Water flow, using multiphaseEulerFoam, problems with Boundary Condition
Like Tree2Likes
  • 1 Post By saddy
  • 1 Post By saddy
Old   June 26, 2017, 16:14
Default Water flow, using multiphaseEulerFoam, problems with Boundary Condition
Cheng
kanes is on a distinguished road
I am trying to use multiphaseEulerFoam with my case. It looks like this:
What I want:
At t = 0, this area is full of air;
Water flows into this area from the top and then flows out of this area from the bottom.
However it does not work.
Water just stopped at the top (at t = 25s), shown in the picture :
I am using the following initial conditions:
alpha.water:
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    outlet
      type            zeroGradient;
    inlet
         type             fixedValue;
         value            uniform 0.5;
    walls
        type            zeroGradient;
alpha.air:
internalField   uniform 1;
boundaryField
    outlet
      type            zeroGradient;
    inlet
        type              fixedValue;
        value             uniform 0.5;
    walls
        type            zeroGradient;
U.water:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    outlet
         type               pressureInletOutletVelocity;
           phi                  phi.water;
          value              uniform (0 0 0);
    inlet
          type               flowRateInletVelocity;
           massFlowRate        constant 0.027778;
    walls
        type               noSlip;
U.air:
boundaryField
   outlet
            phi                  phi.air;
           value               $internalField;
    inlet
          type                 fixedValue;
    walls
       type               noSlip;
p_rgh:
dimensions          [1 -1 -2 0 0 0 0];
boundaryField
    outlet
            type             fixedValue;
    inlet
        type            fixedFluxPressure;
    walls
Can someone indicate me where I am wrong?
regards,
Cheng
kanes is offline   Reply With Quote
Old   July 11, 2017, 04:49
sandy
saddy is on a distinguished road
try two things,
first try to give velocity for water instead of mass flow rate,
second plz check
whether your inlet is a patch or a wall, bcz if its a wall water cannot enter
hope that helps
kanes likes this.
saddy is offline   Reply With Quote
Old   July 11, 2017, 10:42
Cheng
Originally Posted by saddy View Post
try two things,
second plz check
hope that helps
Hey Sandy,
thank you very much!
I set the inlet as 'patch', then it works.
But now new problem is, the Phase-sum volume fraction always increased.
I also use the velocity for water (inlet)
do you have any suggestions for this?
thanks
Old   July 11, 2017, 13:36
sandy
i m glad i could help
now what is your error?? can u copy paste it here?
and what about mass flow rate have u tried with ur old boundary conditions??
Old   July 11, 2017, 14:02
Thomas Sprich
Swift is on a distinguished road
Do you mean the phase sum increased above 1?
What did you set the outlet to. Is it also patch?
Sent from my EVA-L19 using CFD Online Forum mobile app
Swift is offline   Reply With Quote
Old   July 17, 2017, 04:14
Cheng
Hi Sandy,
thanks.
sorry for late reply.
yes, I've tried also the mass flow rate, but after some iterations the ' Phase- sum volme fraction' incresed abouve 1.
like this:
Phase-sum volume fraction, min, max = 1 0.999983 1.18336
do you have any suggestions for the boundary conditions?
thanks
Old   July 17, 2017, 04:20
Cheng
hey Thomas,
yes, above 1.
I have set the outlet as patch.
do you have any suggestion?
thanks
Old   July 17, 2017, 04:48
Cheng
Hey Sandy,
I have also tried to define the Inlet (patch) for water and air separately, as follows:
Then I also changed the alpha file like this:
alpha.air:
boundaryField
walls
type zeroGradient;
bottom
type zeroGradient;
top_water
type fixedValue;
value uniform 0;
top_air
type zeroGradient;
alpha.water
boundaryField
walls
type zeroGradient;
bottom
type zeroGradient;
top_water
type fixedValue;
value uniform 1;
top_air
type zeroGradient;
However after some time the 'Phase-sum volume fraction' still increased above 1.
I didnt figure out.
Old   July 17, 2017, 19:08
sandy
Originally Posted by kanes View Post
Hey Sandy,
alpha.air:
alpha.water
I didnt figure out.
your alpha seems fine. i guess now problem is somewhere in p/u files
don't fix outlet pressure with internal field. use zero gradient b.c instead
Old   July 18, 2017, 03:48
Cheng
Thanks.
the p_rgh and U.* file as follows:
p_rgh
boundaryField
bottom //outlet
type fixedValue;
value uniform 0;
top_air
top_water
walls
type zeroGradient;
U.air
boundaryField
bottom
phi phi.air;
walls
type fixedValue;
top_air
type fixedValue;
top_water
type fixedValue;
U.water
boundaryField
bottom
phi phi.water;
walls
type fixedValue;
top_air
phi phi.water;
top_water
massFlowRate constant 0.1;
// type fixedValue;
// value uniform (0 0 -0.03368);
Water should flows out from the bottom.
If I use 'zeroGradient' for the outlet pressure, then there is the problem with Continuity.
Old   July 18, 2017, 05:23
sandy
hey look. i can't specifically give u all b.c. what i can give u is physical setup for b.c.
your phases are flowing counter-currently right??
so 1. you have to give separate inlets and outlets..ok
2. face 1 : inlet for air, oulet for water face 2: outlet for air inlet for water
now imagine if your surrounding four patches are "walls" and both 2 faces are allowing mass to accumulate. and rate of mass inlet is greater than rate of mass leaving. where will this mass go then??
so it will push back the lighter phase more, i.e. air from inlet, some of the water will also be pushed back because we are using incompressible flow, so this is referred to as backflow, openfoam allows tis condition to be modelled using "inletoutlet" and "outletinlet" boundary condition where backflow is specified using "value"
so try using inletoutlet bc. for alpha ,and see if error comes
basically we have try to adjust b.c. u can't just setup bc in one go. it takes time
keep trying you will eventually get it
good luck
kanes likes this.
Old   July 19, 2017, 05:05
Cheng
Hey Sandy,
thanks a lot!
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
