Convergence problem with pimpleFoam with OpenFOAM-v1706 |
August 29, 2017, 13:10 |
Katherine
Rep Power: 10 |
I recently installed OpenFOAM-v1706 released from ESI, and I am having trouble running a test case that I had previously ran without problems when I was using OpenFOAM version 3.0.1.
I discovered this problem when using the pimpleFoam solver in solving for incompressible, laminar flow over a 2D cylinder. I used the same setup as I had previously used in OpenFOAM 3.0.1., but when I ran the case using OpenFOAM-v1706, the pressure and velocity do not converge and there is very strange behavior in the residuals as compared to the working case ran with my previous build of OpenFOAM 3.0.1. The picture I attached are the residuals I have from running the case using pimpleFoam for 0.1 simulation seconds. To me, there is weird behavior in everything here - they do not behavior like I expect from using pimpleFoam (like the final graph shown here). My fvSolution file is as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-04; relTol 0.01; smoother DICGaussSeidel; } pFinal { solver GAMG; tolerance 1e-04; relTol 0.0; smoother DICGaussSeidel; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-4; relTol 0.01; } UFinal { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-04; relTol 0.0; } } PIMPLE { nNonOrthogonalCorrectors 0; nCorrectors 1; nOuterCorrectors 50; //pRefCell 0; //pRefValue 0; residualControl { U { tolerance 1e-4; relTol 0.0; } p { tolerance 1e-4; relTol 0.0; } } } relaxationFactors // 0 < relaxationFactors <= 1 { fields { p 0.3; pFinal 1; } equations { U 0.3; UFinal 1; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application pimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1; deltaT 0.01; writeControl runTime; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; adjustTimeStep yes; maxCo 5; functions { forces { type forces; functionObjectLibs ("libforces.so"); writeControl runTime; writeInterval 1; patches (fixedWalls); pName p; UName U; rho rhoInf; rhoInf 1; log true; CofR (0 0 0); // origin for moment calculation writeFields yes; binData { nBin 90; //output data into 20 bins direction (1 0 0); // bin direction format gnuplot; cumulative yes; } } forceCoefficients { type forceCoeffs; functionObjectLibs ("libforces.so"); writeControl runTime; writeInterval 1; patches (fixedWalls); writeFields yes; log true; patches (fixedWalls); // on cyl only pName p; UName U; dragDir (1 0 0); liftDir (0 1 0); pitchAxis (0 0 1); CofR (0 0 0); magUInf 10; // free stream velocity lRef 1; Aref 0.79; // cross sectional area rho rhoInf; rhoInf 1; origin (0 0 0); coordinateRotation { type EulerRotation degrees true; rotation (0 0 0); } binData { nBin 90; //output data into 20 bins direction (1 0 0); // bin direction format gnuplot; cumulative yes; } } } // ************************************************************************* // I'd like to ask if anyone has ran into similar problems with using pimpleFoam and OpenFOAM-v1706, or if there is anything that I am just missing that is included in the new release. I know that the residual behavior of this test case is strange, and I would appreciate any and all tips for uncovering what the problem is! |
September 5, 2017, 21:00 |
Katherine
Rep Power: 10 |
Sorry to answer my own question here but after some more debugging I found the source of my problem; using pure Crank Nicolson for the time derivatives was causing the blow-up in pressure residuals after the first time step. I switched to a backward scheme and I am much happier with the use of pimpleFoam - it behaves in a way that I understand
openfoam-v1706, pimplefoam, residuals |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
Problem with convergence | Iman Sengupta | FLUENT | 12 | June 23, 2015 08:44 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 12:32 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 05:48 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 14:43 |
