July 24, 2017, 06:32 |
Running OpenFOAM on LSF platform
Dominic
Rep Power: 9 |
Dear Foamers,
Currently I am trying to run OpenFoam on LSF platform. Even though I have read many reference materials, but I still can't make it works. I really need help on this. Would anyone shed some light on this? Any comments are appreciated. Thank you. My script is shown below: <<<<<<<<<<<<<<<<<snappy.lsf>>>>>>>>>>>>>>> Code:
#! /bin/bash #BSUB -n 264 #BSUB -q model_queue_high #BSUB -e openmpi_%J.err #BSUB -o openmpi_%J.out #BSUB -R "span[ptile=8]" export PATH="/usr/mpi/gcc/openmpi-1.3.2/bin:$PATH" export LD_LIBRARY_PATH="/usr/mpi/gcc/openmpi-1.3.2/lib64:$LD_LIBRARY_PATH" for i in $LSB_HOSTS do echo $i >> machineFile done source /prod_model/home/R2test/OpenFOAM/OpenFOAM-2.4.0/etc/bashrc mpirun -np 264 --hostfile machineFile snappyHexMesh -overwrite -parallel > Smesh.log And I type Code:
bsub < snappy.lsf All the output message are attached here as reference. openmpi_784507.out.txt openmpi_784507.err.txt machineFile.txt Any ideas? Many Thanks! |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
[Docker] Running OpenFoam 4.1 from script without user intervention | fnellmeldin | OpenFOAM Running, Solving & CFD | 9 | June 7, 2017 19:04 |
3D simulations OpenFoam running too low(more 1 000 000 elements) Suggestion speed up? | silvai | OpenFOAM Running, Solving & CFD | 4 | April 6, 2017 12:44 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 07:15 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
