nan values in output file
Like Tree1Likes
  • 1 Post By LauraL
Old   September 8, 2017, 09:53
Default nan values in output file
Laura Luhede
LauraL is on a distinguished road
Hi everyone
we use our custom solver to calculate the shear stress at interfaces. We had to switch from OF 3 to OF 4 and got a problem.
While reconstructing the case we get an error and found that some cells got a "-nan" value instead of the scalars (Image 1). When checking the Cell ID, we found them to be away from out actual interface (Image 2). In these cells the shear stress is supposed to be set to zero, so the problem is not located in our shear stress calculations.
Does anyone know, when OpenFoam writes nan values in the output files? The log doesn't show any divergence and the solver just keeps running until the end, it crashes when we try to reconstruct . Now we have trouble locating the error. So far we tried to change the decompose method.
Best, Laura
LauraL is offline   Reply With Quote
Old   September 8, 2017, 14:13
Default Re: nan values in output file
aow
Andrew O. Winter
aow is on a distinguished road
Hi Laura,
In my experience, OpenFOAM produces NAN output when division by zero occurs, which usually stops the simulation so perhaps your issue is different.
Could you provide some more details about the simulation? Particularly, was there any error or warning output produced during the simulation even though it didn't fail to complete? What is the problem you are modeling and what are your initial conditions? What solver did you use (or rather what one did you modify)? Solution method and schemes (fvSchemes, fvSolution)? How are you generating your mesh?
Best regards,
Andrew
aow is offline   Reply With Quote
Old   September 28, 2017, 12:25
Laura Luhede
Hi Andrew,
thank you for your answer and sorry for the very late reply.
I found the issue. In the end it was a problem with the break criteria in the shear stress calculation loop we applied in our code. So in rare cases the shear flow calculation went wrong and we divided by 0. I still don't get, why the simulation didn't crash though
Best
Laura
Kummi likes this.
decomposed, divergence, interfoam
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
