simpleFoam + MRF properties: FATAL ERROR: not implemented |
August 3, 2017, 16:53 |
I'm running an incompressible case with simpleFoam and a rotating Zone with OF-dev. I set the constant/MRFProperties file as: Code:
MRF1 { cellZone rotor; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (amiRotor); origin (0.006423 0.149165 0.03985); axis (0 0 1); omega 167; } Code:
Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 2500 steps. Reading field p AMI: Creating addressing and weights between 823 source faces and 487 target faces AMI: Patch source sum(weights) min/max/average = 0.923989, 1, 0.99915 AMI: Patch target sum(weights) min/max/average = 0.691331, 1, 0.980684 AMI: Creating addressing and weights between 10174 source faces and 3772 target faces AMI: Patch source sum(weights) min/max/average = 0.999999, 1, 1 AMI: Patch target sum(weights) min/max/average = 0.999999, 1, 1 AMI: Creating addressing and weights between 2030 source faces and 4670 target faces AMI: Patch source sum(weights) min/max/average = 0.997628, 1, 0.999993 AMI: Patch target sum(weights) min/max/average = 0.999981, 1, 1 AMI: Creating addressing and weights between 220 source faces and 277 target faces AMI: Patch source sum(weights) min/max/average = 0.878276, 1, 0.989146 AMI: Patch target sum(weights) min/max/average = 0.977914, 1, 0.999491 AMI: Creating addressing and weights between 3948 source faces and 7162 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 AMI: Creating addressing and weights between 57188 source faces and 37254 target faces AMI: Patch source sum(weights) min/max/average = 0.99994, 1.00043, 1.00001 AMI: Patch target sum(weights) min/max/average = 0.993209, 1.00036, 1 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Selecting laminar stress model Stokes Creating MRF zone list from MRFProperties creating MRF zone: MRF1 No finite volume options present Starting time loop Time = 1 --> FOAM FATAL ERROR: Not implemented From function Foam::tmp<Foam::Field<Type> > Foam::coupledFvPatchField<Type>::gradientInternalCoeffs() const [with Type = Foam::Vector<double>] in file lnInclude/coupledFvPatchField.C at line 185. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::coupledFvPatchField<Foam::Vector<double> >::gradientInternalCoeffs() const at ??:? #3 Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, Foam::SymmTensor<double> >::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #4 Foam::fv::gaussLaplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::fv::laplacianScheme<Foam::Vector<double>, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) at ??:? #7 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #8 Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::fvm::laplacian<Foam::Vector<double>, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #9 Foam::linearViscousStress<Foam::laminarModel<Foam::IncompressibleTurbulenceModel<Foam::transportModel> > >::divDevRhoReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:? #10 ? at ??:? #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 ? at ??:? Aborted |
June 23, 2019, 11:26 |
Greg
I have encountered a similar error message in a simulation that I am attempting to run. Could you elaborate as to what kind of error on patch definition you had and how you fixed it? Thanks |
April 11, 2021, 04:11 |
Mahmoud
Rep Power: 6 |
Hi. I encountered the same poblem. Have you managed to solve this issue?
MRF and topoSet problem- Rotating volume doesn't rotate | andreas0209@hotmail.com | OpenFOAM | 1 | April 4, 2021 14:35 |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 12:59 |
Using a new implemented viscosity model with simpleFoam | TemC | OpenFOAM Running, Solving & CFD | 6 | March 8, 2017 04:07 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 23:43 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
