VOF initialization with a STL file (closed volume)
Like Tree10Likes
  • 10 Post By dglee
Old   June 23, 2017, 02:16
Default VOF initialization with a STL file (closed volume)
Dongguk Lee
dglee is on a distinguished road
Hi guys,
I was looking for the way to set the VOF initial position by using a certain shape (closed volume of STL file).
Finally I was able to do that.
Since I was not able to find this way from web searching, I write this thread here. Just prepare your stl file and set your setFieldsDict file with "surfaceToCell" optioin.
/*--------------------------------*- C++ -*---------------------------------*\
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 4 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
FoamFile
version 4.1;
format ascii;
class dictionary;
object setFieldsDict;
location "system";
defaultFieldValues
volScalarFieldValue alpha.secPhase 0
regions
// Select based on surface
surfaceToCell
file "sphere.stl";
outsidePoints ((-1 -0.8 -0.5)); // definition of outside
includeCut false; // cells cut by surface
includeInside yes; // cells not on outside of surf
includeOutside no; // cells on outside of surf
nearDistance -1; // cells with centre near surf
curvature 0.9; // cells within nearDistance
fieldValues
volScalarFieldValue alpha.secPhase 1
guin, JFM, frantov and 7 others like this.
dglee is offline   Reply With Quote
Old   January 6, 2018, 09:47
JFM
JFM's Avatar
John Anonymous
JFM is on a distinguished road
Send a message via Skype™ to JFM
Hi Dongguk Lee
I appreciate you providing this post I have been looking for this type of approach for a period of time. I have taken your approach and tried to apply it to my particular case, however I am recieving the following error message:
Create time
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
    Setting internal values of volScalarField alpha.water
Setting field region values
--> FOAM FATAL ERROR:
Cannnot read "test_1.stl"
    From function bool Foam::triSurface::read(const Foam::fileName&, const Foam::word&, bool)
    in file triSurface/triSurface.C at line 360.
FOAM exiting
The code I have used in the setFieldsDict is:
defaultFieldValues
    volScalarFieldValue alpha.water 0
regions    // Select based on surface
      surfaceToCell
    //     https://www.cfd-online.com/Forums/openfoam-solving/189582-vof-initialization-stl-file-closed-volume.html
        file                     "test_1.stl";
        outsidePoints            ((3.02858 1.94427 83.2));    // definition of volume outside
        includeInside            yes;                        // include cells inside surface
        includeOutside            no;                            // exclude cells outside surface
        useSurfaceOrientation    true;                        // use surface normals
        nearDistance            -0.01;                        // cells with centre near surface
        fieldValues
            volScalarFieldValue alpha.water 1
I have also attached a copy of the STL file I am hoping to use to set the initial phase conditions. This STL includes a volume of the alpha (water) phase and has been snapped to the external boundary vertices (inlet/outlet/wall patches) with the exception of the top surface which is set at the desired water surface elevation within the model domain.
I have checked the db/dictionary (surfaceToCells) and the layout of the function and what you have provided appears to be fine so i guess the issue relates to the STL itself.
Any assistance guidance will be appreciated.
Regards
JFM
File Type: gz test_1.stl.tar.gz (701 Bytes, 62 views)
JFM is offline   Reply With Quote
Old   January 7, 2018, 22:49
Dongguk Lee
Hi JFM,
I tried with your "test_1.stl" file and it works fine.
Could you please try again, but please locate the "test_1.stl" file in your project directory. not inside of 0 or constant or system.
Old   January 10, 2020, 05:15
Default Same problem
Ann
Adyk is on a distinguished road
I know, this is an old thread, but maybe you read it anyway. This is exactly the same problem I struggle with:
Here is the error message
Cannot read "1.stl"
    in file triSurface/triSurface.C at line 304.
FOAM exiting
and this is my setFieldsDict
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
defaultFieldValues
    volVectorFieldValue U (0 0 0)
regions
    surfaceToCell
        file "1.stl";
        outsidePoints ((1 1 0.01)); // definition of outside
        fieldValues
Well, i don't really understand the "outsidePoints ((x y z)); // definition of outside" , how do i define them? which values of my shape define the outside? Probably that's my problem..
I attached the stl file.
Hope you can help me!
Adyk is offline   Reply With Quote
Old   January 13, 2020, 02:55
Yogesh Bapat
ybapat is on a distinguished road
Outside point is point outside the stl and inside the geometry. Also I recommend you rename you file to start with string instead of 1. You need to keep the file in project directory or provide full path.
Regards,
-Yogesh
ybapat is offline   Reply With Quote
Old   January 13, 2020, 05:15
Ann
Thanks for your reply! Finally I got it. But there's another problem.. This is for my bachelor thesis, so it would be great, to get it work.
Okay, I'll rename it.
Does it matter, where this outside point is? And how can I define the position of the stl in my Mesh?
At the moment, I don't see the phase in ParaView. When I look at p_rgh or U I can see something (don't know what it is exactly, but something happens). But the shape itself is not visible (see attached files)
I also did the volume rendering, but there is nothing..
Does "surfaceToCell" give me the phase at all? Or is it just for U, p etc?
Old   January 14, 2020, 06:16
Yogesh Bapat
Outside points is just any point outside the closed STL in which you want to patch the phase. surfaceToCell can be used to patch any scalar, vector etc. field.
Regards,
-Yogesh
Old   January 14, 2020, 06:17
Yogesh Bapat
Outside points is just any point outside the closed STL in which you want to patch the phase and inside the mesh
initialization, interfoam, setfields, vof
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
