writeControl writing every time step despire writeInterval specifying otherwise |
September 5, 2017, 21:21 |
Katherine
Rep Power: 10 |
I'm having an issue with OpenFOAM writing data every time step. I'm using pimpleFoam with a max Courant number of 5, so I'm trying to take advantage of adjusting the time step to meet this criteria and speed things up a bit. But the problem is that no matter what scalar value I set "writeInterval" to, OF writes data every time step. Here is my controlDict file:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 5; deltaT 0.01; writeControl adjustableRunTime; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 12; writeCompression off; timeFormat general; timePrecision 12; runTimeModifiable true; adjustTimeStep yes; maxCo 5; functions { forces { type forces; functionObjectLibs ("libforces.so"); writeControl timeStep; writeInterval 1; patches (fixedWalls); pName p; UName U; rho rhoInf; rhoInf 1.205; log true; CofR (0 0 0); // origin for moment calculation writeFields yes; binData { nBin 90; //output data into 20 bins direction (1 0 0); // bin direction format gnuplot; cumulative yes; } } forceCoefficients { type forceCoeffs; functionObjectLibs ("libforces.so"); writeControl timeStep; writeInterval 1; patches (fixedWalls); writeFields yes; log true; patches (fixedWalls); // on cyl only pName p; UName U; dragDir (1 0 0); liftDir (0 1 0); pitchAxis (0 0 1); CofR (0 0 0); magUInf 10; // free stream velocity; inlet condition!! lRef 1; Aref 0.79; // cross sectional area rho rhoInf; rhoInf 1; origin (0 0 0); coordinateRotation { type EulerRotation degrees true; rotation (0 0 0); } binData { nBin 90; //output data into 20 bins direction (1 0 0); // bin direction format gnuplot; cumulative yes; } } } // ************************************************************************* // NOTE: I am running OpenFOAM-v1706 released here with Ubuntu 16.04. |
September 6, 2017, 08:48 |
Oskar
Rep Power: 11 |
Hi.
There is endTime set to 5 while writeInterval set to 100. I would set writeInterval to 0.1 or something like that. Maybe this solve Your problem. |
September 6, 2017, 12:14 |
Yousef
Rep Power: 11 |
When you select Code:
writeControl adjustableRunTime; So first, as Oskar said, reduce the writeIntervals to a value less than your endTime. Anyways, this should not be the main issue. Since with your current config no time step should be saved. I think it has something to do with your functionObjects. Please first remove them and verify that write behavior is resolved. Then, try setting writeFields to No in your functionObjects. Regards, |
September 6, 2017, 15:22 |
Katherine
Rep Power: 10 |
You are right Yousef; the problem was with my functionObjects. Removing them resolved the write behavior, and then including them and setting writeFields to "no" works as intended. Thank you both for your help!
May 28, 2020, 05:56 |
le
Rep Power: 17 |
Hello Alls,
I use OF1812 in system/control .... writeControl adjustableRunTime; writeInterval 0.1071; ..... and system/forces ..... writeControl timeStep ; writeInterval 10; ..... OF writes every time step even though I change value of " writeInterval 10; " So, appreciated your comments ! |
May 28, 2020, 18:47 |
Herpes Free Engineer
Rep Power: 13 |
- Could you please share the `controlDict` and `force*` file entirely? - What does OF write out at each time-step? `force` FO information or something else? - Have you double checked the log file if the `force` FO is written every time-step? May be the time-step is tiny, and you misinterpreted what is going on? thanks
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
July 15, 2024, 00:13 |
Rep Power: 3 |
For anyone coming across this in the future, I was dealing with a similar issue. One way of controlling your probes is by including the “executeControl” and “executeInterval” settings. For some reason this helps write at the expected interval instead of some other case, though I have found issues trying to use non integer values when using writeTime as the control. timeStep seems to be a better option for that.
adjustable run time, openfoam v1706+, write control |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
