Regarding unbounded alpha values -interFoam |
July 31, 2017, 07:13 |
Phanindra
Rep Power: 13 |
Dear Foamers,
I'm using interFoam for flow over flat plate. Over the course of time I see the alpha values increasing beyond 1. With refined mesh , with all schemes including upwind. . Can anyone of you help me to overcome this issue I'm attaching fvschemes,fvsolution and p_rgh files for your perusal.fvSchemes.txt fvSolution.txt p_rgh.txt |
July 31, 2017, 07:56 |
Kevin van As
Rep Power: 20 |
You can use a limited scheme as convective scheme for the alpha equation, for example:
div(phi,alpha) Gauss limitedVanLeer 0 1; //vanLeer; div(phirb,alpha) Gauss limitedLinear 0 1; //linear; |
August 25, 2017, 20:29 |
Santiago Marquez Damian
Rep Power: 24 |
Hello, the MULES integrator mostly overrides the fluxes computed by the limiters, therefore the whole thing is related to MULES. Try to reduce your time-step or using more nAlphaSubCycles.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
July 5, 2018, 04:32 |
#4 | |
Elham
Rep Power: 16 |
As my alpha was unbounded I used the following expression. Code:
alpha1=max(scalar(0.0),min(alpha1,scalar(1.0))); Cheers, Elham |
March 6, 2019, 08:05 |
Mahmoud Aboukhedr
Rep Power: 12 |
March 6, 2019, 09:06 |
Rep Power: 24 |
Hello, that method is non-conservative and should be avoided.
Regards
March 6, 2019, 09:34 |
#7 | |
Mahmoud Aboukhedr
Rep Power: 12 |
Currently, I see an increase in my alpha value due to the unbounded alpha max and min |
May 14, 2020, 11:10 |
Liz
Rep Power: 6 |
Hi Mahmoud, did you solve this problem? I'm saving the same problem right now with my simulation.
Regards |
September 25, 2021, 06:05 |
#9 |
Hamid
Rep Power: 14 |
It may be a little late to give an answer here, but have you tried isoAdvectors i.e., interIsoFoam? It gives bounded alpha.water fields
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Mapping values from 2D mesh to 3D mesh boundary during runtime | benk | OpenFOAM Programming & Development | 1 | June 13, 2014 02:39 |
InterFoam - Dambreak - alpha | erncyc | OpenFOAM | 0 | July 4, 2012 11:18 |
Bounded scheme gives unbounded solution | su_junwei | OpenFOAM Running, Solving & CFD | 3 | November 18, 2011 02:35 |
Alpha to be phased out | Heiko Gerhauser | Main CFD Forum | 17 | July 25, 2001 14:40 |
