July 3, 2017, 06:43 |
running in parallel
Gebregziabher
Rep Power: 9 |
Hi all,
I am new to OpenFoam and interFoam solver, I want to run a case in parallel simulation, but when i decompose it, i found in the decomposed folders only constant folder not the 0 folder, what could be the possible problem? Thank you so much for your help! |
July 3, 2017, 13:30 |
alberto
Rep Power: 10 |
Do you have the folder 0, constant and system?
did you use the command decomposePar? |
July 3, 2017, 13:52 |
Re - parallel running
Gebregziabher
Rep Power: 9 |
Dear dewey,
Thank you so much for your concern, yes I used the decomposePar command, I got the solution now ...like you know..i did my mesh with Gmsh but I forget to assign the base type boundary conditions. Thanks again !!! |
July 3, 2017, 14:18 |
alberto
Rep Power: 10 |
Your welcome, good luck!
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 22:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 08:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 04:50 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
