How to add random perturbation for velocity in Openfoam
Like Tree6Likes
  • 1 Post By Tobi
  • 3 Post By Tobi
  • 2 Post By tomf
Old   June 21, 2017, 05:29
Default How to add random perturbation for velocity in Openfoam
Maria
marialhm is on a distinguished road
Hi dear all,
I have a model in which the inlet velocity is in x direction, while random perturbations in Y direction is needed. What kind of boundary condition or functions should I use, and how?
Thanks in advance!
Maria
marialhm is offline   Reply With Quote
Old   June 22, 2017, 04:14
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Maria,
I think you should look at either groovyBC (from swak4Foam) or turbulentInlet. I guess the latter would do just fine. Please note that there may be some pressure fluctuations introduced and when the fluctuations are too large you may get problems with convergence..
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 22, 2017, 04:24
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi Maria and Tom,
I think Tom's idea is one of the easiest and simplest. For competence, you also could use a codedFixedBC, in which you define your x-value as a constant and the y-value could be build randomly using the Random class of OpenFOAM. However, using groovyBC should be more easier (depend on the point of view and your programming knowledge). I just wanted to mention this way too.
Cheers.
cryabroad likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 22, 2017, 06:18
Maria
Thanks, Tom and Tobias,
I tried to use groovyBC, but I dont know which random function I should use. I tried random(), but it seems Openfoam does not recognize it.
Also, for turbulentInlet or codedFixedBC, should I install more subroutines?
Best,
Maria
Old   June 22, 2017, 06:34
Tobi's Avatar
Tobias Holzmann
the random functionality within groovy is a function of groovy. So it should do the work. Right now I cannot test it - so I am sorry. The codedFixedBC is named codedFixedValue in OpenFOAM and is an boundary condition which already exists. In the header file (finiteVolume/fields/fvPatchFields/derived/codedFixedValue/) you will find an example of how to use it.
Out of the box an example which I did not tried but should give you some hints:
myPatch
    type codedFixedValue;
    value uniform (0 0 0);
    name myOwnBC;
    code
        const Random randObj(time(NULL));
        const scalar Uy = randObj.scalar01()*10;
        const vector U = vector(1,Uy,0);
        operator==(U);
Here we build a Random function which is everytime different (after calling) based on time(NULL). Then we make the Uy value and after the U vector. Keep in mind that this will not make a perputation because Uy is on each face similar. So you have to make a scalarField which corresponds to the faces. Sourceflux made some nice example how to do that (http://www.sourceflux.de/blog/the-co...ary-condition/).
However, based on the fact that I am using the Random function too, I guess it is not the best idea using that code above because the initialization of the RandomObj is slow because we build some X vector etc. (http://pubs.opengroup.org/onlinepubs...h/drand48.html).
I think groovy is much faster here but I wanted to show you how to make it with the codedFixedValue boundary condition.
GroovyBC
type            groovyBC;
variables     "Uy=random(); Ux=10;";
valueExpression "vector(Ux,Uy,0)";
value           uniform (Ux 0 0);
But again, here I guess the Uy distribution is similar to each face. I guess there are possible ways to get rid of that and to make each face randomly. Sorry that I am limited in that kind of question.
Keep foaming,
Tobias Holzmann
Old   June 22, 2017, 06:39
Maria
Originally Posted by Tobi View Post
myPatch
    name myOwnBC;
    code
        operator==(U);
GroovyBC
type            groovyBC;
I used "Uy=random(); ", but it seems Openfoam doesnt recognize "random()", did I miss something?
Also, the codedFixedValue BC in your reply doesn not work in my case. Should I add some libs?
Old   June 22, 2017, 06:53
Tom Fahner
Just to complete the options, the turbulentInlet option would be like this (version 4.x). No additional libraries are needed.
    inlet
        type            turbulentInlet;
        referenceField  uniform (10 0 0);
        fluctuationScale (0 0.01 0);
        value           uniform (10 0 0);
The source code tells us that
fluctuationScale is RMS fluctuation scale (fraction of mean)
Regards,
Tom
beatlejuice and amolrajan like this.
Old   June 22, 2017, 07:00
Maria
Originally Posted by tomf View Post
    inlet
Regards,
Tom
Thanks, It seems good. I will try this.
Old   December 4, 2019, 07:40
George Pichurov
jorkolino is on a distinguished road
    inlet
Regards,
Tom
However this usage will use the same seed so the results will replicate if you make another run.
jorkolino is offline   Reply With Quote
Old   April 3, 2023, 05:48
Stefan Zitz
Zitzeronion is on a distinguished road
myPatch
    name myOwnBC;
    code
        operator==(U);
This solution works for me with minor modification, see below
myPatch
    name myOwnBC;
    code
        const Random randObj(1234);
        const scalar Uy = randObj.sample01<scalar>()*10;
        operator==(U);
     codeInclude
         #include "Random.H"
One thing is that scalar01 is now sample01 and it needs the <type>. The other thing is the codeInclude, which ensures that Random.H is linked properly (without it I couldn't make it work). The 1234 in randObj is just to set a fixed seed.
Zitzeronion is offline   Reply With Quote
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 14:50
Adding jpeg picture file in OpenFoam post in add a message window kumar2 OpenFOAM 1 March 22, 2006 23:17
