problems with compressible solvers
Like Tree1Likes
  • 1 Post By RobertG
Old   September 25, 2017, 11:09
Default problems with compressible solvers
Robert Grandl
RobertG is on a distinguished road
Hy everyone,
I have problems running a Karaman vortex street test case with all compressibel solver in foamExtend but als in OpenFoam 4.0.
I realy can't see the error.
The setup is simple:
U
Inlet : fixedValue (1 0 0)
outlet: zeroGradient
Wall: fixedValue (0 0 0)
p
Inlet: zeroGradient
Outlet: fixedValue 1e5
Wall: zeroGradient
T
Inlet: fixedValue 293.15
Outlet: zeroGradient
Wall: fixedValue 293.15
laminar flow
Don't fix me to the numbers. But the boundary conditions are correct.
At first, it runns correct, but at some point, the velocity starts to jump,
the pressure is fluctuating (also gets negative) and the same for the density.
I realy hope some one can help me.
Thanks a lot
RobertG
RobertG is offline   Reply With Quote
Old   September 26, 2017, 03:47
Smile compressible solver
CFDfreak
nandhakumar is on a distinguished road
Hello
The solution is blowing up it seems..Try adjusting your density relation factor to 0.01 - 0.05 and try adjusting your schemes to bounded gauss upwind for divergence.
Kindly post me your relaxation factor and schemes used. It seems you are trying to simulate von karman vortex. Try any turbulence model otherwise solution may not converge.
nandhakumar is offline   Reply With Quote
Old   September 26, 2017, 13:25
Robert Grandl
Hello nandhakumar,
I forgot to mention, that I uploadet the whole case.
By the way, thank you.
Your hint with the fvSchemes, helped a lot.
I copied one from rhoPisoFoam tutorials. Now it workes fine.
Thanks a lot.
Best Regards
RobertG
nandhakumar likes this.
rhocentrafoam, rhopimplefoam, rhopisofoam
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Compressible Flow Solvers vatant OpenFOAM Running, Solving & CFD 30 March 27, 2017 13:10
Why rho coeffs are zero in compressible solvers? immortality OpenFOAM Running, Solving & CFD 5 December 14, 2012 13:09
Problems with a compressible shear flow ivan_cozza OpenFOAM Running, Solving & CFD 2 May 26, 2010 11:08
Using compressible BCs for incompressible problems cfd Main CFD Forum 1 April 16, 2006 03:41
