alphatWallFunction vs alphatJayatillekeWallFunction
Like Tree10Likes
  • 3 Post By arvindpj
  • 1 Post By wc34071209
  • 1 Post By khedar
  • 3 Post By wc34071209
  • 2 Post By Gerhard
Old   June 4, 2017, 18:02
Default alphatWallFunction vs alphatJayatillekeWallFunction
Yuehan
wc34071209 is on a distinguished road
Hi Foamers,
Looking at the source code, the difference between
alphatWallFunction
and
is apparent.
For alphatWallFunction, alphat = mut/Pr, where Pr is the turbulent Prandtl number.
For alphatJayatillekeWallFunction, it is more involved, as it distinguishes linear law region and log law region.
What I am wondering is the scope of application and the pros and cons of these two wall functions.
Does appliation of these two wall functions for alphat depend on low-Re or high-Re turbulence model, high-resolution mesh or low-resolution mesh, or others?
Thank you.
wc34071209 is offline   Reply With Quote
Old   June 9, 2017, 16:18
Default Depends on the type of flow
Arvind Jay
arvindpj is on a distinguished road
alphatWallFunction - for compressible cases
alphatJayatillekeWallFunction - for incompressible cases
Cheers :-)
-Jay
tariq, lukasf and lpz456 like this.
arvindpj is offline   Reply With Quote
Old   June 9, 2017, 16:20
Yuehan
Cheers :-)
-Jay
Hi Jay,
Thank you for your reply. But both can be applied to compressible cases, provided that you put 'compressible::' before them.
arvindpj likes this.
Old   June 9, 2017, 16:27
Arvind Jay
What would you use in "alphat" in case of a compressible low-re case ?? Is it
wall
            type             calculated;
             value           $internalField;
Thanks,
Jay
Old   June 9, 2017, 16:41
Yuehan
What would you use in case of a compressible low-re case ?? Is it
wall
            type             calculated;
Thanks,
Jay
As far as I know, 'calculated' b.c. does not apply to mut/nut.
Old   June 9, 2017, 17:12
Arvind Jay
Originally Posted by wc34071209 View Post
Hi Jay,
But,
compressible::alphatWallFunction is strictly for compressible cases
Old   June 10, 2017, 16:03
khedar
khedar is on a distinguished road
alphatJayatillekeWallFunction performs much better than alphatWallFunction for various y+ meshes (I have tested on a channel flow for y+=10 to 50 with BSL-EARSM model) and would advise to use the same if using high y+ meshes.
lpz456 likes this.
khedar is offline   Reply With Quote
Old   June 11, 2017, 09:32
Yuehan
But,
Yes, if you use for incompressible, you use
alphatWallFunction
or
and if you use for compressible, you use
or
compressible::alphatJayatillekeWallFunction
I am talking about OpenFOAM 2.3 and I am not certain about OpenFOAM 3.0 and later versions.
saadat66, masimasiqi and Sakun like this.
Old   June 11, 2017, 09:33
Yuehan
Thank you for your reply. But much better performance, you mainly mean the profile of T at the near wall region or the convective heat flux or both?
Old   June 11, 2017, 09:47
khedar
By much better performance I mean the convective heat fluxes. I am not sure how you would get a profile at the near wall region since due to the wallfunction usage, there is only one value of temperature which in turn is calculated using some thermal universal profile by alphatJayatillekeWallFunction. So in other words WallFunction uses the profile to get the temperature at the near wall cell. Do correct me if I am wrong.
Old   June 11, 2017, 10:03
Yuehan
I mean how the value of temperature at the 1st, 2nd, 3rd, ... layer of the mesh agrees with DNS or experimental data.
Have you ever compared these two wall functions for alphat on a grid leading to y+ < 5?
Old   June 11, 2017, 15:33
khedar
I have not done cell wise check for the temperature values since it would not make any sense. First cell value with this wallfunction for say y+30 mesh cannot be same to that of y+1 mesh without any wall function.
I have compared the heat fluxes with a simulation on y+1 mesh in OpenFoam and CFX. I get a good match for these.
Old   June 11, 2017, 16:18
Yuehan
I mean you compare the values of temperature at different wall distances (not at different y+) with DNS or experimental data.
So you mean you have obtained quite close results to CFX on a y+=1 mesh with alphatJayatillekeWallFunction? Did you simulate a compressible or incompressible case?
Old   June 11, 2017, 16:26
khedar
I simulated compressible case using buoyantSimpleFoam solver.
Old   April 15, 2019, 11:12
Jianrui Zeng
calf.Z is on a distinguished road
I am wondering whether alphatWallFunction is suitable for both high Re and low Re? Thank you.
calf.Z is offline   Reply With Quote
Old   April 15, 2019, 11:24
Arvind Jay
For LowRe cases, I prefer using alphatJayatillekeWallFunction
Old   March 1, 2021, 05:04
Gerhard
Gerhard is on a distinguished road
wall
            type             calculated;
Thanks,
Jay
For low-Re cases, would a fixed value of zero not be better?
The turbulence viscosity, nut, is set equal to zero in the nutLowReWallFunction.
Now, for alphat, looking at alphatWallFunction, for example, the thermal diffusivity is calculated as
alphat = nut / Prt.
In other words, for low-Re application, if nut = 0 at the wall, I would think alphat = 0 should also be the case at the wall?
Regards,
Gerhard
caio.df and saidc. like this.
Gerhard is offline   Reply With Quote
Unknown patchField type alphatWallFunction for patch type wall ranasa OpenFOAM Running, Solving & CFD 7 November 21, 2019 03:13
Error during initialization of "rhoSimpleFoam" kornickel OpenFOAM Running, Solving & CFD 8 September 17, 2013 06:37
Heat Transfer from a Rough Cylinder in Tunnel RE=2.2E5 M=0.07 aerothermal OpenFOAM Running, Solving & CFD 9 May 23, 2013 05:12
