Gas Injection in a Duct Flow - Modelling and Solving |
September 19, 2017, 11:51 |
Andrea
Rep Power: 9 |
Hello everyone,
I am a beginner in OpenFOAM and would love some help with this project I'm starting on. I want to run a simulation of a cylindrical duct, in which the main-flow is air and a different gas in injected radially via a secondary duct. So I will probably deal with a 2D-axisymmetric, single-phase (but multispecies), low-Mach (incompressible), unsteady problem. Could you please provide a suggestion for which solver to use and/or how to model the injection process? Thank you very much Andrea |
October 18, 2017, 12:04 |
Ayush
Rep Power: 9 |
Dear Andrea!
If you have no condition of strict low Mach solver then you can use reactingFoam which can be set up for incompressible or low Mach case. Axisymmetric mesh will do fine. Also, for sample or similar kind of case you can look up to tutorials of openfoam dev version of Sandia flame D. Ayush |
October 18, 2017, 12:24 |
Fridrik Magnusson
Rep Power: 9 |
I think pisoFoam or icoFoam can do the trick
otherwise there is a list of standard solvers here: https://www.openfoam.com/documentati...rd-solvers.php if you are new to OpenFoam i suggest you have a look at this webpage: https://wiki.openfoam.com/Tutorials This video might be something close to what you need https://www.youtube.com/watch?v=KznljrgWSvo - Fridrik Magnusson |
October 20, 2017, 04:41 |
Andrea
Rep Power: 9 |
Thank you for your answers.
After a couple of simulations with simpleFoam (in order to have the steady state solution before injecting) and then using reactingFoam as it is by deafult, only switching off the reactions, I realised that it is too expencive. I really need to run it incompressible (low mach approximation). Have you some advices about how I could make such a modification? I have been reading about a similar work done on reactingFoam in OF 2.0, but OF 4.x it is quite different and the actual modifications were not explained in detail. Thank you Andrea |
axissymmetric problem, duct flow, injection model, mixing gases, multi species |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Erosion modelling in slurry flow through pipelines | Piyushsingh | FLUENT | 0 | May 1, 2013 04:40 |
Jet in Supersonic Crossflow, controlling mass flow rate | ChrisA | OpenFOAM Running, Solving & CFD | 3 | November 13, 2012 18:20 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 05:16 |
Modelling air flow around a sphere | Fergie | FLUENT | 1 | December 5, 2005 15:27 |
