Porous Medium: Obtaining D/F coefficients from Pressure-Drop Experiment
Like Tree6Likes
  • 2 Post By sdfij6354
  • 2 Post By SebT
Old   August 3, 2017, 13:15
Default Porous Medium: Obtaining D/F coefficients from Pressure-Drop Experiment
Alwin
sdfij6354 is on a distinguished road
I want to implement the pressure drop along a netting into my OpenFOAM case though the Porous Media and Darcy-Forchheimer-Equation.
OpenFOAM requires the coefficients D and F which I calculated according to
Darcy-Forchheimer law for specifying Porous Zones
F = 2 * a / (deltaP * dx)
D = b / (viscosity * dx)
With deltaP being the pressure drop and dx the length if the Porous Medium in x-Direction (0.5m). "viscosity" is the dynamic viscosity of air (1.789*10^-5 in my case, 20°C and sea level).
First, I measured the pressure drop along the real screen in a wind-tunnel experiment.
I obtained the variables a and b by fitting a second degree polynomial using R-Studio and the curve dp=f(v):
x <- c(7.4,4.3,3.1,0.0)  // inlet velocity
y <- c(67.4,33.2,21.4,0.0) // measured pressure drop
lm(formula = y ~ x + I(x^2))
Results were:
Coefficients:
(Intercept)            x       I(x^2)
   -0.06875      5.57380      0.48012
Hence,
a = 0.48012
b = 5.57380
Then I calculated F and D
> velocity <- 4.2
> deltaP <- a*velocity^2+b*velocity
> print(deltaP)
[1] 31.87928
> dx <- 0.5
> viscosity <- 0.00001789
> F <- 2 * a / (deltaP * dx)
> D <- b / (viscosity * dx)
> print(F)
[1] 0.06024227
> print(D)
[1] 623119.1
and inserted it into fvOptions in /case/constant.
    explicitPorositySourceCoeffs
        selectionMode   cellZone;
        cellZone        porousBlockage;
        type            DarcyForchheimer;
        DarcyForchheimerCoeffs
            d   (623119.1 -1000 -1000);
            f   (0.06024227 650 650);
            coordinateSystem
                type    cartesian;
                origin  (0 0 0);
                coordinateRotation
                    type    axesRotation;
                    e1  (1 0 0);
                    e2  (0 1 0);
I've defined the cells for the Porous Medium using the command "topoSet" and defining the cellZone boundaries in the file "topoSetDict" in /case/system.
However, when running a test run with a simpleFoam case and measuring the pressure drop along the x-Axis in ParaView, I obtain just a deltaP of ~16, compared to the ~32 I should have according to the polynomial equation:
> a <- 0.48012
> b <- 5.57380
> v <- 4.2
> deltaP=a*v^2+b*v
> print(deltaP)
[1] 31.87928
I've also attached my complete case. Did I do anything wrong in calculating the D/F coefficients? Or is my case set up in the wrong way to verify the measured/simulated pressure drop across the screen? I appreciate any help
I've also read papers where the Porous-Medium / Darcy-Forchheimer-Equation was implemented using K (permeability) and Y (nonlinear momentum loss coefficient), but I don't know how to convert these values into D/F required by openFoam. Is there a way do to it and where could I find further information on how to do it?
mayursathe and Takue like this.
sdfij6354 is offline   Reply With Quote
Old   August 3, 2017, 14:22
alberto
dewey is on a distinguished road
Take a look to this file.
https://es.scribd.com/document/23868...orousInter-v11
The coefficient D specifies the viscous resistance , it is calculated as 1/K where k is the permeability, and Fij specifies inertial resistance, i dont know if you need the coeeficient F.
dewey is offline   Reply With Quote
Old   August 3, 2017, 15:10
Alwin
Thank you for you answer, I will take a look at the document (need to sign up first though).
However, I'm wondering about D = 1/K. Doesn't depend D in some way also on the thickness of the porous media? Or is this irrelevant for OpenFOAM?
Since my K = (3.44*(10^-9)*(epsilon^1.6) with epsilon = screen porosity = 0.4 and hence K = 7.94062E-10, my D would be = 1259347462.
So I set
D = (1259347462 -1000 -1000) since the resistance is only in X-Direction and
F = (0 0 0).
This leads to a pressure drop of ~55 along the screen, which is still a bit off.
manuc and ombretta like this.
Old   August 3, 2017, 15:31
alberto
Take a look to this files, I hope this could help you.
It is irrelevant for OF. K is a resistance for the fluid.
I dont know if that is the way to do the resistance only in the X-direction, You could put the same value in the three directions, setting that it is a isotropic medium. Are you trying to do a 2D simulation? because if you want to do that, you only have to set the faces as empty.
I am working with porous media too, but I am not an expert, if I can help you in something, let me know.
https://www.dropbox.com/s/djktzs0umq...efano.pdf?dl=0
https://www.dropbox.com/s/ivb3igaj7o...r_v11.pdf?dl=0
https://www.dropbox.com/s/n127zo90so...eport.pdf?dl=0
https://www.dropbox.com/s/sxjj5hvu66j9gmd/leer.pdf?dl=0
Old   August 6, 2017, 11:38
Alwin
I have a question regarding to this paper:
μ(kg·m−1·s−1) is defined as the "dynamic viscosity" - of air?
In my case, air is flowing through a tube with a netting in the middle. I want to implement this netting as my porous media.
I'm wondering, because I don't get feasible results using the equation for deltaPressure in the reference:
deltaPressure = (μ/k)*velocity
I have my permeability k calculated as 7.94062E-10. When assuming a dynamic viscosity of air at (μ) 20°C of 15.11*10^-6 m-2/s, I get unrealistic results for my pressure drop value. E.g. deltaPressure = 16897 with a velocity of 0.75 m/s, even though it should be around 4.5 according to my measurements.
Old   August 7, 2017, 10:15
alberto
Yes, it is the dynamic viscosity
You are trying to run your simulation with porousSimpleFoam right?
Do you know that this incompresible solver works with kinematic pressure ?
When I started, first of all I did the example of the page 73
https://www.dropbox.com/s/2ztsdtebjv...oleum.pdf?dl=0
and after i did an experiment for validate.
You should do that excercise and simulate to compare.
Old   August 7, 2017, 11:25
Sebastian
sepp.zell is on a distinguished road
Maybe you can also have a look at my comparison between Darcy's law and the OpenFOAM simulation.
porousSimpleFoam - comparison to Darcy's law
There it is shown that OpenFOAM might not work for flow through porous media. Maybe this is the same in your test case. I discussed this issue with the developers. In the moment there is no fix for it. One suggestion was to try different schemes.
You should also have a look at a plot for the velocity over the x-axis. There are some spurious oscillations over your porous netting. This seems to be the reason that the pressure drop is not computed correctly (see also here: https://bugs.openfoam.org/view.php?id=134).
sepp.zell is offline   Reply With Quote
Old   September 13, 2017, 11:14
Sebastian Tück
SebT is on a distinguished road
Dear Alwin,
i looked a little bit into your problem and think i can solve some Problems. First of all you are calculating a regression curve with y-intercept. Since there is no pressure drop at 0 speed there should be none. Hence:
dp = a * v² + b * v
The Darcy-Forchheimer equation can be written as:
dp/dx = mu * d * v + 1/2 * f * rho * v²
with dx being the thickness of the porous medium.
Coefficient comparisson leads to following expressions for d and f:
f = (2 * a) / (rho * dx)
d = b / (mu * dx)
I attached a libre file to automatically calculate the coefficients from meassurments.I also set up a test case to check the values. When calculating the pressure drop with your settings I get a relative diviation regarding your measurments of 5.04 % for 7.4 m/s and 3.01 % for 4.3 m/s, which i consider completely ok. Maybe you forgot to multiply the pressure by the fluid density? Incompressible solvers in OpenFOAM use kinematic pressure pk which is defined as pk=p/rho. So to obtain static pressure you need to multiply with the fluid reference density.
I hope this helps with your Problem. If you need the test case let me know and I'll send it to you.
manuc and keitaro7_14 like this.
SebT is offline   Reply With Quote
Old   February 11, 2018, 02:28
Ramana
svramana is on a distinguished road
I am working on porous media on OpenFoam, i have a question about porosity and calculation of D and F coefficients. Can i have access to the above files ?
Reagrds,
S.V.Ramana
svramana is offline   Reply With Quote
Old   March 10, 2018, 10:30
Default porous media
DEEPTI
deeptiof is on a distinguished road
there are two coefficient D and F used in darcy forchhiemer equation for porous media modelling.
I have one doubt that why F value is set to zero for most of the cases??
deeptiof is offline   Reply With Quote
Old   July 4, 2019, 05:40
ombretta bistoni
ombretta is on a distinguished road
How did you find this relationship between porosity and permeability?
Thank you.
ombretta is offline   Reply With Quote
Old   November 22, 2023, 18:33
West barkley
west barkley is on a distinguished road
Originally Posted by SebT View Post
Dear Alwin,
dp = a * v² + b * v
d = b / (mu * dx)
Hi, could you please help me with this question. where are the dp values? where can i find them to feed into the table?
west barkley is offline   Reply With Quote
Polydispersed phase pressure drop with drop size Laksh CFX 1 June 8, 2017 19:56
pressure porous medium acchavesg FLUENT 1 October 16, 2016 04:18
How to model pressure drop without modeling porous media Sanyo CFX 9 May 27, 2016 11:50
Calculate pressure drop coefficients in x,y,z, direction georgcfd FLUENT 0 April 16, 2010 08:09
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
