chtMultiRegionSimpleFoam issues - non-conformal meshes & residual handling... |
Rep Power: 13 ![]() |
Hello Foamers,
I have been facing some problems with the use of the "conjugate heat transfer solver - chtMultiRegionSimpleFoam" lately and I would like to get another opinion on some specific issues. First of all, for this thread I will be referring to the v4.1 of OpenFOAM. More specifically I am facing some problems regarding: 1) The use of non-conformal meshes between "fluid" and "solid" regions. I have noticed that even if I change the boundary "type" for the coupled patch in "constant/polyMesh/boundary" from "wall" to Code:
Coupled_wall_fluid { type mappedWall; nFaces 24000; startFace 1339125; sampleMode nearestPatchFaceAMI; // sampleMode nearestPatchFace; sampleRegion Solid; samplePatch Coupled_wall_solid; Code:
Coupled_wall_solid { type mappedWall; nFaces 10000; startFace 289600; sampleMode nearestPatchFaceAMI; // sampleMode nearestPatchFace; sampleRegion region0; samplePatch Coupled_wall_fluid; } On the other hand, when the 2 coupled boundary patches (mesh created in salome as <unv> for the record) are conformal, then the solution appears to be more meaningful. Heat is conducted through the solid and is convected to fluid, judging from the temperature fields in paraview when post processing the results. Is it something that has to do with the "nearestPatchFaceAMI" mode? Could this be a bug or is it something else that I am missing here? 2) For the same (steady state) solver I have noticed that up to the v4.1 there seem to be an issue with the residual control for multiple regions. I have already seen the bug report and the solution that was implemented in OpenFOAM-dev for the solver (https://github.com/OpenFOAM/OpenFOAM...gionSimpleFoam) My problem in this case is that even with this fix, residual control doesn't seem to work! (at least for me!) What I did was to compile the fixed solver from the OpenFOAM-dev repository as a custom solver in OF v4.1 environment, named as "customCHTMultiRegionSimpleFoam". The compilation was successful, but when I try to declare the convergence criteria in "system/fvSolution" under "SIMPLE" dictionary as usual: Code:
residualControl { p_rgh 1e-3; U 1e-3; "(k|epsilon|omega)" 1e-3; h 1e-3; // tolerance 1e-03; } Code:
Time = 1 Solving for fluid region region0 --> FOAM FATAL ERROR: Attempt to return primitive entry ITstream : /home/bot/OpenFOAM/kostas-4.1/run/my_cases_mech_v4-1/submit_test_case_CHT_pipe_v0/system/fvSolution.SIMPLE.residualControl.U, line 86, IOstream: Version 2.0, format ASCII, line 0, OPENED, GOOD primitiveEntry 'U' comprises on line 86 the doubleScalar 0.001 as a sub-dictionary From function virtual const Foam::dictionary& Foam::primitiveEntry::dict() const in file db/dictionary/primitiveEntry/primitiveEntry.C at line 189. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::primitiveEntry::dict() const at primitiveEntry.C:? #3 Foam::dictionary::subOrEmptyDict(Foam::word const&, bool) const at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Attached you will find a link, leading to a test case that I prepared in order to check all these issues. I hope that it would be useful, if someone has the time to take a look on that! Thank you in advance and I would be grateful for some feedback on all these issues! Regards, TEST CASE LINK: https://my.pcloud.com/publink/show?c...cbMqSaJhTjzWSV |
I wasn't able to figure out any solution to the above mentioned issues until now, so I changed to the conjugate solver of the "foam-extend" version (v.4.0) named "conjugateHeatSimpleFoam". It seems to work properly and definitely it can handle non-conformal patches, since it includes classes for GGI (obviously with the necessary interpolation).
If someone finds any further clue about the "chtMultiRegionSimpleFoam" solver case, please post it here to be visible for anyone interested in this topic. Regards, |
Çağatay Emre Ayhan
Rep Power: 8 ![]() |
Hello foamers, I am new to Openfoam. I am trying to solve steady conjugate heat transfer around and inside a cylinder. I checked my boundary conditions and thermophysical properties. But I get this nonsense result. Any help will be appreciated.
Sam Mallinson
@manalis, change your residualControl entry to:
residualControl { p { tolerance 1e-6; } U { tolerance 1e-6; } h { tolerance 1e-6; } } Last edited by SamMallinson; October 10, 2018 at 18:55. Reason: specify user |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
