July 12, 2017, 05:24 |
SIMPLE and SIMPLEC produce different results
Rep Power: 11 |
I've tested a SIMPLEC vs SIMPLE algorithms for my simulation and found that SIMPLEC produced a significantly higher velocities compared to SIMPLE.
The case was the same. The only things that were changed were: 1) consistent yes; 2) no relaxation for pressure; relaxation for velocity 0.9 A screenshot with comparative cross-sections is attached. From my own experience I could say that result with SIMPLE seems to be correct. But why SIMPLEC gives a different result ? The residual plots are attached. It is a pulsatile flow with pulse period of 0.77 s. I've simulated 5 full periods. I can upload the case if it is necessary. |
July 12, 2017, 18:24 |
Joachim Herb
Rep Power: 22 |
Are you sure, that residual values of 0.1 (for pressure) are low enough? Normally they should be below 1E-4.
July 13, 2017, 13:07 |
Joshua
Rep Power: 10 |
You could also try smaller time steps.
July 13, 2017, 13:34 |
Rep Power: 11 |
I think that time step was small enough (dt = 0.0001 s).
July 13, 2017, 13:36 |
Joshua
Rep Power: 10 |
What is your Courant number?
July 13, 2017, 13:46 |
Rep Power: 11 |
Plot for Courant number is attached
July 13, 2017, 14:01 |
Daniel P. Combest
Just a question here...are you using a steady solver (simpleFoam) for a transient flow? If so then your time step size has no influence on the solution since there is no time derivative in the simpleFoam solver. Furthermore, your differences in solution are just comparisons of two un-converged flow fields. With that, what solver are you using?
July 13, 2017, 14:02 |
Rep Power: 11 |
I used pimpleFoam
July 14, 2017, 07:30 |
#10 |
Rep Power: 11 |
As you can see in the attached file, Courant number is high only for a few cells and doesn't affect the overall solution.
July 14, 2017, 07:57 |
#11 |
Oskar
Rep Power: 11 |
Hello.
Your are wrong. Even one bad cell crashes Your solution. Prepare better mesh to get Max Courant Number below 1. |
July 14, 2017, 10:24 |
#12 |
Daniel P. Combest
@Svensen Again, just curious,
July 14, 2017, 12:13 |
#13 |
Rep Power: 11 |
Log files are attached.
Domain was initially meshed by ANSYS, I've just imported the mesh to OpenFOAM by fluent3DMeshToFoam. |
July 16, 2017, 19:13 |
#14 |
if you want to use large courant number such as 100-200 and compare SIMPLE and SIMPLEC time accurate simulations move on from pimpleFoam to transientSimpleFoam - this solver is discussed and attached somewhere in this forum cant remember which thread actually
July 17, 2017, 12:44 |
#15 |
Rep Power: 11 |
I think that the actual problem is this set of few high Courant cells. I don't know why they were created by mesher. Maybe it is an OpenFOAM problem, because meshing was done by ANSYS, which is commercial and highly tested software.
If it would be possible to omit these cells then the problem would be solved. However it is not an easy task. According to my experience, If I just manually remove them, then some other cells will have a high Courant... |
July 18, 2017, 03:17 |
#16 |
Rep Power: 21 |
This is not because fluent is highly tested, but rather because it limits accuracy when faced with bad mesh cells without user intervention. OpenFOAM on the other hand needs the user to step in. Nearly all tutorial settings are for accuracy. Not for bad mesh quality. Your mesh is not bad on average, but as pointed out a single bad cell is enough to lower your convergence rate immensely. The main problem here is the non orthogonality. Now you can either work with limiters and change your schemes, or simply create a better mesh. For this geometry snappyHexMesh should work absolutely fine.
July 18, 2017, 10:21 |
#17 |
Daniel P. Combest
The issue here is the tetrahedra cells. OpenFOAM can use them but you will get poor results from them without additional steps. Since I run away from tetrahedra cells and stick with hex-dominant meshes, from memory you can:
I actually suggest remeshing with a hex dominant mesher and save yourself some time. I used the two above steps during my PhD on really complicated geometries and adopted the ABT (anything by tet) approach was the best option in OpenFOAM. good luck. |
openfoam-dev, simple, simplec |
Ask help wiht a SIMPLE Method on compressible flow. | universez | Main CFD Forum | 0 | February 8, 2010 11:38 |
SIMPLEC slewness correction results in divergence | jrg | FLUENT | 2 | September 26, 2007 04:25 |
Making SIMPLE converge faster | Fabio | Main CFD Forum | 4 | April 9, 2006 12:35 |
SIMPLE and SIMPLEC | Aditya | Main CFD Forum | 2 | January 12, 2006 20:11 |
SIMPLEC on Co-located Variables | Aditya | Main CFD Forum | 0 | January 6, 2006 05:59 |
