rhoSimpleFoam doubts on BC and fvSchemes (external aero)
Like Tree2Likes
  • 1 Post By giovanni.medici
Old   July 6, 2017, 18:24
Default rhoSimpleFoam doubts on BC and fvSchemes (external aero)
Giovanni Medici
giovanni.medici is on a distinguished road
Dear all,
I joined this forum few years ago, and have appreciated the tons of information it provides, I've read so many interesting posts, that I almost blush due to the questions I'm going to ask...
Recently I'm doing some experiments with openFOAM. I find the software really interesting, and there is unparalleled possibility to adjust it to the user needs, maybe after some (many) headaches …
My testcase is a low speed (34 [m/s] 3 m long rc aircraft), external aerodynamics, CFD case.
Due to the slow speed regime I've (with some success), modelled the problem using simpleFoam, kwSST, and run several AoA (0 to 10 [deg]).
The mesh is half airplane, unstructured, tetra, + hexa and pyramids on the BL more or less 5m elements. 10 layers of BoundaryLayer.
I’m currently trying to run rhoSimpleFoam, to introduce compressibility (which I expect should play a rather minor role, anyway it could, maybe, explain some differences between the results obtained with another solver).
The best result I could achieve is running ~200 iterations, with very low relaxation factors, and then, apparently after a residual bump, the run crashes (you could find the error among the attachments).
I would be so grateful if any of you could please answer some (several) questions that are hereby reported?
rhoSimpleFoam
1. Which would be the most suitable BC conditions in case one wants to use the same mesh with different AoA? Other solvers use quite frequently a sphere far-field / or half-sphere far field approach. I used a combination of symmetry and freestream BC. I’m particularly puzzeled as far as turbulence BC is concerned (some interesting information is available Problem running simpleFoam with kOmegaSST turbulence model) , in particular alphat?
2. The mesh as I said is not structured (I attached the checkMesh result), which is in your opinion, the most suitable combination in fvSolution and fvSchemes? I read several interesting posts about the opportunity to use potentialflow initialization , nonorthogonalCorrectors (nNonOrthogonalCorrectors), nCellsInCoarsestLevel (What are several parameters mean in fvSolution file?). Some of you prefer PBiCG to GAMG for U e and p. But I read that GAMG is more efficient in a small home cpu (6 cores). I tried so many different setups, I’m running out of ideas …
3. Would it be possible to use the (converged), solution of an incompressible case run with simpleFoam, as starting point for the compressible case (transform incompressible case in compressible case How?
simpleFoam
4. simpleFoam, is incompressible, thus p is specified as p/rho. Does this affect in whatsoever way the forces calculation? Beside the rho ratio, is p: static pressure, right?
5. If I specify 0 as p in the 0/ folder, the converged results, close to the far field, are a constant negative value of pressure, as if the parameter reported in the BC 0 file was a setting for the ptot. What operation do you currently use to output (or compute/calculate) the CP in paraview?
6. Apparently although I went up to 10 deg, the wing seems not to stall, which is quite an unexpected behavior. Possibly to capture such complex, instability of incipient stall I shall use a different solver (transient), such as centralFoam, I tried, but without any success.
Thanks
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "(p|e)"
	solver GAMG;
	tolerance 1e-8;
	relTol 0.1;
	smoother GaussSeidel;
	nPreSweeps 1;
	nPostSweeps 2;
	cacheAgglomeration on;
	agglomerator faceAreaPair;
	nCellsInCoarsestLevel 200;
	mergeLevels 1;
    U
        solver          smoothSolver;
        nSweeps         1;
        tolerance       1e-08;
        relTol          0.1;
	"rho.*"
        solver          diagonal;
        tolerance       1e-05;
        relTol          0;
	"(k|omega)"
        solver          GAMG;
        tolerance       1e-08;
        relTol          0.1;
        nCellsInCoarsestLevel 20;
		nPreSweeps 1;
		nPostSweeps 0;
		mergeLevels 1;
SIMPLE
	nCorrectors 1;
	nNonOrthogonalCorrectors 3;
	pRefCell 101325;
	pRefValue 101325;
	rhoMin 1.0;
	rhoMax 1.5;
	transonic       no;
    consistent      yes;
potentialFlow
	nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.05;
		rho 			0.05;
    equations
		p 				0.3;
		U               0.2;
        k               0.5;
		omega           0.5;
		e 				0.05;
	cache
	grad(U);
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default             steadyState;
gradSchemes
    default             Gauss linear;
	grad(U)         	cellLimited Gauss linear 1;
    grad(p)             Gauss linear;
	grad(e) 			cellLimited Gauss linear 1;
divSchemes
    default none;
	div(phi,k)      bounded Gauss upwind;
    div(phi,omega)  bounded Gauss upwind;
	div(phi,U) Gauss limitedLinear 1;
    div(((rho*nuEff)*dev2(T(grad(U)))))      Gauss linear;
	//div(phi,e) Gauss limitedLinear 1;
    div(phi,e)          bounded Gauss upwind;
    div(phid,p)         Gauss upwind;
    div(phi,Ekp)        bounded Gauss upwind;
    div((phi|interpolate(rho)),p)  Gauss upwind;
laplacianSchemes
	default Gauss linear corrected 0.33;
interpolationSchemes
    default                 linear;
snGradSchemes
	default         limited corrected 0.33;
wallDist
    method meshWave;
FoamFile
	version 2.0;
	format binary;
	class dictionary;
	location "";
	object controlDict;
application rhoSimpleFoam;
startFrom startTime; // latestTime
startTime	0.;
stopAt endTime;
endTime	4500;
deltaT 	1;
writeControl timeStep;
writeInterval	250;
purgeWrite	2;
writeFormat	binary;
writePrecision	6;
writeCompression	uncompressed;
timeFormat	general;
timePrecision	6;
graphFormat	raw;
runTimeModifiable	yes;
adjustTimeStep	off;
maxCo	1.25;
maxAlphaCo	0.;
maxDeltaT	1e-2;
functions
 residuals
        type            residuals;
        functionObjectLibs ("libutilityFunctionObjects.so");
        enabled         true;
        outputControl   timeStep;
        outputInterval  1;
        fields
            p
            U
			k
			omega
			rho
			e
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
	type            heRhoThermo;
	mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    // normalised gas
    specie
        nMoles          1;
        molWeight       28.96;
    thermodynamics
        Cp              1004.5;
        Hf           2.544e+06;
    transport
        mu              1.8e-05;
        Pr              0.7;
		As          1.4792e-06;
        Ts          116;
FoamFile
	version 2.0;
	format binary;
	class volScalarField;
	location "";
	object p;
#include        "include/initialConditions"
dimensions [1 -1 -2 0 0 0 0];
internalField uniform $pressure;
boundaryField
	botWt
		type freestreamPressure;
	topWt
	outlet
	sideWt
	inlet
	ldgAvoid
		type zeroGradient;
	sym
		type symmetry;
FoamFile
	version 2.0;
	format binary;
	location "";
	object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform $temperature;
boundaryField
	"sideWt|botWt|topWt"
		type zeroGradient;
	outlet
		type inletOutlet;
		inletValue $internalField;
		value $internalField;
	inlet
		type fixedValue;
	ldgAvoid
		type zeroGradient;
	sym
		type symmetry;
FoamFile
	version 2.0;
	format binary;
	class volVectorField;
	location "";
	object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform $flowVelocity;
boundaryField
	sideWt
		type freestream;
		freestreamValue uniform $flowVelocity;
		rhoInlet $densityRef;
	botWt
		type freestream;
	topWt
		type freestream;
	outlet
		type freestream;
	inlet
		type freestream;
	"ldgAvoid|flap|Aileron|VT|Rudder|elevator|HT|wing|fuselage"
		type fixedValue;
		value uniform (0 0 0);
	"NoseLDG|mainLDG"
		type slip;
	sym
		type symmetry;
FoamFile
	version 2.0;
	format binary;
	location "";
	object alphat;
dimensions [1 -1 -1 0 0 0 0];
internalField uniform 1e-6;
boundaryField
	  type            zeroGradient;
	outlet
	  type zeroGradient;
	inlet
		type zeroGradient;
		type compressible::alphatWallFunction;
		Prt 0.85;
		value uniform	1e-6;
	"NoseLDG|mainLDG"
		type zeroGradient;
	sym
		type symmetry;
FoamFile
	version 2.0;
	format binary;
	location "";
	object k;
dimensions [0 2 -2 0 0 0 0];
internalField 4.335;
boundaryField
	  type            zeroGradient;
	outlet
	  type            inletOutlet;
        inletValue  uniform    $internalField;
        value       uniform    $internalField;
	inlet
		type fixedValue;
		type kqRWallFunction ;
	"NoseLDG|mainLDG"
		type zeroGradient;
	sym
		type symmetry;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 4.2;
boundaryField
		type calculated;
		value uniform 0;
		//type inletOutlet;
		//inletValue $internalField;
		//value  $internalField;
	outlet
	type calculated;
		value uniform 0;
		//type inletOutlet;
	inlet
		type calculated;
		value uniform 0;
		//type fixedValue;
		type nutkWallFunction;
		value uniform 0;
	"NoseLDG|mainLDG"
			value uniform 0;
	sym
		type symmetry;
FoamFile
	version 2.0;
	format binary;
	location "";
	object omega;
dimensions [0 0 -1 0 0 0 0];
internalField uniform 54.30;
boundaryField
		type zeroGradient;
	outlet
		type inletOutlet;
	inlet
		type fixedValue;
		type omegaWallFunction;
	"NoseLDG|mainLDG"
		type zeroGradient;
	sym
		type symmetry;
INITIAL CONDITIONS
flowVelocity        (34. 0. 0.);
pressure            101325;
densityRef			1.225;
dpressure			0;
temperature         288;
turbulentKE         1000;
turbulentEpsilon    25000;
sk_malladi likes this.
giovanni.medici is offline   Reply With Quote
Old   July 23, 2017, 11:54
Giovanni Medici
I think I solved most of the issues I had, now. I changed the BC using the information provided in this tutorial: https://community.dur.ac.uk/g.l.ingr...torial2012.pdf
and the thread rhoSimplecFoam: error in Forces output (correct pressure field)
which gave me the insight of using the temperature limiter. Now the rhoSimpleFoam converges accurately and the comparison with the other CFD solver are very encouraging.
As far as my doubts of total or static pressure of the simpleFoam solver, I think the answers, provided in the thread Pressure in OpenFOAM are complete, a must to be read
I attach the final version of BC (0), constant and system folder, as well as a residual convergence picture.
Old   October 26, 2021, 10:19
Default PDF link is broken
Foad
foadsf is on a distinguished road
sadly the above link to the PDF tutorial is broken. I think The PDF can be found here. But if you came to this page looking for rhoSimpleFoam tutorials, you will be disappointed.
foadsf is offline   Reply With Quote
Old   October 27, 2021, 06:06
Domenico Lahaye
dlahaye is on a distinguished road
Possibly here
https://wiki.openfoam.com/index.php?title=Tutorials
https://wiki.openfoam.com/Collection...#Joel_Guerrero
https://wiki.openfoam.com/Collection...ichael_Alletto
dlahaye is offline   Reply With Quote
convergence, rhosimplefoam, simplefoam
