August 13, 2017, 21:00 |
Mesh Scale and Parameters
Rep Power: 10 |
Hello to all,
i have a little doubt. In my blockMesh file i wrote Code:
convertToMeters 1e-6; Thanks for help |
August 14, 2017, 03:05 |
#2 | |
Rodrigo
Rep Power: 16 |
This parameter only scales the magnitudes of your geometry introduced in the blockMeshDict-file.
August 23, 2017, 06:48 |
Robert
Rep Power: 12 |
Hello alberto,
as guin said, the factor only applies to your mesh. As the diffusivity doesn't depend on your mesh/domain size (e.g. the diffusivity of oxygen(g) - water(l) will be the same on all scales) you don't need to scale it as long as you don't scale other parameters, e.g. the viscosity. |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 16:15 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 20:34 |
[snappyHexMesh] Disturbance in the mesh after the addition of layers | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 0 | June 13, 2017 03:27 |
Mesh not modified while shape optimization | dolfyn | SU2 Shape Design | 0 | May 3, 2017 22:20 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
