August 18, 2017, 04:33 |
Defining position varying heat source
Rep Power: 9 |
Hi all. I have done a lot of research on this but can't find anything to solve my problem, but I am pretty new to OpenFOAM so hopefully this isn't a simple google away... anyway
I am trying to model a problem to compare to an analytic solution and this requires a very specific heat source term: V = Q*exp(-z/h) z is the vertical coordinate, Q and h are constants, so essentially a heat source that decays with height, but only in the middle of the domain. Using heat flux at the wall won't be the same, and I've looked into using fvOptions but all I've successfully done is create a constant heat source throughout the region. This was using a semiImplicitSource - I feel like using a codedSource might be my best option for a position dependent source, but I'm having no luck in getting it to work (probably due to lack of C++ skills). Is there an easier way to achieve what I'm doing? I found a few examples of fvOptions using time dependent sources and I tried to adapt them but none of them worked. Cheers sturgeon |
August 22, 2017, 15:07 |
Tobias Holzmann
Rep Power: 51 |
Hi and welcome to the forum,
you are on the right way. Personally I would implement it via the fvOptions and using a codedFixed function for that. Right now, I have no access to my server but I was thinking that I had published a fvOptions + coded tutorial. Just check them out later (don't know what my server is doing right now). Another option would be to implement it direct to the solver and manipulate the matrix by using the setValues() function and a cellZone. However, based on the fact that you said you have lack c++ knowledge, the fvOptions is the easiest and fastest way. You just have to keep in mind that you should divide everything by the volume (or multiply) ... ähm I guess divide.
Keep foaming, Tobias Holzmann |
August 23, 2017, 07:32 |
#3 | |
Rep Power: 9 |
Cheers sturgeon |
August 23, 2017, 07:45 |
Tobias Holzmann
Rep Power: 51 |
Right now I did not find a tutorial with fvOption published on my website. But in the header file there is an example that you can use. http://www.holzmann-cfd.de/index.php/en/tutorials-en
August 23, 2017, 08:36 |
#5 | |
Rep Power: 9 |
EDIT: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // harmonic { type scalarCodedSource; active true; selectionMode all; scalarCodedSourceCoeffs { fields (T); redirectType sourceCoeffs; selectionMode all; codeInclude #{ #}; codeCorrect #{ Pout<< "**codeCorrect**" << endl; #}; codeAddSup #{ const scalarField& V = mesh_.V(); const vectorField& C = mesh_.C(); const volVectorField& U = mesh().lookupObject<volVectorField>("U"); const volScalarField z = U.mesh().C() & vector(0,1,0); scalarField& hSource = eqn.source(); forAll(V, i) { hSource[i] -= 0.00098*exp(-z[i]/1000)*V[i]; } Pout << "***codeAddSup***" << endl; #}; codeSetValue #{ Pout<< "**codeSetValue**" << endl; #}; // Dummy entry. Make dependent on above to trigger recompilation code #{ $codeInclude $codeCorrect $codeAddSup $codeSetValue #}; } sourceTimeCoeffs { selectionMode all; // Dummy entry } } // ************************************************************************* // Aside from assigning the source to the entire domain rather than a selected portion of it, is anyone able to tell me if this is in line with what I am trying to achieve? Thanks |
August 23, 2017, 09:23 |
Tobias Holzmann
Rep Power: 51 |
As I said, I could not find the tutorial. Maybe I did not publish it because I do not publish all the tutorials. However, my second hint was the source code header:
energySource { type scalarCodedSource; active yes; name sourceTime; scalarCodedSourceCoeffs { selectionMode all; fields (h); codeInclude #{ #}; codeCorrect #{ Pout<< "**codeCorrect**" << endl; #}; codeAddSup #{ const Time& time = mesh().time(); const scalarField& V = mesh_.V(); scalarField& heSource = eqn.source(); heSource -= 0.1*sqr(time.value())*V; #}; codeSetValue #{ Pout<< "**codeSetValue**" << endl; #}; // Dummy entry. Make dependent on above to trigger recompilation code #{ $codeInclude $codeCorrect $codeAddSup $codeSetValue #}; } sourceTimeCoeffs { $scalarCodedSourceCoeffs; } }
August 23, 2017, 09:27 |
Rep Power: 9 |
August 23, 2017, 09:28 |
Tobias Holzmann
Rep Power: 51 |
Then you should specify your question more. Right now there is nothing one can get out of your questions. So what is the problem?
August 23, 2017, 09:46 |
#9 | |
Rep Power: 9 |
In an effort to understand exactly what is going on, I am trying to figure out how to see the internal variables during execution, ie, in: Code:
codeAddSup #{ const scalarField& V = mesh_.V(); const vectorField& C = mesh_.C(); const volVectorField& U = mesh().lookupObject<volVectorField>("U"); const volScalarField z = U.mesh().C() & vector(0,1,0); scalarField& hSource = eqn.source(); forAll(V, i) { hSource[i] -= 0.00098*exp(-z[i]/1000)*V[i]; } Pout << "***codeAddSup***" << endl; #}; Thanks for your help so far Tobi. |
August 23, 2017, 09:57 |
#10 |
Tobias Holzmann
Rep Power: 51 |
Are you aware of doxygen? If not, use it. The class fvOptions holds a reference to the object of the fvMesh class named mesh_ which you can access:
const volVectorField& U = mesh().lookupObject<volVectorField>("U"); const volScalarField z = U.mesh().C() & vector(0,1,0); Code:
forAll(C, cellI) { heSource[cellI] -= 0.00098*exp(-C[i].z()/1000)*V[i]; } Code:
forAll(C, cellI) { Pout<< "For cellID " << cellI << " we add a source of " << 0.00098*exp(-C[cellI].z()/1000)*V[cellI] << " while the z coordinate is " << C[cellI].z() << nl; heSource[cellI] -= 0.00098*exp(-C[cellI].z()/1000)*V[cellI]; }
May 10, 2020, 18:13 |
#11 |
René Thibault
Rep Power: 6 |
Hi!
I got similar issue. I applied only one source term on epsilon to the k-e turbulence model for 1D (x=0.001m, y=0.15m, z=0.001m) ABL simulation. Ny=150, so each cells center are at y1=0.0005m, y2=0.0015m, etc. Y+ is around 50. The y component I used in the formula is the center of the cells so, y-coordinate of internal cells (distance from the wall to the center of each cells,see text file, 3rd column). From the results, the calculation by the equation "epsilonSource[i]" are good since I printed out the results in a text file and verified the validity but the source term doesn't seem to be applied to the domain(see picture). The boundary wall seem to work (because in the epsilon patch I choose the BC "epsilonWallFunction") and then after, the values are null. The simulation stop after 11 step of iteration... Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // epsilonSource { type scalarCodedSource; selectionMode all; active true; fields (epsilon); name epsilonSource; codeInclude #{ #include "OFstream.H" #}; codeAddSup #{ const Time& time = mesh_.time(); const scalar us_ = 0.76; const scalar D1k_ = 1.44; const scalar D2k_ = 1.92; const scalar kappa_ = 0.41; const scalar sigmaEps_ = 1.17; const scalar Cmu_ = 0.09; const scalar z0_ = 3.3474e-05; const scalarField& y = mesh_.C().component(1); scalarField& epsilonSource = eqn.source(); // Apply the source forAll(y, i) { { epsilonSource[i] = (pow(us_,4)/(pow((y[i]+z0_),2))) *(((D2k_-D1k_)*sqrt(Cmu_)/pow(kappa_,2))-(1/sigmaEps_)); } std::ofstream file; file.open ("Epsilonterm.txt", std::ofstream::out | std::ofstream::app); file << time.value()<< " " << epsilonSource[i] << " " << y[i] << endl << "\n"; file.close(); }; #}; codeCorrect #{ #}; codeConstrain #{ #}; } // ************************************************************************* // Do you guys have any clue? Thank you very much! Best Regards, P.S.: I have tried your method and no luck. |
June 25, 2021, 06:26 |
#12 | |
UOCFD
Rep Power: 5 |
Hello Tobi, how can I access a topoSet defined cellSet inside the loop?? I have tried Code:
forAll(mesh.cellZones()[ignitionCellsCZ],i) Moreover, what is the difference between mesh and mesh_?? Thanks |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
