Turbulence models
Like Tree1Likes
  • 1 Post By Flowkersma
Old   August 23, 2017, 10:16
Default Turbulence models
Gebregziabher
gerie is on a distinguished road
Dear Respected members,
Since I am new to CFD simulations, I got a problem:-
1. When I run my case [k-epsilon turbulence model], I got a warning message, see the attached photo. What could be the possible mistake I made? I can not post process it (I can’t see any thing on the para-view).
2.What is the distinction that I get on the velocity profile after using turbulence model and the velocity profile I get with out using the turbulence model?
Kind regards,
Gerie
gerie is offline   Reply With Quote
Old   August 23, 2017, 11:46
Mikko
Flowkersma is on a distinguished road
Hi Gerie,
1. Seems like you are trying to link dynamically a library (swak4Foam) which you do not have installed. If you do not need swak4Foam, just remove the libs entry in system/controlDict which should look something like this:
libs
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
2. If the turbulence model that you are using is perfect (it is not), then the velocity profiles should look the same. Otherwise, the difference is the modeling error induced by the turbulence model. Obviously, I assume that you are doing things right so for instance you have adequate mesh resolution for the simulation without turbulence model (DNS).
Regards, Mikko
gerie likes this.
Flowkersma is offline   Reply With Quote
Old   August 24, 2017, 10:01
Gebregziabher
Dear Mikko,
Thank you so much, it works!
Kind regards,
Gerie
different zones, different turbulence models gmwsy FLUENT 5 June 17, 2020 16:42
Adding turbulence models to (reacting)TwoPhaseEulerFoam lavdwall OpenFOAM Running, Solving & CFD 0 February 3, 2017 04:04
y+ range for turbulence models babri FLUENT 1 August 30, 2016 18:39
Zero Equation Turbulence models stefan.gracik OpenFOAM Programming & Development 3 April 17, 2013 15:12
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
