Reading the patch labels
Like Tree2Likes
  • 2 Post By Sugajen
Old   August 3, 2017, 11:46
Default Reading the patch labels
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
I need patch ID for some calculations in the kEpsilon.C .
I found on forum that patch can be accessed like:
label patchID = patch.boundaryMesh.lookupPatchID("patchName")
My questions are:
1. when I am compiling the EXE for this, the patchName does not exist as such since I have not run any solver such as simpleFoam or pisoFoam, or kEpsilon file does not have the mesh details. So, how will it get the patchID given the patchName.
2. I get an error: 'patch' was not declared in this scope
3. How can I read patchID as I read other constants such as Cmu_, sigmaK_ etc from coeffDict?
I tried:
kEpsilon::kEpsilon(..,...,..):RASModel(....),
inletID
        dimensioned<label>::lookupOrAddToDict
            "inletID",
	    1
I get the error: no matching function for call to 'Foam::dimensioned<int>::lookupOrAddToDict(const char [8], int)'
So, how should I get the labelID for the patch names I have described in blockMeshDict?
vcvedant is offline   Reply With Quote
Old   August 3, 2017, 15:14
Sugajen
Sugajen is on a distinguished road
Hi Vedamt,
string patchName = mesh.boundaryMesh()[patchI].name();
Is this what you're looking for?
Sugajen is offline   Reply With Quote
Old   August 3, 2017, 15:29
Vedamt Chittlangia
No. I my idea is to get the patchID from the patchName.
But i don't have patchName available in the RASModel.C or kEpsilon.C
So, I want to get that information from the user.
Old   August 3, 2017, 15:37
Sugajen
I see what you say. Do have a look at this,
forAll(mesh.boundaryMesh(), patchI)
	string patchNameNeeded = "patchNameInBlockMesh";
	if (patchName.find(patchNameNeeded) != std::string::npos)  // checks if "patchNameInBlockMesh" is in the current patchName
ruloz and dasa like this.
Old   August 3, 2017, 15:59
Vedamt Chittlangia
Thank you Sugajen, this explains well what I needed.
I will post in couple of days when I am able to run the case using this implementation.
kepsilon, label, lookup error, mesh, patch
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 18:36
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 11:45
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 12:25
[Commercial meshers] FluentMeshToFoam CRT OpenFOAM Meshing & Mesh Conversion 3 May 24, 2012 17:07
