How to get the trim angle using interDyMFoam? |
September 14, 2017, 02:45 |
Antoni Alexander
Rep Power: 16 |
Hello, everyone!
I am using OpenFOAM 2.3.0 interDyMFoam to simulate the planning process of a certain boat. I have copied the DTCHull from the interDyMFoam tutorial, then changed the grid to my model grid, and made some other modification. After that, the computation is running well. However, when I see the output log file, I did not find any information of the trim angle of my boat. The output of one time step from my log file is as follows: Code:
Interface Courant Number mean: 1.02311e-05 max: 5.03824 Courant Number mean: 0.00387547 max: 9.9856 deltaT = 8.32898e-05 Time = 1.087646 Restraint translationDamper: force (-0 -29.8886 -0) Restraint rotationDamper: moment (-0 -0 -40.6732) Centre of mass: (1.999 0.135179 0) Linear velocity: (0 0.00348609 0) Angular velocity: (0 0 0.00349454) Execution time for mesh.update() = 1.36 s GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.0878525, No Iterations 13 time step continuity errors : sum local = 6.88552e-13, global = -4.13486e-13, cumulative = 7.49271e-07 smoothSolver: Solving for alpha.water, Initial residual = 7.31488e-07, Final residual = 4.15881e-12, No Iterations 2 Phase-1 volume fraction = 0.613521 Min(alpha1) = -2.88339e-17 Max(alpha1) = 1 Applying the previous iteration compression flux MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.613521 Min(alpha1) = -5.01782e-09 Max(alpha1) = 1 GAMG: Solving for p_rgh, Initial residual = 0.000485961, Final residual = 4.47356e-07, No Iterations 11 time step continuity errors : sum local = 6.06207e-12, global = 3.72063e-12, cumulative = 7.49274e-07 GAMG: Solving for p_rgh, Initial residual = 6.56915e-05, Final residual = 5.96469e-08, No Iterations 24 time step continuity errors : sum local = 8.08326e-13, global = 4.84482e-13, cumulative = 7.49275e-07 GAMG: Solving for p_rgh, Initial residual = 3.83081e-05, Final residual = 4.69749e-08, No Iterations 24 time step continuity errors : sum local = 6.36565e-13, global = 3.72979e-13, cumulative = 7.49275e-07 smoothSolver: Solving for omega, Initial residual = 2.03442e-07, Final residual = 4.6581e-10, No Iterations 1 bounding omega, min: -724.397 max: 1.08996e+06 average: 454.004 smoothSolver: Solving for k, Initial residual = 2.63561e-06, Final residual = 5.50966e-09, No Iterations 1 bounding k, min: -4.08257 max: 43.585 average: 0.0755764 ExecutionTime = 81314.7 s ClockTime = 81351 s forces forces output: sum of forces: pressure : (77.6269 419.922 -166.705) viscous : (3.34985 -0.269405 1.06011) porous : (0 0 0) sum of moments: pressure : (1.78104 -10.2919 -34.4436) viscous : (-0.346968 0.814481 1.01335) porous : (0 0 0) Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libsixDoFRigidBodyMotion.so"); solver sixDoFRigidBodyMotion; sixDoFRigidBodyMotionCoeffs { patches (hull); innerDistance 0.3; outerDistance 1; centreOfMass (1.999 0.135 0); mass 39.08; momentOfInertia (1 1 40); rhoInf 1; report on; reportToFile on; accelerationRelaxation 0.3; value uniform (0 0 0); constraints { yAxis { sixDoFRigidBodyMotionConstraint line; direction (0 1 0); } zPlane { sixDoFRigidBodyMotionConstraint axis; axis (0 0 1); } } restraints { translationDamper { sixDoFRigidBodyMotionRestraint linearDamper; coeff 8596; } rotationDamper { sixDoFRigidBodyMotionRestraint sphericalAngularDamper; coeff 11586; } } } // ************************************************************************* // From that I can tell the sinkage from the centre of mass of each time step, but I can't get the trim angle information. So, how can I get the trim angle? Should I do some modification in any of the dictionary files? Any suggestion will be appreciated. |
September 17, 2017, 21:21 |
Antoni Alexander
Rep Power: 16 |
No one has this kind of experience?
September 19, 2017, 05:58 |
Jan
Rep Power: 20 |
Easiest would be to switch to the latest dev-Version:
https://github.com/OpenFOAM/OpenFOAM...73d888c26dfbbd Best regards, Jan |
September 21, 2017, 22:04 |
Antoni Alexander
Rep Power: 16 |
Thanks Jan, I will check the latest version. Maybe I will start from a interDyMFoam tutorial.
But if we concentrate on this 2.3.0 version, is it possible to modify the code a little bit so that the Euler Angle could be printed as well? Best regards, Antoni |
October 10, 2017, 07:14 |
Antoni Alexander
Rep Power: 16 |
With the new version of OF, I got the orientation from the output.
Note that, in my case, the ship is fixed in z=0 plane, which is different from the tutorial of DTCHull, so I think the orientation should be (cosφ −sinφ 0 sinφ cosφ 0 0 0 1). If your ship is fixed in y=0 plane, which is the same as the DTCHull tutorial, the orientation will change to (cosθ 0 sinθ 0 1 0 −sinθ 0 cosθ). Based on these information, the trim angle φ orθ can be easily calculated. By searching in this forum, I've found some useful scripts provided by foamers. After that I modified them and added some new functions. Use this script, the trim angle and CG rise of a ship can be plotted directly. motion.sh Code:
#!/bin/bash #pick centre of mass grep 'Centre of mass' $1 | cut -d '(' -f 2 | tr -d ")" > centreMass_Extract grep -e "^Time = " $1 | cut -d " " -f 3 > times_Extract awk 'NR == 1 || (NR-1) % 3 == 0' centreMass_Extract > centreMass_Extract1 paste times_Extract centreMass_Extract1 > cmMotion_parcial sed -e 's/ [ ]*/\t/g' cmMotion_parcial > cmMotion #pick euler angle and convert it to degree grep 'Orientation' $1 | cut -d '(' -f 2 | tr -d ")" > ort awk 'NR == 1 || (NR-1) % 3 == 0' ort > ort1 awk '{ print $2 }' ort1 > sin_theta awk ' function acos(x){return atan2(sqrt(1-x*x),x);} function asin(x){return atan2(x,sqrt(1-x*x));} function pi(){return 2*asin(1);} { trim_in_deg=asin($1)/pi()*180 print trim_in_deg }' sin_theta > trim_extract paste times_Extract trim_extract > trimMotion rm cmMotion_parcial rm times_Extract rm centreMass_Extract rm centreMass_Extract1 rm ort rm ort1 rm sin_theta rm trim_extract #plot cm and trim angle gnuplot -persist > /dev/null 2>&1 << EOF set title "Motion vs. Time" set xlabel "Time / Iteration" set ylabel "CG Rise (m) or Trim Angle (degree)" # set xrange [3.06:] plot "cmMotion" using 1:3 title 'CG Rise' with linespoints,\ "trimMotion" using 1:2 title 'Trim Angle' with linespoints EOF Code:
montion.sh log Best regards, Antoni |
Dynamic contact angle calculation in multiphaseInterFoam | rajeshchem | OpenFOAM | 3 | December 23, 2022 14:00 |
Roll angle values at every time step... interDyMFoam Help plz | 13msmemusman | OpenFOAM Programming & Development | 0 | June 20, 2015 15:10 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 17:24 |
error using interDyMFoam with kOmegaSST to simulate sloshing | anmartin | OpenFOAM Running, Solving & CFD | 0 | July 20, 2010 13:21 |
