End time question
Like Tree2Likes
  • 1 Post By GerhardHolzinger
  • 1 Post By piu58
Old   September 13, 2017, 08:29
Default End time question
Gebregziabher
gerie is on a distinguished road
Dear respected members,
I just want to ask a small question, currently am running a case with interFoam solver, and I set my end time to 40 in system/controlDict, but when the simulation ends it stops at 37, therefore what could be the possible mstake I made, or does it calculates by it self the exact end time?
Thank a lot in advance,
Gerie
gerie is offline   Reply With Quote
Old   September 13, 2017, 10:31
sati is on a distinguished road
It is hard to give you a satisfying answer with so little information about your case.
Can you post your controlDict and the end of your interFoam log file?
sati is offline   Reply With Quote
Old   September 13, 2017, 10:50
Gebregziabher
What I mean is that, look to Pic-1, I set the end time to 40, then when I run the case and did "reconstractPar", I got only till 37 (see Pic-2, I took screen shot), I expected to show me until the last end time (folder40),but it gives me till folder37 as the last one.
Thank again for your help.
Old   September 13, 2017, 12:02
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
Are you sure your simulation did not crash between t=37 and t=38, thus making 37 the last time step to be recorded. Maybe it didn't crash, but you did not state whether the simulation ended without errors or not.
Since you were able to run reconstructPar, it is safe to assume that the simulation did not crash due to a full hard drive. This would cause an IO-error when the solver tries to write time step 38.
gerie likes this.
GerhardHolzinger is offline   Reply With Quote
Old   September 14, 2017, 01:14
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I assume it crashed.
You may look at the loh file what happened. If you don't want to store it you should at least print some of the important parameters form the log to the screen (with the help of awk of at least with grep). Simulated time is one of them, time step may be another.
gerie likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
