First Step Parallel Simulation and HPC
Like Tree1Likes
  • 1 Post By Svensen
Old   July 13, 2017, 17:32
Exclamation First Step Parallel Simulation and HPC
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
I'm moving my first steps in the world of parallel simulation and HPC. If i understood corectly, with parallel simulation i can divide my domain and let the single core of my CPU solve that part of domain assigned. So, if i had a quad core CPU, i could divide the domain in 4 part, and not more. Is it right?
I run the pitzDailyExptInlet case, with my own PC, in the normal and parallel way but i didn't notice a substantial difference of velocity. Is my sensation wrong?
Now a question for people who have already worked with HPC system.
It is the first time i work with HPC system and i'm not sure about the structure of the system. To submit a job i have to specify:
1- The number of node NN
2- The number of CPUs (ncpus) max 16 in my case
3 -The number of MPI tasks per node (mpiprocs)
I don't understand the meaning of 1 and 3.
Suppose to choose these numbers (1,16,1) for the three value, this means that i have to decompose my domain in 16 regions, is it right?
Last question: how does decomposePar work? Which criterion i should use to divide my domain? Which directions i should choose?
Thanks for help.
FlyBob91 is offline   Reply With Quote
Old   July 14, 2017, 05:17
Svensen is on a distinguished road
Originally Posted by FlyBob91 View Post
Hello to all,
decomposePar subdivides your computational domain on subdomains according to system/decomposeParDict.
I suggest you to use 'scotch' method, which will do subdivision automatically without any extra input data.
The number of subdomains in system/decomposeParDict could be arbitrary, but normally it is N or 2*N, where N is a total number of cores.
Also, in HPC system you don't need to specify all (1)-(3) parameters. You should know which management system runs on your HPC station. If it is SLURM, then you can type 'sbatch -n 16 icoFoam -parallel', for example, where '16' is a number of threads (it should be equal to a number of subdomains (system/decomposeParDict)).
FlyBob91 likes this.
Svensen is offline   Reply With Quote
Old   July 14, 2017, 09:29
FlyBob91's Avatar
Thank you Svensen, you clarified me some doubts.
To be precise my scheduling system is PBS.
Best Regards,
Roberto
Old   July 14, 2017, 10:05
Normally for every HPC cluster there are some scripts, which used to submit a task for computing. The scripts generally are prepared by cluster administrators.
Error while running a Fluent Simulation in Hpc cluster averageindianjoe FLUENT 0 February 7, 2017 06:10
help to run CFX simulation via HPC, please happy CFX 19 February 28, 2016 18:18
Job submit code in HPC for Workbench beyonder1 CFX 0 January 6, 2016 12:18
Ansys HPC licensing policy assafwei ANSYS 0 June 29, 2014 17:00
massive parallel run messed up lustre file system matthias OpenFOAM 1 May 28, 2011 17:18
