solid-liquid two phase flow for two phase Euler Foam |
August 30, 2017, 04:57 |
Kai Jiang
Rep Power: 9 |
Hello!
I'm a beginner to OpenFOAM and i'm working on twoPhaseEulerFoam and simulate solid-liquid two phase flow. That is the liquid (water or oil) with carring the solid particles (diameter:0.0003m, the volume fraction:0.3 ) flows in a pipeline. It is wothing noting that i have deleted the lift force, virtual mass force, wall lubrication and the energy equation from the solver code in order to match the facts. However the terminal always hinted the following error when i tried to run the case. The error is the following: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : twoPhaseEulerFoamHydrate Date : Aug 30 2017 Time : 15:07:12 Host : "JK" PID : 4190 Case : /home/jk/OpenFOAM/jk-4.1/run/paperCase/solid-liquid two phase flows nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading g Reading hRef Creating twoPhaseSystem Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleInternalEnergy; } Calculating face flux field phi.particles Selecting diameterModel for phase particles: constant Selecting turbulence model type RAS Selecting RAS turbulence model kineticTheory Selecting viscosityModel Gidaspow Selecting conductivityModel Gidaspow Selecting radialModel SinclairJackson Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson kineticTheoryCoeffs { equilibrium off; e 0.8; alphaMax 0.62; alphaMinFriction 0.5; residualAlpha 0.0001; viscosityModel Gidaspow; conductivityModel Gidaspow; granularPressureModel Lun; frictionalStressModel JohnsonJackson; radialModel SinclairJackson; JohnsonJacksonCoeffs { Fr 0.05; eta 2; p 5; phi 28.5; alphaDeltaMin 0.05; } } Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } Calculating face flux field phi.air Selecting diameterModel for phase air: constant Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; } Selecting default blending method: none Selecting dragModel for (particles in air): GidaspowErgunWenYu Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting swarmCorrection for (particles in air): none Selecting heatTransferModel for (particles in air): RanzMarshall Calculating field g.h Reading field p_rgh Creating field dpdt Creating field kinetic energy K No MRF models present No finite volume options present Courant Number mean: 0.00180506 max: 2.27071 Max Ur Courant Number = 0 Calculating field DDtU1 and DDtU2 Starting time loop fieldAverage fieldAverage1: Starting averaging at time 0 Courant Number mean: 0.00180506 max: 2.27071 Max Ur Courant Number = 0 Time = 0.001 PIMPLE: iteration 1 MULES: Solving for alpha.particles MULES: Solving for alpha.particles alpha.particles volume fraction = 0.3 Min(alpha.particles) = 0.3 Max(alpha.particles) = 0.3 Constructing momentum equations GAMG: Solving for p_rgh, Initial residual = 0.991305, Final residual = 8.79876e-09, No Iterations 28 PIMPLE: iteration 2 MULES: Solving for alpha.particles MULES: Solving for alpha.particles smoothSolver: Solving for alpha.particles, Initial residual = 0.00150465, Final residual = 2.74931e-13, No Iterations 2 alpha.particles volume fraction = 0.315835 Min(alpha.particles) = -6.15607 Max(alpha.particles) = 1.72539 Constructing momentum equations #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? addr2line failed #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) addr2line failed #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) addr2line failed #5 Foam::dragModels::Ergun::CdRe() const addr2line failed #6 Foam::dragModels::GidaspowErgunWenYu::CdRe() const addr2line failed #7 Foam::dragModel::Ki() const addr2line failed #8 Foam::dragModel::K() const addr2line failed #9 Foam::BlendedInterfacialModel<Foam::dragModel>::K( ) const addr2line failed #10 Foam::twoPhaseSystem::Kd() const addr2line failed #11 ? #12 __libc_start_main addr2line failed #13 ? ************************************************** ************************************************** *** #3 and #5 indicates the main source of the error comes from the denominator is zero during the calculation of drag forces. I have tried to modify the case, but still haven't found the solution. Thank you very much. Kai Jiang Last edited by Jack_Kerouac; August 30, 2017 at 05:02. Reason: spelling mistake |
August 31, 2017, 05:05 |
#2 | |
Hi, from your log:
Regards, Tom |
August 31, 2017, 05:34 |
Kai Jiang
Rep Power: 9 |
Thanks so much for response. Does the wrong initial condition of phase fraction cause the problem?
August 31, 2017, 05:39 |
It could be, it could also be the time step since you have a Courant number larger dan 1. Maybe start with a smaller time step?
I cannot help if you do not share the details of the case (like your 0 folder, fvSchemes/fvSolution/controlDict, checkMesh result) Regards, Tom |
August 31, 2017, 05:52 |
Kai Jiang
Rep Power: 9 |
Thank you again. I'm uploading my case.
Regards, Kai Jiang |
August 31, 2017, 06:19 |
Kai Jiang
Rep Power: 9 |
the case always can't upload successfully. I will send an email to you. Regards Kai Jiang |
drag forces, solid-liquid flows, twophaseeulerfoam |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
2 phase flow liquid flow solid particles | sachin | OpenFOAM Running, Solving & CFD | 0 | August 28, 2008 17:51 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
