SimpleFoam Stops Without Error Message
Like Tree2Likes
  • 1 Post By arjun
  • 1 Post By ARTisticCFD
Old   July 8, 2017, 12:14
Default SimpleFoam Stops Without Error Message
Moe Alams
MoeCFD is on a distinguished road
Hello All,
I am trying to run simpleFoam. I created the mesh using SnappyHexMesh and and an stl file that I have. It is 3D problem with one inlet and one outlet, below are the boundary conditions that I am using and the simulation settings.
SimpleFoam stops without an error message. I provided simpleFoam output below as well. Any idea why this is happening?
For pressure:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    fixedWalls_patch20083
        type            zeroGradient;
    left
        type            fixedValue;
		value			uniform 1e-3;
    right
        type            fixedValue;
		value			uniform 0;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    frontAndBack
        type            zeroGradient;
For velocity
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
        type            fixedValue;
		value			uniform (0 0 0);
    left
        type            zeroGradient;
    right
        type            zeroGradient;
    bottom
        type            fixedValue;
    top
        type            fixedValue;
    frontAndBack
        type            fixedValue;
Here is my fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-07;
        relTol          0.1;
    U
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-07;
        relTol          0;
    U
        solver           smoothSolver;
        smoother         GaussSeidel;
        tolerance        1e-12;
        relTol           0;
        nSweeps          1;
    p
        solver           GAMG;
        tolerance        1e-9;
        relTol           0.1;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-6;
        U               1e-6;
	pRefCell 0;
	pRefValue 0;
relaxationFactors
    p               0.15;
    U               0.9;
When I run the command SimpleFoam to start the simulation based on the inputs shown above, I get the following (see below)
which doesn't show me what went wrong with the simulation. Is it something with the way I defined the boundary conditions or simulation settings?
On a separate note, I am running the simulation in serial for now. However, I created the Mesh by running SnappyHexMesh in parallel then used reconstruct to put it together.
Build  : 4.1
Exec   : simpleFoam
Date   : Jul 07 2017
Time   : 21:57:43
Host   :
PID    : 592
Case   :
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p      tolerance 1e-06
    field U      tolerance 1e-06
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
No MRF models present
No finite volume options present
Starting time loop
Time = 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.219962, Final residual = 2.60365e-08, No Iterations 10
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 4.89906e-08, No Iterations 11
DILUPBiCG:  Solving for Uz, Initial residual = 0.143777, Final residual = 9.97743e-08, No Iterations 9
moe@DESKTOP:/example$
MoeCFD is offline   Reply With Quote
Old   July 8, 2017, 17:28
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Your endTime (settings in system/controlDict) is 1?
alexeym is offline   Reply With Quote
Old   July 9, 2017, 12:44
Moe Alams
Originally Posted by alexeym View Post
Hi Alexeym,
Thank you for your reply. Here is the controlDict settings. I have it at 1000
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       latestTime;
startTime       0.0;
stopAt          endTime;
endTime         1000.0;
deltaT          1;
writeControl    runTime;
writeInterval   1000;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
Old   July 9, 2017, 13:17
Alexey Matveichev
I missed the fact, that simpleFoam exits just after momentum predictor, so the problem is somewhere in your environment or installation. simpleFoam tutorial cases run without problems? What is mesh size? How OpenFOAM was installed?
Old   July 9, 2017, 13:42
Moe Alams
Alexey - The tutorials were ran without issues. In regard to the installation, I followed the instructions from OpenFOAM.org.
In regard to the mesh, I had an stl file of a porous network. I used blockMesh to create a background and then SnappyHexMesh to eliminate the non porous region. Below are the mesh information:
x - length = 0.085 m (no of mesh =88) thus cell length = 0.000967 m
y - length = 0.2029 m (no of mesh =215) thus cell length = 0.000967 m
z - length = 0.081 m (no of mesh =84) thus cell length = 0.000967 m
The geometry represents a cube where the flow is along the y direction.
Along the y axis we have an inlet to the left, and outlet to the right. Then for the other 4 faces, we have top, bottom, and frontAndBack
Here, I ran the help on simpleFoam just to check if SimpleFoam is Ok.
moe@6:/example$ simpleFoam -help
Usage: simpleFoam [OPTIONS]
options:
-case <dir> specify alternate case directory, default is the cwd
-noFunctionObjects
do not execute functionObjects
-parallel run in parallel
-postProcess Execute functionObjects only
-roots <(dir1 .. dirN)>
slave root directories for distributed running
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
Using: OpenFOAM-4.1 (see www.OpenFOAM.org)
Build: 4.1
Old   July 9, 2017, 16:44
Alexey Matveichev
Could you also post checkMesh output? Or maybe if you case is not under NDA, you can post whole case? So (a) the error could be reproduced, (b) the real origin of the error could be found and reported upstream.
Old   July 9, 2017, 17:20
Moe Alams
Alexey,
Again thank you for you patience and will to help. Below is the output of the checkMesh
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 4.1
Exec   : checkMesh
Date   : Jul 09 2017
Time   : 15:16:51
Host   :
PID    : 237
Case   :
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            447817
    internal faces:   383810
    cells:            146412
    faces per cell:   5.68005
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     115422
    prisms:        8106
    wedges:        0
    pyramids:      0
    tet wedges:    2277
    tetrahedra:    4
    polyhedra:     20603
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            4   13574
            5   7029
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
   *Number of regions: 5
    The mesh has multiple regions which are not connected by any face.
  <<Writing region information to "0/cellToRegion"
  <<Writing region 0 with 146408 cells to cellSet region0
  <<Writing region 1 with 1 cells to cellSet region1
  <<Writing region 2 with 1 cells to cellSet region2
  <<Writing region 3 with 1 cells to cellSet region3
  <<Writing region 4 with 1 cells to cellSet region4
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
            frontAndBack     2644     3118  ok (non-closed singly connected)
                    left      707      825  ok (non-closed singly connected)
                   right      717      848  ok (non-closed singly connected)
                  bottom      866     1078  ok (non-closed singly connected)
                     top     1054     1298  ok (non-closed singly connected)
    fixedWalls_patch20083    58019    72015  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (0.0663932 0.0736 0.235492) (0.151514 0.2765 0.316507)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-6.14891e-17 7.68427e-18 1.80846e-17) OK.
    Max cell openness = 3.85128e-16 OK.
    Max aspect ratio = 5.61657 OK.
    Minimum face area = 5.01235e-09. Maximum face area = 3.59669e-06.  Face area magnitudes OK.
    Min volume = 8.71886e-13. Max volume = 2.35087e-09.  Total volume = 0.000128431.  Cell volumes OK.
    Mesh non-orthogonality Max: 54.2248 average: 10.454
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.26928 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Old   September 11, 2019, 08:42
Arne
arsimons is on a distinguished road
Hi fellow Foamers
I recently had a similar problem. In my case, it was due to a dynamic mesh. I had a rotating object which I placed in an AMI. However, I initially did not know that the AMI would be rotating as well so the axis of rotation did not go through the center of the AMI. In my case, this also caused a sudden stop without any error-message.
After I changed the axis to the center of the (cylindrical) AMI, everything worked fine.
Hope this might help someone.
Best regards
Arne Simons
arsimons is offline   Reply With Quote
Old   September 11, 2019, 18:46
Aashay Tinaikar
ARTisticCFD is on a distinguished road
Hello Moe and Arne,
You might have to understand that simpleFoam is a steady state solver. As far as I have known, all steady state solvers will exit once the convergence is achieved, i.e once the residuals are small enough and do not change much with each iteration.
If you can see in the original post, the convergence criteria for simpleFoam in fvSolution was 10e-6 for both U and p. The residual after 1st itertation was in the range of e-8 << convergence criteria. Hence the solver assumes that the steadystate has been reached and there is no need to compute further. Therefore it stops.
This is surely not a bug/or due to some errors. Hence there is no error in the output. The steady state has been reached well before your endTime.
This is not the case for transient solver. It will continue to compute in time.
Hope this helps
ARTisticCFD is offline   Reply With Quote
Old   September 12, 2019, 04:23
Arne
Originally Posted by ARTisticCFD View Post
Hello Moe and Arne,
Hope this helps
Hi ARTisticCFD
Thank you for your reply. In my case, the problem occurred with a transient solver (interFoam) and resulted in a stop without mentioning 'end' or any error.
I am just wondering, shouldn't a steady state solver give and 'end' if the convergence is achieved before the endTime?
Best regards
Arne
Old   September 12, 2019, 05:31
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Originally Posted by arsimons View Post
Hi ARTisticCFD
Best regards
Arne
I have mentioned this few times before but people ignore it and move on to find other explanations.
I have observed this problem with my solver Wildkatze and saw that operating system killed the process without warning.
For it typically it happens when i switch off the internet or i switch off some other big process. In the book keeping the operating system (ubuntu and mint) are killing some processes that they shall not be killing.
I suspect this is what is happening with you.
PS: I did not observe it with ubuntu 14. Ubuntu 16 was terrible and now with latest version it happens but not as much as it happened with ubuntu 16.
ARTisticCFD likes this.
arjun is offline   Reply With Quote
Old   September 12, 2019, 10:31
Aashay Tinaikar
Yes, both of you are right.
It should show an end statement even if it converges before the end time. If it doesn't there could be other reasons.
I agree with Arjun , I have observed this behavior couple of times on ubuntu 18.04 as well. This could well be the reason for termination of your solver. Unfortunately, I have not found any reason for its termination though.
PS. For me, it happened very seldomly and in that case, I just ran it again. If it is getting terminated at each run, then the problem might be a little different.
arjun likes this.
Old   July 20, 2022, 06:49
Wolfram Schneider
Wolfram is on a distinguished road
I recently faced the same issue and searched the entire forum for any hints. It seems like there is no specific reason for this behaviour.
In my case a refined mesh at the boundaries solved this issue. Apart from that the entire setup remained the same.
Wolfram is offline   Reply With Quote
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 07:53
Laminar simpleFoam and inviscid simpleFoam herenger OpenFOAM Running, Solving & CFD 7 July 11, 2013 07:27
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
HELP PLS: Simplefoam manipulated to add diffusive mass transport...but solver stops!! 1gn0rant OpenFOAM Running, Solving & CFD 1 August 13, 2010 12:02
