IO ERROR:
Could not open "/home/jackhansonjr/OpenFOAM/openfoam5/tutorials/incompressible/pimpleDyMFoam/Torpedo/constant/triSurface/Torpedo_with_Wings.eMesh"
file: /home/jackhansonjr/OpenFOAM/openfoam5/tutorials/incompressible/pimpleDyMFoam/Torpedo/system/snappyHexMeshDict.castellatedMeshControls.features from line 94 to line 95.
From function void Foam::refinementFeatures::read(const Foam:bjectRegistry&, const Foam::PtrList<Foam::dictionary>&)
in file refinementFeatures/refinementFeatures.C at line 98.
FOAM exiting
I'm assuming this is because "Torpedo_with_Wings.eMesh" doesn't exist and I'm going to go through the exercise of figuring out how to make that.
Old   September 27, 2017, 06:09
the entry changed is the name of the region in the .obj file. During prior execution SHM was looking for a region named "ascii" in your .obj file and could not find it. You could check this by opening .obj file with a text editor and looking at the headers.
About next error, I guess you are right. For example you can automatically create the .eMesh files by running surfaceFeatureExtract command which reads a surfaceFeatureExtractDict in your case system directory.
If I remember correctly you could also create .obj files with edges needed for refinement, place them in constant/triSurface and change the file name and format accordingly in snappyHexMeshDictionary.
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
How to Mix AIR and WATER Elvis1991 FLUENT 12 December 1, 2016 13:28
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 12:27
