LaunderSharmaKE diverges and return 'nan' error
Like Tree1Likes
  • 1 Post By vcvedant
Old   July 26, 2017, 17:02
Default LaunderSharmaKE diverges and return 'nan' error
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
I am simulating turbulent flow over flat plate using low Reynolds number model: LaunderSharmaKE.
Boundary conditions:
Inlet: U (30, 0 ,0), p 0, k 0.13, epsilon 2.56, nut calculated.
Outlet: zeroGradient
top: zeroGradient
plate: U (0 0 0), p - zeroGradient, k 1e-10, epsilon 1e-8, nut 0.
I am using simpleFoam solver but after running for 14 iterations my solution diverges and I receive an error:
wrong toke type - expected Scalar, found on line 0 the work 'nan'.
When I checked the log files I found that k and epsilon have very large min and max bounds.
Can someone help me resolve this or guide me in the write direction?
Thanks,
Vedant
atulkjoy likes this.
vcvedant is offline   Reply With Quote
Old   July 29, 2017, 10:00
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
You might want to check the following points:
1. [Mesh] Y+ value should be at most order of 1 on the plate boundary.
2. [Boundary Condition] Inlet: p zeroGradient, Outlet: p 0
Best regards,
Fumiya
[Personal]
fumiya is offline   Reply With Quote
Old   July 29, 2017, 11:29
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
Have You tried to set relaxations factor?
Check my post:
Sudden divergence of simulation
Or it could be the mesh problem too.
EDIT:
'nan' means not a number.
sheaker is offline   Reply With Quote
Old   July 29, 2017, 16:53
Vedamt Chittlangia
Thank you all for your reply.
I think it was a mesh problem. I created a mesh in pointwise for OpenFOAM and used that which was giving me errors. I created a new mesh (using the same parameters as pointwise) using blockMeshDict which was able to converge.
I checked the mesh imported from pointwise using checkMesh and found no errors. My y+ was 0.3. So, I don't understand what was the problem with the previous mesh?
divergence, low re k-e, openfoam 2.2.2, turbulence modeling
